Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
justawatt
These are my findings.
For tuning the resonance coil we have play with following.
Duty cycle 16-26% range.
Dead time
Then tl494 phase shift is 180 degree, we need adjustable phase shift if you see Stalker circuit he used cd4093 ic to adjust the phase.
Most important part if frequency use 20k pot to find the resonance frequency like we all did.
Then use 500ohm or 1 k to fine tune there you will see the standing wave being formed.
The gernade coil winding direction is not important like 2 layers clockwise anticlockwise. Wind this coil clockwise all layers then for resonance coil wind it anticlockwise.
Then you will create standing wave.
Which is the key.
https://youtu.be/LPXXfb5cQrY
https://youtu.be/rpDkVf1ub5c
https://youtu.be/0CqMqTGOVZk
https://youtu.be/AolNFB7ayeE
https://youtu.be/zybuy5SnUlI (check his channel all video)
https://youtu.be/fRA6qf7sTUY (check his channel)
https://youtu.be/OIXveajGyhA (important)
https://youtu.be/qgpPJGgWR5I
To understand better see the scope and signal generator.
There you could resonance frequency at 62 khz.
But at 62.40-62.60 khz you could see the standing wave formed. So like I said in pwm frequency generator use 20k to find the resonance frequency then fine tune 500ohm or 1k to get standing wave.
https://youtu.be/FBAKLoOXv34 ( watch carefully)
Now watch Ruslan video where he told about this waveform.
https://youtu.be/K9tEQxewJpY
https://youtu.be/EFEy-T2akps
https://youtu.be/bfSgUBq1PQ4 (he said the secret here fish 🐠 wave)
It's not like what color is saying it's not about the resonance frequency.)
Ruslan always showed us a sinewave right, see it not a pure sine wave. We have to make the fish wave and when you expand the waveform in the oscilloscope you could see a sign wave inside the fish wave ,we have to pulse to that wave.
I don't know how many understood this.
This is my findings so far.
color
https://realstrannik.com/forum/btg-tarielya-kapanadze/1389-btg-kapanadze-teoriya-i-praktika-2?start=6020#166495
나의 가문의 Spirit들은 유대교의 여호와(어둠신 및 뱀신 아페피)를 잘 압니다.
고대에 나의 가문이 바울(프톨레마이오스 12세)을 도와서 하토르 신전을 재건축했으니까요.
히람 아비프가 솔로몬(앗시리아 왕 Shalmaneser III)을 도와 여호와 신전을  7년 동안 건축한 것은 72인역이 유대인들 과거를 조작해서 첨가한 것입니다.
기원전 1세기 희랍인 과학자이자 공학자인 헤론을 바울이 고용해서 하토르신전을 재건축 했습니다. 클레오파트라 7세 사망 전까지 헤론이 신전공사 감독했습니다.
나중에 이런 자세한 얘기를 할 수 있었으면 좋겠습니다.
지금은 유대교와 기독교 반발로 묻어 놓겠습니다.
Blessed are those who wash their robes, so that they may have the right to the tree of life, and may enter by the gates into the city.(요한계시록 NASB)
참고로 몇가지 더,
셉츄아진트-72인역 구약에서 솔로몬이 여호와 신전을 7년 동안 건축한 이유는,
서서있는 아펩뱀 한마리와 누워있는 아펩뱀 3마리에서 온 숫자 계산법입니다.
누워있는 아펩뱀 3마리는 쌍둥이들이라 총 6마리 입니다.
그래서 1+6=7마리(7년) 됩니다.
1+2=2=4=9 or 8마리가 될 수도 있습니다.
7을 선호하는 것은, 밤의 북두칠성이 북극성 주위를 돌지만 북극성의 위치는 지구의 세차운동으로 25436년 224일 16시간(25436.61511년)마다 북극성의 별이 바뀝니다. 그래서 북극성이 밝은 별이 걸리면 8이 되고, 북극성이 어두우면 7일 되는 원리입니다.
지금의 지구 자전축은 작은곰자리의 알파별을 향하고 있지만 기원전 15세기의 이집트 사람들이 관찰할 당시에는 용자리의 알파별이었습니다.
그리고 2000년전 북극성의 자리에는 특별하게 해당하는 별이 없습니다.
3000년전에는 북두칠성의 손잡이 부분이 거의 북극성 위치에 있습니다. 주변에 북두칠성보다 밝은 별은 없습니다. 용자리 투반도 북두칠성보다 밝은 별은 아닙니다만 엇비슷해서 지금처럼 8번째로 포함됩니다.
