What's a magnet/ gravity motor worth to you?? New way of thought.
Started by magnetman12003, January 10, 2019, 01:21:06 PM
skywatcher
Quote from: lancaIV on January 20, 2019, 07:31:09 AM
1 Rotation is for the rotor the maximal freedoms degree limited by the shaft fixation.
You fixed the magnets  ! And their magnetic force field near/ far effect!
1 Rotor( or Stator) dividing this 360° circle in chamber,  where the - each magnet/ its- chamber can  moves with or against the outer Ring !?
Sorry, i don't understand what you mean. The rotor is NOT fixed. It can move (roll) freely inside the drum.
skywatcher
Quote from: ARTMOSART on January 20, 2019, 07:39:50 AM
Hi skywatcher,
nice bwuild and thank for doing the experiment ,if you can, i suggest to you to reduce the number of magnet to half or les ,just an idea?
This would not improve anything, i think it would be even worse then.
Maybe making the drum slightly bigger would improve it a little bit but it's so far from working i think there is no chance that even after some improvements it would work.
I will not waste more time on this project.
It is" relatively" fixed by Stator/ Rotor dimension ratio  !
Give the magnets ccw or cw motion freedom,  their mass moving effect extra as potential !
skywatcher
Quote from: lancaIV on January 20, 2019, 07:49:34 AM
It's absolutely the same as described by Tom and shown in his picture.
I wanted to repilcate Tom's design, not anything else.
  " It is absolutely the same as described by Tom ..."
#46  not ~ #57 ,#48 ~ #57
       #46 / # 48 : magnetic field lines!?
