Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
The filament of a light bulb has its own resistance.
Can other synthetic-resonances work when the yoke-transformer resonance and the Kacher-resonance pass through the filament of a hot bulb
Synthetic-resonance through a high-temperature resistor depends on the strength and weakness control of the gate signal and the collector voltage frequency.
Push-pull circuit The two MOSFET collector voltage frequencies and one transistor collector voltage frequency are automatically determined by one PSU output voltage frequency.
https://upload.wikimedia.org/wikipedia/commons/5/5d/Waventerference.gif
In other words,
It means that it has a generator circuit structure in which the frequency can only be adjusted automatically without having to adjust the frequency.
color
The voltage value may vary slightly depending on the value of the resistance value of the bulb, the inductance of the grenade coil, and the value of 1 to infinity capacitance and the additional transformer inductance, but the fact that it is determined within the capacity of the PSU, like a frog in a well, does not change.
color
Sometime only pictures of old legs keep appearing.... ;D ;D
I need some additional explanation,
The few windings of the yoke-transformer's coils do little to help with resonance.
The large inductance of the transformer inductor helps the resonance.
It means that there should be many windings in the transformer coil. 8) 8)
эксперименты с индукционкой от адыга2
https://www.youtube.com/watch?v=9jAqYz9-AUU
I know it's a lot confusing.
However, it does not change that the generator is an alternating current system using a transformer and an air core transformer. ;D 8)
color
And,
Kacher's frequency is not amplified by the two MOSFET frequencies in the push-pull circuit,
It is activated and amplified by the lightning principle created by Kacher by activating Earth-Ground.
The frequencies of the two MOSFETs and the frequency of one Kacher transistor automatically move equally so they do not affect each other.
This caused Ruslan to misunderstand as if the two frequencies helped each other, and cafe members took it for granted, and the error spread.
In a Korean proverb, there is a saying that ``a clumsy shaman catches people''.
It is a minor misunderstanding that occurred because the amplification of the current amount of the generator was so large.
