A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
Our body emitts in the infra-red spectrum , too !
Good/bad ? Mental emotion indication, fever/infection indication,......
Infrared-lamps for (sub-/percutan) skin treatment ( included emulsion/creme/balsam).
We have to differ between under-/over-dose ! Between medical use and simple room heat device !
W/sqcm power emission density and surface temperature  !
Infrared- emission dries the walls over the time : wet walls lower the insulation efficiency,"cold radiation"
Sergh
Quote from: lancaIV on May 27, 2019, 01:38:46 PMOur body emitts in the infra-red spectrum , too !
Our body, unlike heaters, emits a lower frequency range of IR.
Sergh,
each resistor emitts infra-red radiation.
But not each resistor is defined as " infra-red heater".
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=102014018647&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
[0004] .... and thus corresponds to the electromagnetic radiation of the human substance. ....
1/273   = 1/ https://www.google.com/search?q=kelvin+temperature&ie=utf-8&oe=utf-8&client=firefox-b-m
( you like it complicated?  Newest research results : < 0° K point reached )
George1
It's a really interesting discussion! Need some time to get the essence of each point of view.
George,
https://patents.google.com/patent/WO2014161057A1
EXAMPLE 1
Instead 15x 110 Volts,  60 Watt bulbs
               15x 110 Volts  60 Watt IR cnt heat panel
                                          60 Watt IR cnt ~ 200 Watt conventional conductive heater
                                    9V and 0,1 A input and 3000 caloric Watt- equivalent output
           This is simple calculated theory/ hypothesis
          Works Dr. Paiva device like descripted it will become reality  !
Problem ,comercially ?
https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=WO&NR=2014161057A1&KC=A1&FT=D&ND=&date=20141009&DB=&locale=#
YES, DE : Non-Entry in national Phase
                 = no DE ergo no EP grant
Probably the need from the patent court decision
