New discovery suggest that permanent magnet motors might be possible
Started by Low-Q, September 26, 2018, 11:53:45 AM
F6FLT
Quote from: telecom on March 09, 2019, 01:52:08 PM
When I was in school, they taught me work in kg * m - what is the difference?
The comparison of the difference of work in the axial vs lateral directions is on page 12.
Can you for once read the whole document before commenting?
Nothing on page 12 either. It's not even a work calculation. To do this, it is necessary to integrate the product F*distance on the trajectory, and to be conclusive, it is necessary to show that for the same starting and arrival point, this integration depends on the trajectory, i.e. here, is different when the magnets slide side by side or move away from each other.
Will you continue to indicate page numbers unrelated to the problem raised, or have you understood the question, that of the experimental demonstration with measurement data that the work depends on the path, while all we know and see until now is that this is never the case when the energy comes from a potential difference, here a magnetic potential?
https://www.voanews.com/a/can-better-electric-motor-save-planet/4235140.html
as explained more than 20 years before :
http://www.geminielectricmotor.com/
permanent magnet motors and magnets true potential force use , demagnetisation risk thrue coercive force :
https://patents.google.com/patent/US6037692A/en
power/density + efficiency : 1 up to 10 KW output per Kg motor weight and 99% conversion, RPM/Frequency!
telecom
Quote from: F6FLT on March 11, 2019, 05:36:04 AM
I think all of this is addressed in the document, exactly the way you outlined it.
I can't say for sure, though, that all the data presented are correct - they need to be retested independently.
I'm not against a healthy bias, but your bias is interfering with the productive thought.
Low-Q
Quote from: lancaIV on March 12, 2019, 05:47:49 PM
https://www.powerelectronics.com/alternative-energy/permanent-magnet-motor-feasible
I have read both this article, and the article that it links to at the beginning (The article that made me post the initial post in this thread).
I did a simulation in FEMM, but the complete cycle is somewhat inconclusive due to inaccuracy in the simulation, but no obvious signs of a working model.
I't easy to believe that it would work if you ignore the magnets travel (distance), but if you multiply the distances with the magnetic forces (potential energy at any given point in space), and summarize all positions, you end up in about nothing.
Say you simulate a scenario that is 100mm x 100mm, and you take measurements at every mm, the result average to zero - more or less.
Vidar