이것을 헤론이 아펩신전에 7마리와 하늘신 누트의 음부에 1마리를 추가로 부조한 이유입니다.
그런데 이것을 앗시리아 왕 솔로몬이 만들었다고 하는 이유는,
솔로몬이 전쟁 나갈 때 쓰던 투구에 7마리 뱀이 있어서입니다.
원래는 Urartu 지역을 지배하던 왕들이 사용하던 것인데, 앗시리아와 바벨론이 그 지역을 점령하면서 솔로몬 역활하던 Shalmaneser III에게 바쳐집니다. 더 원래는 이집트 아펩신을 메소포타미아 문명이 채택하면서 시작된 일이라 원조는 아펩신이 되는 겁니다.
가운데 똑바로 물구나무 서서있는 뱀이 한마리 있고, 좌우로 6마리 뱀이 약간 누워있는 형태로 있습니다.
이것을 바울이 아펩신전 3마리 아펩뱀 설정 주제로 채택한 겁니다.
히브리인들은 앗시리아나 바벨론보다 이집트를 더 싫어했습니다. Djed 역활하는 모세가 이집트의 어둠신 아펩을 여호와로 선택하면서 이집트가 신성시하는 태양신이 어둠신을 죽이는 역활하기 때문입니다.
여호와가 아니였다면 바벨론유수 느브갓네살의 바벨론이 제1의 공적이 됐겠지만 어둠신 여호와로해서 공공의 적이 태양신과 이집트가 된겁니다.
But Moses said to the people, "Do not fear! Stand by and see the salvation of the LORD which He will accomplish for you today; for the Egyptians whom you have seen today, you will never see them again forever.(출애굽기 14장)
그래서 유대인들에게  출애굽기는 창세기보다 훨씬 더 중요합니다.
그러나 기독교의 예수가 이집트 태양신을 모델로 탄생해서 유대교 제사장들은 예수를 반드시 죽일 필요가 생긴 겁니다.
셉츄아진트를 사두개인(사마리아인 리더조직) 랍비들이 작성했고, 신약성서를 바울같은 바리새인들이 개입해서 작성한 관계로 태양으로 태어난 예수는 어둠신에게 죽을 운명이였습니다.
그런데 아이러니는 예수는 어둠신 아펩-여호와로 Djed-십자가에 매달려 죽었다는 겁니다.
(이 이야기는 긴 설명이 필요해서 지금은 하지 않겠습니다)
바울의 몸에 흐르는 절반의 피가 바리새인입니다, 즉 바울의 엄마가 바리새인이였습니다.
바리새인들의 조상이 블레셋입니다.
남유다의 주력 세력이 또한 블레셋이였습니다.
구약성서에는 이런 이야기가 없습니다. 신약에서 예수가 이런 사실을 숨겼다고 바리새인들을 심하게 비판하는 이유입니다.
마태복음의 저자 마태가 레위파 사두개인입니다.
그래서 세리 마태가 특별한 이유없이 (사마리아인)죄인으로 언급됩니다.
누가복음 7장에 500-denarii와 50-denarii 얘기가 나오는데, 바울이 50-denarii의 주인공입니다. 500-denarii 주인공은 프톨레마이오스 11세고, 사도행전 7장에서 바울(사울)에게 죽는 스데반의 모델이 프톨레마이오스 11세입니다.
두 사람을 납치한 주인공이 베드로 역활하는 폰투스의 메트리다테스 6세입니다.
'사람을 낚는 어부'라는 유명한 예수의 말은 미트리다테스 6세가 프톨레미 11세와 12세를 왕자 시절에 납치한 사건에서 나온 겁니다.
이집트 역사를 잘아는 사람들은 무슨 이야기인지 이해하실 겁니다.
누가복음 7장에서 두 사람이 베드로에게 납치된 몸값을 클레오파트라 3세가 지불하면서 예수의 발에 향유를 적시고 씻기는 여자가 됩니다.
그러나 이 여자는 태양신전에 있는 마트가 대신합니다.
신약성서에는 마트는 여러가지 역활로 나옵니다. 아브라함의 딸부터, 혈루병 걸려 예수 몸에 손대는 여자로도 나오죠.
바울의 몸에 흐르는 절반의 피가 또한 그리스인이라 바울이 어둠신 아펩-여호와에게 중요한 뭔가를 주입합니다.
