Flynn / Lafonte slider - 800% OU possible
Started by norman6538, December 29, 2018, 07:33:23 PM
Turbo
Quote from: norman6538 on December 30, 2018, 12:22:14 PM
That  is true and also of many other inventors but I really learned a lot from all he did.
I did make a slider setup that is OU but due to switching losses it would not self run.
I always wanted him to see that but never could get a valid email address/reply.
I also learned that several mechanisms need to be involved to make it work.
My pendulum that goes past its dropped point is also an example of using
gravity inertia and magnetism to make it work. Disturb any of those factors
even a little and it fails or gets stuck.
Over unity exists. I have seen it several times but the switching losses are too high
to make it self running.
Norman
It exists but you are using the loudspeaker because you think it is the source of the sound while you should understand it is the signal source that makes the thing sing.
You are using the light bulb trying to make light because you think that the light bulb is the source of the light but you should understand that it is the signal source that makes the thing blink.
This is one of the core elements and very easy to verify yet nobody seems to bother with it and spend their lifetimes trying to make speakers sing and light bulbs blink without any power input, and they are (almost) ALL GOING TO FAIL.
The ones that will succeed, will understand what i wrote and have a different starting point then yours.
Gravity is no different you can throw a ball off a high building Gravity will carry it down, where did the energy come from ?
norman6538
Turbo, I did not get any of the speaker stuff.
So do you want me to know or do you want to keep it a secret?
Or are you a detractor troll?
Could you or someone else explain this?
Norman
norman6538
Turbo, Obviously you did not view my pendulum. So here is what it does.
1. lift to 2 oclock.
2. drops down to 6 and up  to noon and does not get stuck at noon.
3. slowly falls down to 6 and gently stops there.
That is a very sick pendulum. It does not get stuck at the stick spot.
Pendulums do not do this.
So where does the extra 2 hrs of lift come from?
I believe it comes from a combination of forces
1. gravity
2. inertia - requird because when it goes too slow it gets stuck at the sticky spot
3. magnetic
and the real contributor is probably magnetic spin because if you
flip the mags it fails.....
see the youtube here.
https://www.youtube.com/watch?v=4FzK2XKQ-74
in 11 seconds you will have some serious re-thinking to do.
I keep saying - we do not understand what magnets and electricity are.
We only understand their observable characteristics.
After years on these forums I have come to believe that many folks are not here
to learn - they want to shoot off their mouth/keyboard  with their ideas.
But there also are some really good researchers here far better than I that
I have great respect for. ie Naudin Woopyjump and others.
If you track my posts you will see I ask questions when I don't understand.
PLEASE - MAY WE ALL WORK TOGETHER IN 2019
Norman
Turbo
It means a speaker will not sing without input power.
And a lightbulb will not shine without input power.
There are no secrets just stop trying to use magnets as batteries, they are not.
They will not magically keep moving when put in this or that configuration.
They are like a lens you can bundle or focus the already present light with them, but they will not shine by themselves.
Take a magnet, observe the magnetic field.
Remove the magnet.
Put a powered coil in it's place, observe the magnetic field.
Remove the coil.
Put Ion wind in it's place, observe the magnetic field.
Is it the magnet?
No, because it's also there without the magnet, and with the coil and the ion wind.
Is it the coil?
No because it's also there without the coil, and with the magnet and ion wind.
Is it the ion wind?
No because it's also there without the ion wind, and with the magnet,and with the coil.
It is already there, always, everywhere.
It is a property of the environment, space.
It's not coming from the magnet, not the coil or the ion wind.
Those only affect it's appearance, and that triggers you to think that you can extract unlimited amounts of energy from it.
That is not the case.
Stop wasting your time, and our's, posting crap pdf's, realize that you need to look elsewhere.
The evidence is overwhelming, STILL people don't understand.
Start with the magnetic field without magnet, without coil, and without ion wind.
Try to power the magnet in stead of trying to power with the magnet.
Therein you will find the answers.
norman6538
Turbo, I clearly understand what you are saying.
I have shown that permanent magnets can do more work out than in.
The pendulum shows that but a spring will not show that.
And my slider  principle also shows that but it does not have enough extra
to run all by itself which is perpetual motion.
Remember there were mountains on the moon as Galaleo said but his professor's
mind was already made up and he did not want to consider either the facts or the truth.
A recent book that I read makes the same point about our moral origins being mostly
as we say "set in our ways" but sometimes can be changed.
"The Righteous Mind" by Jonathan Haidt  why good people are divided by politics and religion.
after I read this it was as if I had black and white filters on my eyes and after removed
I can see colors. Imagine that. I wish I could see magnets and electricity like Tesla and others.
Norman
Norman
