The book is dedicated to self-propelled mechanical generating devices.
Started by rakarskiy, November 02, 2018, 11:56:37 AM
Floor
@ all readers
The diffuse cascading  or otherwise, has no applicable value to the.......
battery powered pump / nozzle / Pelton  type water wheel / generator device
                          as presented in Mr. Rakarskiy's     02_ENG_HHP_SELF.pdf .
                                         (This device runs on a battery).
The  pump / nozzle / Pelton  type water wheel / generator,  arrangement, only,
and  greatly decrease the amount of usable energy that would otherwise
have been available directly from the battery or from the battery and then
through a DC to AC converter.
The described diffuser system is only useful in gas systems.
   floor
rakarskiy
Quote from: Floor on January 11, 2021, 07:20:50 PM
@ all readers
   floor
The language of an engineer is a calculation and a drawing. If your arguments are just words that are not supported by anything, then this is the opinion of an ordinary person, nothing more.
I think whoever is interested will figure it out. Liquid is a very interesting medium. Difficult, but very interesting. Water has a lot of potential, after acceleration it increases quadratically.
In general, a very interesting article in Russian. It is not related to my device, but it is very interesting.
http://vitanar.narod.ru/laval1/laval1.html
Floor
The formulas do not say the same things you are say.
Your arguements are Bull Sh_t.
And so you reveal what was immediately apearant, although you were given
some benefit of the doubt. You are just another hukster.
If you see Kay....
   Why...
      Oh...
       You,
           can tell her for me,  walk away.
Cadman
Rakarskiy,
You can't expect your calculations to be taken seriously if your base numbers are wrong.
The HF6B pump you cite on page 16 has a maximum working pressure of 1.47 bar. https://torujyri.ee/en/high-flow-pumps/957-centrifugal-pump-hf6b-pedrollo.html
Then you state: H - 12 meters (2.1 atm/1.4 bar). No, 12 meters of head is 1.176 bar.
Then you write: 4 meters is 1.4 atmospheres. No, it's 0.387 atm.
Then on page 18, "The height of the water in the tank (surface - points of water intake by the pump) is 0.7 meters." followed by the first line in your table of calculations "Pump outlet pipe" and give a pump pressure of 2.16 atm, which exceeds the Maximum working pressure of your pump by a large margin.
There is no point in continuing.
https://www.convertunits.com/from/meters+head/to/bar
https://www.convertunits.com/from/meter+of+head/to/atmosphere+[standard]
https://www.convertunits.com/from/bar/to/atm
rakarskiy
​https://youtu.be/Az0v79-vG_E
The author from Indonesia did not bring his installation to its logical conclusion, "stumbling" precisely on the calculations and design of the generator. His mistake is that when changing the parameters of the generator, he did not change the rotor, leaving the magnetic induction in the same place, but lengthened the wire, reduced its cross section. As a result, he received the necessary EMF (no-load voltage), but excluded the possibility of obtaining the required current parameter in the wire. It was necessary to increase the number of magnets on the pole, change the design of the rotor, or add another (or more) block of the accelerator module, using the PUSH-PUL technology, in order to increase the speed of rotation of the rotor - a massive flywheel.
EMF formula: E = B * L * V;
where: B - magnetic induction (in teslas); L is the length of the conductor (in meters); V is the rate of change of the magnetic induction on the conductor (meters per second).
Current formula: I = (E - Ubat) / R + rZ + r0;
where: E - EMF of the no-load phase (in volts): Ubat - operating voltage of the storage battery (in volts); R, rZ, r0 - resistances of the loop, load and phase wires (in Ohm)
The second formula does not change, we use it to calculate the current, i.e. battery voltage and loop resistance cannot be changed, only one EMF parameter remains. To fulfill the condition for changing the conductor length parameter (in the first formula), in the corresponding case, it could not be changed, or it could be performed with a large cross-section to preserve the phase conductor resistance parameter r0 (in Ohms), but the volume of the package did not allow this. There are only two parameters left: B - magnetic induction (in tesla) - increase, this means adding magnets to the stack, or V - the rate of change of magnetic induction on the conductor (meters per second), adding one more or other accelerating nodes of the PUSH-PUL system.
https://rakatskiy.blogspot.com/2021/03/live-overunity-proof-free-energy.html
Perhaps in the future, the author will still achieve the correct calculation of his design and receive a self-propelled gun with recharging the ballast battery.
If you read what the authors of EARTH ENGINE (Gravity Generator) from the USA say about their design
"We 'push' a large mass by manipulating the magnetic field. When the two opposite sources of 'fuel' (magnetic fields) driving the flywheel mass are in the correct position, the engine generates a small electromagnetic charge, about 52 W. This charge allows the opposing sources of fuel. "see" each other and can create a significant force to rotate a large mass of the flywheel. This inertial force of the rotating mass is then transmitted through a separate magnetic link to a generator, which generates electrical energy. This force can also be used mechanically."
(Source: https://ie.energy/about.html )
It is clear that the principle is the same, but a different, larger-scale design. All this can be done independently, including counting
http://rakarskiy.narod.ru​
