Perpetual motion track magnets and gravity
Started by juliotony, October 29, 2018, 12:13:41 PM
Belfior
add an electromagnet between the top magnet and the wheel. Zap that magnet to counter the cogging of the closes rotor magnet and the cycle repeats. The top permanent magnet will do all the work (oh shit did I mention a PM and work in the same sentence...). Electromagnet can be zapped with energy that was collected from a sister wheel on the same shaft that has magnets going past coils.
burnit0017
https://youtu.be/H9p6K4UehuA
https://youtu.be/jKIWcJiJs04
https://youtu.be/9bzQyEBcQrU
Hi, I like your idea. Are you planning to build test? I started to build and combined the three above projects. If the gravity and magnet configuration does not work, I will the solenoid. Cheers
Belfior
Quote from: burnit0017 on October 29, 2018, 03:59:26 PM
Well I have these ideas written in my black notebook :) My idea was to put the rotor magnets in ying yang form, but a singular spiral could work better. Then you need just one pulse per revolution
I got the magnets, shafts, bearings and wheels and they are all in a box in my garage. I will build it at some point
Belfior
oh and I made magnetic bearings so the shaft floats in the air. Also use a reed switch for the DC jolt to the electromagnet. It will self regulate to what ever speed. Make the electromagnet from ferrite and make a coil around it.
The PM will turn the wheel and when the closest magnet is near the PM you put DC into the electromagnet to block the PM and repel the last rotor magnet. Then you are back at the first magnet and a new revolution begins
Rubber wheels are easy to drill into or acrylic. Drill holes that go deeper and deeper. Then glue round magnets into the holes and you got your rotor. Even half a tun of magnets will do, because it takes off really fast and easily turn full rotation even with few magnets
