Thanks to ALL for your help!!
What's a magnet/ gravity motor worth to you?? New way of thought.
Started by magnetman12003, January 10, 2019, 01:21:06 PM
magnetman12003
By placing the 4 inch pipe with magnet inside on top of the skate wheel bed it will "" ROLL"" in one spot now and that's the displacement.  You don't have to follow it with the external magnet anymore. That magnet in repel near the setup now supplies the force.  That's all energy.
magnetman12003
magnetman12003
The 3 inch long internal magnet is at its upper limits repeled away from the external magnet.
So now it's weight is resting on the left side of the 4 inch diameter pipe.
That sets up a imbalanced condition where the left heavy side of the pipe rolls downwards.
The internal magnet just rolls in place on the surface of the pipes insides.
Any amount of all ceramic skate bearings can be used to support the pipe in a horizontal position.
I stated 4 each on both sides but more can be used.  The ceramic bearings are the best to use as they are not magnetic.
skywatcher
Always the same wrong reasoning... there can be no permanent imbalance.
Every imbalance of forces causes motion, but the motion stops as soon as the balance is restored.
magnetman12003
The only thing the external magnet does is raise up by repel the internal magnet to its highest elevation.
That's all.  Since the 4 inch drum is round inside the internal magnet must fall one way or another to the drums inside wall.  At its highest limit it rests its weight in one spot on the walls inside.
Now the drum is heavy on that side and rotates downward all the time as the internal magnet is not going anywhere.  The internal magnet is free to turn with the drum however.
