What's a magnet/ gravity motor worth to you?? New way of thought.
Started by magnetman12003, January 10, 2019, 01:21:06 PM
eavogels
Quote from: Low-Q on January 26, 2019, 07:50:46 PM
Have you ever considered why drum B moves at the side at all? The result, using a magnet to push B to the side, will appearently look like drum A suddenly got more weight on one side. However, the force of the magnet is keeping it there, so the total vector of forces between A and B is perpendicular to the point where A and B touch eachother. So there is no force to spin A, or B with it.
As long B keeps its position to the side, it is logical that there is no driving forces that makes A rotate. Just if B is stuck to A, and B is able to "fall" down and drag A with it, you get rotation for a few degrees. But that is due to the release of potential energy in B.
Vidar
I see some connection with this device from Robert Calloway, when reading the explanation.
http://freeenergy2000.tripod.com/hamstercagerotor.htm
/Eric
skywatcher
Quote from: eavogels on January 27, 2019, 07:36:06 AM
/Eric
That's besically the same principle. I think almost every idea has already been tried by someone. Magnets are not new, so there was plenty of time to experiment... obviously without any success.
magnetman12003
Cut out a 5 inch section of 4 inch diameter pvc pipe.  Make 2 four inch diameter end caps for the pipe and drill a 5/16 or 8mm hole in the center of each cap.   Two 8 mm all ceramic skate bearings mounted in the end caps will have the lowest rotating friction. [
Now take a 3 inch long 1 inch diameter alnico or neo rod magnet covered by a  3 inch, 3 or 4 ply silicon automobile water hose and place it inside the 5 inch long pvc pipe.
Place caps inside both ends of the 5 inch long pipe and run a 12 inch long 5/16 inch or 8 mm diameter non ferrous rod through it.
Support both ends of the rod so the 4 inch diameter ,5 inch long pipe rotates freely.
SLOWLY bring another powerful same size rod magnet close to one side of the supported pipe so the magnet inside the pipe just starts to roll to the other side ""in repel.""  Stop at that point. If done to quick the magnet inside the pipe will pin itself to the inside pipe wall and nothing will happen.
That silicon hose provides the bonding or sticky surface that insures the pvc pipe to start rolling the ""INSTANT"" the hose covered magnet inside the pipe rolls.  The inside magnet must be free to rotate but must ""NOT "" be able to slip around.
This is as simple and inexpensive as it gets as far as build trouble goes.
I plan to show it in late February.
skywatcher
Why should the magnet roll ?  It only rolls until all forces are balanced out. Maybe it also rolls for some short time if you move the external magnet back and forth. But it will not roll if the external magnet is fixed.
magnetman12003
If motion is certainly required then make the external magnet like a small pendulum bouncing back and forth at a certain distance away from the internal hose covered magnet while ""in repel.""   A small springlike device on the external magnet is not hard to construct?
Remember than when the internal magnet try's to go up the pipes inner diameter it will roll backward at some point and that will in turn bounce the external magnet backward. Pendulum forward action will kick in.   Process is repetitive.
