A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
George1
To JerryVolland an to Floor.
Hi paid agents of the official science mafia,
Your primitive manipulation techniques do not give any result, this is more than evident. Take some beginner's manipulation techniques guide and study it very, very carefully. Because otherwise you both simply resemble clowns! :)
Look again at our last post of June 28, 2021, 09:44:18 AM. Let us proceed further with our previous questions as written in our last post of June 28, 2021, 09:44:18 AM.
Prof. S. L. Srivastava's solution is given below.
Prof. S. L. Srivastava's solution consists of two lines only.
LINE 1. Current through the electrolyte is given by I = (m)/(Z x t).
LINE 2. Power consumed = (I) x (I) x (R) =  ((m)/(Z x t)) x ((m)/(Z x t)) x (R) = 31.86 W.
I am asking you (PERSONALLY!) my question for the 28th time: Is Prof. S. L. Srivastava's solution correct? Yes or no? Only one word -- either "yes" or "no"!
All members of this forum are waiting for your PERSONAL(!) answer for the 28th time. Only one word -- either "yes" or "no"!
ramset
George
Sorry if I have missed it , your claim has it been built ?
You engage a few men here who build and show their work
Good result or not so good , honestly!
The scientific method or empirical testing with 100% transparency is how we advance .
Math can be a nice start , however your initial claim in post number one seemed simple?
And you mentioned a group you work with?
Have you built the device ? Is it open source ( forum theme)
Can you show it to scientific community here ?(demonstration / lab
Will you take a phone call to discuss this ?
Respectfully
Chet K
Or can the mentioned Professor take a call ?
Thanks Grandma
George1
To ramset.
Hi ramset,
Hi dear colleague,
Thank you very much for your reply. Within a period at least two months your post is the first reasonable post, related to this topic. Please give us (our team) some time to consider carefully and thoroughly your text and answer all your questions in a proper manner. I will write to you in the nearest future.
Regards,
George1
To ramset.
Hi ramset,
Hi dear colleague,
Let us start our explanations. (All considerations in items 1 and 2 below have been experimentally proved within a period of 200 years. But despite of this let us consider again these basic axioms of standard electric engineering.)
1) Assume that a standard SOLID conductor (a standard copper wire for example) is connected to a standard DC source (a standard fully-charged battery for example) thus forming a circuit. (This circuit is equipped with a standard ohmmeter and with a standard ammeter. Besides you have at your disposal a standard chronometer/clock.) Assume further that the Ohmic resistance R of the SOLID conductor is just equal to 1 Ohm. Assume also that current I of 1 A flows through the  SOLID conductor within a period of 1 second. The electric energy, consumed by the SOLID conductor, is just equal to 1 Joule and the heat, generated by the SOLID conductor, is equal to 1 Joule too. The last sentence is a manifestation of the so called first Joule's law of heating. The latter is taken for granted by any electric engineer in the world. No electric engineer in the world measures the generated heat of 1 Joule BY USING OF CALORIMETRY METHODS. Every electric engineer in the world takes for granted the generated heat of 1 Joule.
2) The same for any standard LIQUID conductor (electrolyte). Assume that a standard LIQUID conductor (a water solution of CuSO4 for example) is connected to a standard DC source (a standard fully-charged battery for example) thus forming a circuit. (This circuit is equipped with a standard ohmmeter and with a standard ammeter. Besides you have at your disposal a standard chronometer/clock.) Assume further that the Ohmic resistance R of the LIQUID conductor is just equal to 1 Ohm. Assume also that current I of 1 A flows through the LIQUID conductor within a period of 1 second. The electric energy, consumed by the LIQUID conductor, is just equal to 1 Joule and the heat, generated by the LIQUID conductor, is equal to 1 Joule too. The last sentence is a manifestation of the so called first Joule's law of heating. The latter is taken for granted by any electric engineer in the world. No electric engineer in the world measures the generated heat of 1 Joule BY USING OF CALORIMETRY METHODS. Every electric engineer in the world takes for granted the generated heat of 1 Joule.
3) The question is: Is there any LIQUID conductor (electrolyte), for which the generated heat is not equal to 1 Joule, that is, is there any LIQUID conductor (electrolyte), for which the generated heat is either smaller or bigger than 1 Joule? In other words, is there any LIQUID conductor (electrolyte), for which the first Joule's law of heating is not valid?
4) If you are an expert in electric engineering, then please answer personally the question, mentioned in previous item 3. If you are not an expert in electric engineering however, then please ask your team's experts in electric engineering the same question.
(Note. It is extremely important to clarify together the question, mentioned in item 3 above, as it is one of the fundamentals of our concept.)
5) After clarifying together the question, mentioned in item 3 above, we will proceed further with our next explanations, which will consist of one or two sentences only, and which will show you how to save electric energy in an extremely simple manner.
Looking forward to your answer.
Regards,
ramset
George
Seems I did a poor job asking the question,
Do you have test results from a working proof of concept ... or
Device ....
to show your simple claim of more power out that in ?
Can a viewing be arranged ( will you take a phone call ?)
To setup an independent lab investigation ?
Respectfully
Chet K
Ps
this is after all  an open source forum
And there are members who will help advance a true scientific anomaly!
Thanks Grandma
