The book is dedicated to self-propelled mechanical generating devices.
Started by rakarskiy, November 02, 2018, 11:56:37 AM
Floor
Quote from: rakarskiy on November 27, 2020, 11:30:36 AM
Wesley, So you can describe the whole book,
I'll try briefly:
The formula of the ketic energy:   Ek = 1/2mv^2; where:  m - mass in kg;  v- speed in m / s.
We write for an example:
Ek = 10kg * 2 m / s = 40 Joules / s   * 0.5 = 20 Joules / s
Ek = 10kg * 50 m / s = 25000 Joules / s * 0.5 = 12500 Joules / s
Rough losses, in a tube are equal to a loss of 1 kg / s (1 l / s)
Ek = 9kg * 50 m / s = 22500 Joules / sec * 0.5 = 11250 Joules / sec
And here is how and why, it is not forbidden for anyone to read the book.
I think all other discussions are optional. I do not discuss unread material with the interlocutor.
https://rakatskiy.blogspot.com/2020/11/autonomous-hydro-power-plant-for-home.html
                                 Here you go with another of your nonsense statements.
quote
"The secret is simple, in increasing the speed of the mass."
end
  floor
Does a permanent magnet near magnetic force field kind orientation attract
by energy,   by force  , by suction pressure , by ' work' in input neutral units or ever calculateable units ?
2 baskets or 2 tanks ,same/similar,one filled with liquid :
between both 'container' interloctive (locare !) a fix/flexible tube
the tube entering into full/filled container I and :
SUCTION of the tube channel by mouth or mechanical  compressor or also called pump
and filling the outcoming liquid into empty container II,
EVACUATION
external energy free ,or is it not ?
Clearly,dependent some parameters/Praemisse/Praeambel !
Complicated,free flow,I mean not,easy experimental to realize the search/found- sensation !
Deutschland,Bayern, Isar-Amper-Elektrizitaets-Werk,Speicher I Kochelsee,Speicher II Walchensee
Portugal,Braga,Elevador do Bom Jesus wikipedia,Waterballast-train-track,up and or down
Sincerely and a nice weekend wishing
OCWL
rakarskiy
Westley, I didn't think you were so illiterate. A lot of money, does not give awareness, probably takes away. Read more academic literature.
As far as I remember, you read and understand Russian. I will slightly translate one paragraph of a Russian textbook on physics.
https://scask.ru/j_book_mech.php?id=81
QuoteFirst of all, let us pay attention to the fact that this force grows very rapidly with increasing fluid velocity. Using the obtained formula, F = pQv^2, it is easy to calculate, for example, that at a speed of 1 m / s the jet will press on every square meter of the obstacle surface with a force of 1000 N (or When the speed increases to 20 m / s, these forces increase to i.e. with an increase in speed only 20 times, the forces increased 400 times
This feature of the action of fast-flowing waters was the cause of many natural phenomena. Huge ravines, riverbeds and river valleys were formed due to the destructive action of such forces created by flood waters. The erosion of sea and lake shores is produced by the same forces arising during the surf. These same forces allow rivers to transport soil eroded by them over long distances.
You probably want to argue with the theory of relativity. Einstein will be angry with you. Although he is a thief, he stole all ideas from his wife, but even in this theory:
Equivalence of mass and energy
https://en.wikipedia.org/wiki/Mass%E2%80%93energy_equivalence
lancaIV, one must follow the path of least resistance. I do not deal with industrial installations, but it is very possible to perform MW, with a smaller volume of water and simpler pumps, and more compact. There is one nuance - the volume, so that there is no strong heating. Canadians have a problem with this, it gets warm. According to rumors, the Americans use similar installations to charge the energy sources of combat lasers, and in Russia in one research institute there are two installations of 5 and 7 MW. "It's not for nothing, Westly, he spawns like that" (Russians have such an expression when the enemy is in a panic)
Have a good weekend
For those interested - Book and calculator at: https://plati.market/itm/3039038?lang=en-US
stivep
I was not asking you about any secrets nor your own secrets.I  have ask you to answer simple questions in  format  listed below.
_____________________________________________
Quote from: rakarskiy on November 27, 2020, 12:08:41 PM
I didn't ask for your opinion about me.
And I didn't ask you  to send me to any links.
I didn't ask you for any proof of any theory.
I didn't question, nor deny, nor object, nor doubt, yet, that particular device nor its futures.
I  DID ASK YOU  TO ANSWER SIMPLE QUESTIONS :
I'm posting again that list:
a. what is the form of original energy used by the device.?
b. that original energy (from point a.) is converted to what type of energy till it is converted  into electrical energy at the end of the process?
c. Efficiency  of refrigerator is more than 100%
    https://www.quora.com/How-can-a-refrigerators-efficiency-be-greater-than-1
    can you explain to me how the device  described by you has efficiency greater  than 1?
The format of  your answer should look like:
Answer to ad a:
the original form of energy used is: ( provide your explanation)
answer to ad b: original energy (described in point "a") is converted to : ( provide in your explanation - the list all of forms of that converted  energy)
answer to ad c: the  efficiency of the device  described by me is :( provide your explanation)
and efficiency of  the device described by me is more than 1 because : ( provide your explanation)
Wesley
rakarskiy
Wesley  :D
You cannot, by definition, order me! In general, you should be glad that I respond to trolling.
In closed systems, efficiency cannot be more than one by definition.
Considering my self-contained hydrogenerator.
All power generated by the generator cannot exceed 5 kW (for example), but the efficiency is taken as a unit. The pump electric motor consumes 1.5 kW (5-1.5 = 3.5 kW to the consumer).
The efficiency of the installation can be estimated as 3.5 / 5 = 0.7.
But at the same time, the generation process is closed and self-propelled.
