Self-Powered Generator - Inventor From South Africa
Started by SkyWatcher123, August 11, 2018, 01:18:43 AM
Low-Q
This experiment is so basic, and known, that I cannot imagine it will work as an over unity machine. It is essentially spinning magnets and coils. What can possibly make this device different from a normal generator?
Vidar
SkyWatcher123
Hi all, I'm still testing this setup variant, it is not exactly the same as the south african setup.
Hi shylo, thanks for the reply, I'm aware of what you say and have run many similar devices as well.
What i can say so far, this is performing different. The voltage keeps increasing on the charging side for every swap cycle and I'm draining the input side to the same level every time, specifically to 12.35 volts and the run time is also increasing in every cycle phase.
Hi low-q, thank you for your reply, I'm also aware this type of setup is common, look at the circuit drawing I posted, it's not exactly the same as most I've seen or tried.
Also, what can possibly make this different you say, well I always think about a gasoline engine car, if the timing is off, that car is barely moving.
Maybe it's similar to that, if things are not setup within a certain window of design, most will not see anything out of the normal.
Not that I'm saying this is operating out of the norm, though it is looking interesting and I'm just sharing my observations thus far, not making claims.
peace love light :)
aldex
Hi, keep testing and posting your experiences. Years ago I tried to replicate some energizers and you are making me continue testing. There is no impossibility until we find the end of the possible. which I particularly do not believe they have found
SkyWatcher123
Hi aldex, thanks for the positive reply.
I will indeed continue testing, as the results are still encouraging.
I am now officially keeping track of data, since the results continue to be positive.
Total run time has been around 15 hours at around 3.2 watts input.
Of the two 12 volt tractor batteries, one started with 12.56 volts and the other started with 12.55 volts before starting this testing.
The overnight rest voltage on the most recent input side batteries is 12.57 volts.
The overnight rest voltage on the most recent charge side battery is 12.70 volts.
At around 48 watt hours used so far, one of these batteries should have dropped in voltage by now, but that is not what is being observed.
Each of these 235 cold cranking amps tractor batteries has around 12-13 amp hours capacity.
Shall continue testing and documenting the results.
peace love light :)
shylo
Skywatcher
You show 11 strands paralleled, couldn't you just use a single strand of a heavier guage?
Not trying to discourage.
Your work and sharing is greatly appreciated.
Thanks  artv
