Gravity assisted pulse motor generator
Started by burnit0017, November 21, 2018, 03:56:58 AM
burnit0017
Hi, I started a new project that may produce more electricity than it uses to operate. I am combining a pulse motor an a over balance wheel to drive a PMA. The PMA will use a PWM cap dump circuit to reduce the BEMF at the output.
https://youtu.be/qtAEWFlPcS4
https://youtu.be/jKIWcJiJs04
I have already manually tested the PMA PWM cap dump circuit.
https://youtu.be/euGYWZsLGRM
burnit0017
https://youtu.be/zFGGvwaYI6U
magnet pushes the moving weight toward the center. A one way bearing should be added to the moving weight to help the rotation.
burnit0017
https://youtu.be/5e5bpB1gPHQ
Hii, Spring has return I am continuing work on the TSO gravity assisted pulse motor. I have fabricated many different configurations and the above device seems to be the best way to proceed. I will post results when available.
burnit0017
https://youtu.be/U9I18-mZHtI
Hi, I will be combining the above configurations. I order a step up converter so I can booster 12 volts dc to 60 volts dc. It should be enough to keep the oscillation going. I will post results when available.
https://youtu.be/NVSOO0FeAPs