이 사건이 신약성서와 구약성서를 존재하게 만든 가장 큰 원인이 됩니다.
이집트신들 특징은 서로가 결합을 잘합니다.
2종, 3종, 4종, 5종, 많게는 능력치를 모두 결합된 신들이 나타나죠.
바울이 이 실험을 어둠신 여호와에게도 합니다.
수십년 후 이집트가 멸망했으니 여호와가 마지막에 선택되어 결합되는 행운을 얻은 것이죠.
누가복음 10장에서 예수가 이 사건을 핵심만 요약했는데,
The seventy returned with joy, saying, "Lord, even the demons are subject to us in Your name."
And He said to them, "I was watching Satan fall from heaven like lightning.
"Behold, I have given you authority to tread on serpents and scorpions, and over all the power of the enemy, and nothing will injure you.
"Nevertheless do not rejoice in this, that the spirits are subject to you, but rejoice that your names are recorded in heaven."
그리스의 대표신이자 번개신인 제우스가 어둠신 아펩-여호와와 결합되는 사건이 벌어진 겁니다.
이것을 72인역 셉츄아진트 저자들이 하지만, 바울로부터 시작된 기독교가 여호와를 배척한게 아니라 예수의 아버지로, 하나님으로 선택하면서 일을 더 복잡하게 만든거죠.
예수가 선악과 죄를 대속해서 십자가에 죽어 죄사함을 얻는 것은, 어둠신을 섬기는 자들 농간이죠.
"When a strong man, fully armed, guards his own house, his possessions are undisturbed.
"But when someone stronger than he attacks him and overpowers him, he takes away from him all his armor on which he had relied and distributes his plunder.
"He who is not with Me is against Me; and he who does not gather with Me, scatters.
누가복음 11장에서 예수의 말대로 예수파의 힘이 더 강했다면 어둠신 여호와 세력을 제거하면 그만이기 때문입니다.
예수파가 여호와파에게 패배해서, 쉽게 말해 태양-예수가 힘이 없어 어둠신-여호와에게 제물이 된겁니다.
하늘신 누트(미카엘 천사역활)와 땅신 게브(가브리엘 천사역활)가 먹은 태양-선악과는 어둠신이 싫어하는 태양과 빛을 먹은 것이라 에덴에서 쫓겨난 겁니다.
그리스 신화에서 프로메테우스가 최초로 인간들에게 불을 전달해준 것과 비슷한 얘기가 됩니다.
빛신파가 완전하게 어둠신파를 제압했다면 예수가 아펩뱀으로 죽을 일이 없었겠지만, 어둠신파가 득세하면서 예수가 어둠신의 아들로 죽은 겁니다. 아니였다면 어둠이 예수의 아들이 되는 역전극이 됐거나, 어둠이 제거됐거나 했겠죠.
그래서 창세기 1장, 2장, 3장의 주요 맥락은 72인역에서 만든 것이지, 바벨론유수 이전의 유대인들이 만든 것이 아닙니다.
악한 지배자가 역사를 조작하듯, 부활을 믿지 않는 사마리아 사두개파 유대인들이 어둠신 여호와의 두루마기를 고성능 전기-세탁기에 이렇게 빨았습니다.
해서 어둠신 여호와가 번개신의 빛까지 장착하면서 창세기 태초에 개입하며 태초의 천지창조로 이어진 겁니다.
사두개인 시초를 솔로몬의 제사장으로 있던 사독으로 유대인들 해석하지만 아닙니다. 사두개인은 앗시리아의 Tiglath-Pileser III(745 – 727 BC)에 의해 앗시라아로 끌려갔다가, 사르곤 왕조의 두 번째 왕 Sennacherib의 아들 Esarhaddon(705 – 681 BC)때 북이스라엘 사마리아로 다시 돌아온, 레위인들이 주축이 된  Djed-모세의 최 측근 그룹입니다.
예수 말대로 출애굽과 관계없는 블레셋의 후손 바리새인들이 Djed-모세의 자리에 앉아서 사두개인들을 혼혈 사마리아인들로 배척한 겁니다.
남유다 주축인 바리새인들은 바벨론으로 끌려갔다가 70년만에 돌아와서 말이죠.
바벨론에 끌려갔던 바리새인은 사마리아-사두개인보다 더 심한 혼혈입니다.
