Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
forest
The members who experiment with revealing the secrets of all operations here in the cafe are "'itsusable/TinselKoala/Nick Zec/GFusion Core" and a few other members.
I haven't seen any cases where the members who are experimenting threaten other members.
But,
Many members, including Remset, threaten to reveal the secrets of the generator's operation.
Ghost members who do not disclose the experiment threaten the members who reveal the experiment.
Some of these will have members with more than one nick.
Members who predict the generator try to solve the structure of the generator by approaching the existing electrical principles.
The Kapanase/Acura/Ruslan generator basically has a structure consisting of a transformer and a grenade.
The yoke-transformer of the Akura/Ruslan generator has the same role and structure as the AC220V transformer inside the inverter used by Kapanase.
Members who do not understand this structure expect and experiment with some technical effect on yoke-transformer.
A member of Jack Noskills, and Russian Romankov, experimented with the yoke-transformer hoping for some technical effect.
https://www.youtube.com/watch?v=Sbb_kSgvzoo&t=54s
https://www.youtube.com/watch?v=AMg6VxBkLkA
Romankov was friendly and experimenting with the schematics, posting them, but the generator didn't work, and Jack Noskills member continued similar experiments after three years.
Members of Jack Noskills imitate the famous Russian generator.
https://www.youtube.com/watch?v=gz0IPdPbHvA
The above generator has an integrated transformer and a grenade.
In order for a'forest' member to require a Jack Noskills member to fully disclose an experiment, it is polite for the'forest' member to disclose a video or photo of the same experiment.
Even my dad doesn't trust members who don't disclose the experiment.
The majority of members who have already understood how the generator works are silent.
It was expected.
Man's greed is endless.
color
Jack Noskills
Re: Simple to build isolation transformer that consumes less power than it gives out
« Reply #405 on: May 08, 2014, 10:50:20 AM »
Don't use the capacitor. If your coil is high impedance then it will work without caps. I have tried higher frequency mods using caps but cannot say about the results for sure because I don't have scope. High impedance means that when load is not connected idle current should be as low as possible.
Can you make measurements, using scope or meter ?
Using isolation trafo in front would be good to have so you could check testcase 3 what is going on there.
I don't understand what the heck is rasor only socket transformer.
Galilei said, "The earth still spins," maybe? ;D ;D ;D ;D
AlienGrey
An interesting analyses but lets look at the above device for a start it uses a royer oscillator this device wastes power in the over lap
of the switching transistors you need a dead time between transitions to minimize this effect or your gaining nothing.
Having an idea of how it works isn't the same as building the device and seeing if it works or sorting the wheat from the chaff
only to ask Its-usable and Nick Zec for help and being told I'm a troll and I should publish what i have found rather than
helping me by testing on kit they already have and in the same breath asking me if i'm also nickname Hoppy and a few others too
silly jester and no I'm just me. All i can say is don't quit your day time job to be a stand up comic with jokes like that.
My resources are limited and components here are expensive and difficult to obtain under the present lock down and
not likely to change in the near future.
SIL
color
AlienGrey
Quote from: forest on February 10, 2021, 03:10:11 AM
Yeah...I remember those experiments I learned something about. When you don't find a magic trick like Kapanadze did you can at least astonish people with a big iron transformer which can be loaded up to the idle current on secondary while lowering input down to almost zero in parallel resonance on primary. However this small effect works only because of mass of iron acting somehow like a regulator for resonance.After you connect load which needs more current then primary idle current then all return back to normal transformer setup.I wonder if having a nice ferrite core transformer and going up to khz range would really make it work like Romancorp self-looper or all those Russian BTG replications ?And NickZ is another person.
So What about Nick Zec ? what experiments has he done we can benefit from and who else is he (nickname wise ?).
Now then we have Doc Stifler and the common mode none inductive choke and low and behold TK's coil in the video that looks as if it works
and yet no one experiments with it except ITSusable and who proves it's a red herring, and yet T1000 keeps saying the grenade needs to be none inductive.
But none of them are ! now look at Delomorto's symmetrical??? device but is it ??
SIL
SIL
