Thanks to ALL for your help!!
How to make a totally free energy generator.
Started by stevensrd1, January 16, 2019, 12:14:47 AM
stevensrd1
This is how you make a real free energy generator. Its all about the ram pumps, if you dont know what they are then do a search on youtube or google. This was known about back in the day but somehow was forgotten, wonder how that happened. Anyway a ram pump works like this. Water from a reservoir flowing down hill a little ways then goes to a ram pump. The ram pump uses that little water pressure from the down hill flow and then pushes water up hill to a great distance far higher then your reservoir. And it does it all mechanically with no needed power source of any kind since a ram pump is powered by gravity itself. Now you can take many ram pumps that get their water from one reservoir and have them working all at once pushing water up hill, this way you get a lot of water going up hill fast. Then you allow that water to fall down hill through electric turbines that generate electricity just like how hydroelectricity is made. And you direct that water that is now falling down hill back into the same reservoir that you used to get the water from in the first place. That keeps it full of water, and you have free electricity generated in the process of it all. So yeah totally free electricity can easily be made. And this was known about long ago, just some how mysteriously forgotten, misplaced, and turned into hydroelectric dams of today that supply the power most pay for. Just the real truth here people, believe it or not as they say.
F6FLT
The flow you can raise is always less than the flow that provides the energy, so the system cannot be looped.
It's like a transformer, just because you have a small voltage in primary and a large one in secondary doesn't mean you can supply the former with the latter. Always the same confusion between potential (voltage or water level) and energy!
stevensrd1
Did you read the info through. Your speaking as if we only use one single ram pump. You can use as many ram pumps as you want, they can all still be connected or getting their water from the same lower reservoir. That allows you to get as much water to the top as quick as you want. Imagine it like this if i have one bucket and dump one bucket into a pool thats not much water. But if I dump 10 buckets all at once then I have a lot of water in the pool and have it in the pool all at once. By using more ram pumps you can have as much water as you want reaching the top at any point in time, and if its still not enough water just use more ram pumps. Thats the secret right there.
stevensrd1
The reason this works is because of gravity, its pull is not depleted or its pulling power lowered by how many objects it pulling downward on. Think of it like this, if I use a battery to light a light bulb, it drains the battery a bit. Now if I use that same battery to light 2 light bulbs the battery drains quicker and as it does eventually less energy will be reaching the light bulbs as more light bulbs used will drain the battery more and more. But with ram pumps their power source being gravity does not drain nor does it lower in force downward regardless how many things gravity pulls down upon. If I use one ram pump I get a set amount of water to a set height at a set time. Lets say that amount is a cup full of water every 5 seconds. Thats not much but if I add another ram pump carrying the water even from the very same reservoir up to that same height I now have 2 cups of water arriving at the top every 5 seconds. And I can add another and another and countless more ram pumps so I can get any amount of water up hill to a set height ever 5 seconds and all at once, in this example. Thats the secret right there because by using more ram pumps they dont pump slower or cause any drain on their power source which is gravity, so they all always pump at a constant speed. Common sense would tell you if you have a set amount of water reaching some height at some set time and I double that I have twice as much water. This can be doubled endlessly by using more ram pumps. So you can get as much water as you want reaching a set height at a set time by using more ram pumps. And again thats the secret right there to it all.
citfta
The following is from a web site about ram pumps.
A ram pump uses the downhill flow of water to pump a portion of it uphill. You can pump up to 25 percent of your supply water, depending on the drop and the lift. Ram pumps will work on sites with 3 to 50 feet (0.9–15 m) of head (vertical drop) and can deliver to elevated sites far from the pump and source.
The formula for calculating the amount of water a ram pump can pump.
Water Delivered = Available Water x Source Fall x 0.5 ÷ Delivery Height
We can see from the formula and information that 75% of the water goes on past the ram pump.  It has to in order for the pump to work.  We also can see that the amount of water a ram pump can pump depends on the source fall or head pressure getting to the pump.  So you can't put more of them in series because the lower ones won't have any head pressure.  And putting several of them in parallel will only work if you have a very large volume of water flowing downhill.  But even then each pump is only going to pump at most 25% of the water that is getting to that pump.  So you can't make a looping system where you keep pumping the same water back to the top.
And ram pumps have not been forgotten.  There are webs sites where you can buy them today.
