Magnetic wheel by steel shielding
Started by vineet_kiran, February 02, 2019, 08:15:48 AM
nix85
Magnetic lines always close and apparently attraction is slightly stronger than repulsion BUT....
ALL FIELD LINES IN SAME DIRECTION REPEL
Magnetic domains in iron do not align so that they all attract, we find them in all possible directions, that's why they call it randomly oriented.
"magnets are unipolar" Well, if you have a toroidal field there are no poles, so it is not even unipolar, it is nonpolar. As for the carries, there are apparently particles flowing in both directions as Leedskalnin drawn in his "Magnetic Current". If you looked at work of Russel he also depicts gravity and magnetic field as two direction flow. So, yes, gravity and magnetism are both polar when field is open. When fields are closed, there is no sense calling them polar unless you are talking about A-field poles which exist even when there are no classical poles.
Now, regarding gravity. You said Earth is a magnet and we are a piece of iron. That's ok comparison, i'd say our subatomic particles are eddies of force acting as resistors to it's magnetic flow.
With important note that there is an inward stream and outward stream (Hollingshead, Zirbes).
I wrote much more but deleted it cause you have to do your own research if you are really interested into these subjects.
Floor
As far as is known, all objects that have mass can also exert a gravitational force.
Not only does a base ball experience an attracting force by the earth, but the earth
also experiences an attracting force by that baseball.
The more massive an object, the greater is the gravitational force it can exert.
Most (if not all) objects have both, a gravitational and a magnetic quality.
Magnets have two poles, while gravity does not.
Magnetic poles that are alike, repel.  There is no comparable or know repelling, in
regard to the gravitational force between objects.  Gravity is not dipolar.
All objects which contain electrons posses some magnetic characteristics.
An electron in motion in relationship to another object which has electrons,
produces a magnetic force.
            OR
An object which has electrons, when IT is in motion, in relationship to an electron
Attracting and repelling magnetic forces are all around us.  The forces of attraction
and repulsion cancel each other out, in by far, most circumstances.
Magnets become magnets not when magnetic forces are made, but rather magnets
become magnets, when the balance between attracting and repelling forces
within the magnet material, are made to be, no longer in balance.
Magnetic shielding is in reality magnetic shunting.  But while it may not be clear to
everyone...
                 ALL shielding is shunting.
Even the "blocking" of a cannon ball by a castle wall is more accurately described as
force shunting, or force redirection, rather than as simply "shielding".
https://overunity.com/18511/floors-magnets-explained/dlattach/attach/175999/
        video @
https://www.dailymotion.com/video/x728wd9
       regards
                floor
nix85
Gravity is not just function of mass, there are other factors like strength of the electric and magnetic fields, spin velocity, extent of etheric mass covering the object etc.
All that exists be it force or "matter" is made of same neutral bubbles (gravity). There is only gravity and it's modalities. When you resist gravity you first get magnetism, then electricity, then electromagnetism, then sound and finally matter. All same substance at different speed.
"Any moving charges produce magnetic field. Protons, electrons, muons, tauons... whatever."
"besides magnetic field created by movement all (as far as I am aware) particles have spin property which is a magnetic moment property. Protons as well as electrons have  1/2ℏ  spin. Even neutrons that do not have a net charge."
Also, it is more correct to say electron (which is not a particle but system of particles, that is, standing waves) is a deformation of a magnetic field. Magnetic field produces an electron, not the other way around. We perceive a magnetic field around a moving electron cause it is resisting gravity slowing it down into magnetism, which is also why one way to achieve levitation is with extreme currents as in Dotto Constantan ring.
Yes..."Iron atom has 4 more electrons spinning in one direction, than in the other".
https://youtu.be/bht9AJ1eNYc?t=1490
But what is magnetic force but slowed down gravity. You may as well call gravity magnetism, it's "vertical component".
nix85
Quote from: Floor on March 18, 2021, 11:35:41 AM
Forgot to address this above altho i said it before. False, false false.
Gravity has 2 poles < geographical south attracting, north repelling, that's why UFOs always come in on Antarctica and leave on North Pole.
There IS gravitational repulsion and it is exactly this what keeps planets, stars, galaxies... apart.
Gravity IS dipolar.
This also reminds me of one incident with Tesla mentioned in Gerry Vassilatos' book.
How Tesla noticed his hand getting sucked in on one side and repelled on another near the axis of a 30kV dynamo spinning at great rpm.
And then there is 3M adhesive tape plant 1980. gravity wall incident
"When he attempted to walk through the corridor formed by the moving film, he was stopped about half way through by an "invisible wall." He could lean all his weight forward but was unable to pass."
http://amasci.com/weird/unusual/e-wall.html
There are tons of accounts like this, Bill Hamilton wrote and spoke about how entrances on the Northrop Anthill facility, Tejon Ranch, California have no doors but two cylinders embedded in the walls which create an invisible forcefield.
George Van Tassel spoke about forcefield stronger than steel made by electrostatic and magnetic fields.
Richard Hoagland spoke how they lost many early satellites because satellites would unexplainably leave their orbits by hundreds of miles because there are BANDS of attracting and repelling gravity around earth.
Speaking of orbits i once calculated the progression of orbits around the sun and to my amazement they too follow the Phi ratio.
Etc.
Floor
            OR
everyone...
        video @
