Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
AlienGrey
it takes over 3 hours to go through all his videos !
justawatt
Edward Lee Dally: he is back
https://youtu.be/qTp_nYQ0CRs
https://www.liveinternet.ru/users/edward_lee/
"The effect was noticed by accident when I set up GNSI as a mandrel for winding a coaxial using an old mini Tesla. But it was wound with another 0.65 mm wire winding and I tried to achieve good spark G.N.S.I. set up and how it is connected to it (to 0.65 mm) capacity, and got a good shock. it's not like the scorching touch of BB RF. then go further experiments in this direction.
windings on a plastic pipe with a diameter of 46mm, the length of the windings is 205 mm.
There are two generators in the installation, one generator (LF) shakes the converter on a ferrite transformer (@ push-pool @) to power the generator of nanosecond pulses and, accordingly, to supply voltage to the coil (@ electromagnet @), then the coils are on a plastic frame and it contains 3 windings , one winding (@ electromagnet @) 475 turns with 0.33 mm wire (to the right). Further, on top of it, the winding of 159 turns with a 0.65mm wire, let's call it resonant, it is connected only to capacitors 1.5μF x 400V - (to the right). Further, winding with coaxial 21 turns RG50U 50 ohm - to the right was previously used in computer networks, a bifilar is obtained - the end of the winding is short-circuited - loaded onto a nanosecond pulse generator. Inside there is one vein - copper, but somehow it is very tough, it does not magnetize. Internal insulation is polyethylene, at least transparent,
Well, from above there is a winding for removing 83 turns - the top one. The take-off winding is loaded on the diode bridge, after the diode bridge there are capacitors. Necessarily polar! The polar ones do not stand up and are stitched or inflated in a few seconds! After the rectifier, I loaded it with a 20 W lamp and, accordingly, the power supply for self-supply. But also, my power supply unit only worked out of four, and the old AT. One did not work at all, two quickly went out of order. A diode bridge between the capacitors and the coil is required! Without it, there is no stability of work!. Total: The windings are all in one direction. (@ according to the photo to the right @) The upper winding is 83 turns (about 2.5 sq.mm.). (Removable). Below it: coaxial - 21 turns RG50U. (Primary TT).
Resonant under the coax, 159 turns of 0.65 mm wire. (Resonant, in resonance of currents) The
lower part is a winding of 475 turns with a wire of 0.33 mm. (Secondary CT into voltage resonance).
Most likely there is a half-wave resonator (@ electromagnet @) with a TEM wave, the phase velocity of which does not depend on the frequency. In this case, if half the wavelength fits into the resonator, then the main vibration corresponds to the lowest resonant frequency. It also resonates at all harmonics of the fundamental frequency.
color
color
AlienGrey
This is one of my dad's experimental data a few years ago.
The circuit structure and capacity are unclear because it is the data derived from numerous capacitor experiments.
According to my dad, he seems to have a problem with the diode bridge, so he retested for several months.
color
