Zero and Q device
Started by v8karlo, January 04, 2019, 11:18:12 PM
v8karlo
Quote from: NickZ on January 11, 2019, 08:29:21 AM
   V8Karlo:   The higher that the voltage is raised, the lower will be the amperage at the output. You are mentioning about input voltage to output voltage, but that does not mean that there is more usable power at the output.
   Raising the voltage is easy, but that does not give you more total power. If you think that it does, you should be able to light more than just a small bulb.
   There are no attacks here. There are questions to be answered. And videos demonstrating the device with some actual readings are needed to back up the claims which up to now have not shown OU, nor self running.
   As this is a free energy forum, the goal is not to light bulbs from the grid, nor to drain batteries like a regular inverter would do, but to show something unusual.   What is unusual about this device?
My coil is 1:1 trifilar. 5,2 kHz there is so much spikes that I don't have to use step up.
My output of that coil is 470V and it is 1:1 from 12V trifilar transformer.
I am just using that spikes.I never used step up transformers.
But you have the point.
Zero will multiply power from input by cca 2,5 times.
It will triple input current but voltage is less then input in case with 3 caps (output is 175V, it is not 220V).
So use that with any kind of AC input.
It is not my idea to present you self runner.
The Zero circuit does what it does, you can find use for it or not.
Why not combining all the possible things existing.
Build it and if you don't believe that is more on output don't use it.
I write this for people who built it and asking me questions.
I don't have to convince them to anything because they saw it with their own eyes and they are curious what to do with it?
I don't know what to do with it. That's why we are talking here.
I think the goal is to find right principle. If it is the right principle it can be developed.
And in short time make big devices which will light many bulbs.
Today is my day off, and I am enjoy it. Usually I don't have free maybe an hour per day.
So I left videos and all that stuff to others because I can't afford the time.
I can write a little like today. Or from my smartphone from my job.
Sorry, but I don't have the answer you want.
v8karlo
Unusual is that Zero has more power on output than input.
It is even visible, and the heat is present.
No matter what AC source it has.
v8karlo
You did build it and it does not show you more on output than input?
You were always normal guy and good researcher, so there is no need to defend.
I don't defend Zero. People made it and started to ask questions.
They started to claim that is more on output than input.
I am answering only what I know about it till today from my old experiments.
That was 2012 y. back then when I did all that experiments.
I do not do them any more.
v8karlo
Nick,
I will be more than happy that someone like you develop it and claim it.
My goal was to show with Zero device principle and that it can be done.
I was listening to Wesley and in one moment I decided to make my work open source.
Who can find something useful in it, just take it! I don't mind at all.
#85 : 2,5 times more compared with Victor Arestov power/ load saving device : his led drawn instead 25 minutes 65 minutes : 65/25= 2,6
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=2012065719A2&KC=A2&FT=D&ND=3&date=20120524&DB=EPODOC&locale=en_EP#
You see v8karlo: the right way ! But your is by pieces quantity number  simpler ergo easier/ cheaper to bild !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20041118&CC=WO&NR=2004100349A1&KC=A1#
Capacitor in number serie + di/triode in number serie + resistor in number serie :
Let us see what  the C. O. P. max. will become !
(PERMOTORS GMBH : partner https://www.google.com/search?q=victor+arestov+motor+&client=firefox-b&oq=victor+arestov+motor+&gs_l=mobile-heirloom-serp.3..30i10.37604.42469.0.43113.15.15.0.0.0.1.205.1762.2j10j1.13.0....0...1c..34.mobile-heirloom-serp..5.10.1235.crUd1h_Q-3M)