더 얘기해주고 싶지만 어둠신 여호와 숭배하는 바리새파-유대인들이 세상을 지배하는 현재 상황에서, 미국 대통령 선서에 영향을 주기는 싫어 더 언급하지는 않겠습니다.
세상에는 어둠신 섬기면서 좋다고 자랑하며 전도질하는 종교인들이 많습니다.
이 카페에도 있나요?
나는 위 러시아 회원이 뭘 안다고하는지 잘 모르겠습니다만, 저 Djed은 중력을 의미하고 아펩신은 어둠의 animalization라서 구리 금속이 아닙니다.
혹시 번개를 상상했다면 그리스 제우스신에게서 찾는게 빠를 겁니다.
구글의 영문 번역이 조잡하여 한국어 원문도 남깁니다.
The Spirits of my family know the Judaism Jehovah (Apepi, the god of darkness and the serpent).
In ancient times my family helped Paul (Ptolemy XII) rebuild the Temple of Hathor.
The fact that Hiram Abif helped Solomon (Shalmaneser III, king of Assyria) to build the Temple of the Lord for 7 years was added by the Septuagint by manipulating the Jewish past.
Heron, a Greek scientist and engineer in the 1st century BC, was hired by Paul to rebuild the Temple of Hathor. Heron supervised the construction of the temple until the death of Cleopatra VII.
I hope we can talk more about this later.
For now, I will bury it in the backlash of Judaism and Christianity.
Blessed are those who wash their robes, so that they may have the right to the tree of life, and may enter by the gates into the city. (Revelation NASB)
A few more for reference
In the Septuagint-72nd Old Testament, the reason Solomon built the temple of Jehovah in 7 years was,
A number calculation from one standing apep snake and three lying Apep snakes.
The 3 lying Apep snakes are twins, so there are 6 in total.
So 1 + 6 = 7 (7 years).
It could be 1+2=2=4=9 or 8.
The preference for 7 is that the Big Dipper at night orbits around the North Star, but the position of the North Star changes every 16 hours (25436.61511) in 25436 years 224 days and 16 hours (25436.61511) due to Earth's precession. So, when the North Star is bright, it becomes 8, and when the North Star is dark, it becomes 7 days.
Earth's current axis of rotation is directed toward Alpha Ursa Minor, but when observed by Egyptians in the 15th century BC, it was Alpha Dragon.
And 2000 years ago, there was no special star in the constellation of the North Star.
3000 years ago, the handle of the Big Dipper was almost at the position of the North Star. There is no star brighter than the Big Dipper around. Tuban Draco is not a brighter star than the Big Dipper, but it is close enough to be included in the 8th position as it is now.
This is the reason why Heron basked 7 snakes before Apep-god and 1 additional snake  in the vagina of Nut, the sky god.
But the reason that it is said that it was made by King Solomon of Assyria,
There were seven snakes in the helmet Solomon wore when he went to war.
Originally used by the kings who ruled the Urartu region, it is dedicated to Shalmaneser III, who played the role of Solomon when Assyria and Babylon took over the region. More originally, it started when the Mesopotamian civilization adopted Egyptian Apep-god, so the origin is Apep-god.
There is one snake standing upright in the middle, and 6 snakes lying on the left and right.
This is what Paul chose as the theme for setting the three Apep snakes in the Temple of Apep.
The Hebrews hated Egypt more than Assyria or Babylon. This is because Moses, who plays the role of Djed, chose Apep, the Egyptian dark god, as Jehovah, and the sun god, which is sacred to Egypt, plays the role of killing the dark god.
If it were not for Jehovah, Babylon of Nebuchadnezzar, the Babylonian captivity, would have been his number one achievement, but with Jehovah, the god of darkness, the public enemies became the sun god and Egypt.
But Moses said to the people, "Do not fear! Stand by and see the salvation of the LORD which He will accomplish for you today; for the Egyptians whom you have seen today, you will never see them again forever. (Exodus 14 )
So to the Jews, Exodus is much more important than Genesis.
However, the Christian Jesus was born after the Egyptian sun god, so the Jewish priests had to kill Jesus.
The Septuagint was written by the Sadducees (a Samaritan leadership organization) and the New Testament was written by Pharisees like Paul, so Jesus, born of the sun, was doomed to die by the dark god.
But the irony is that Jesus, the dark god Apep-Jehovah, Djed- was hung on the cross and died.
(This story needs a long explanation, so I won't do it now)
Half of the blood flowing through Paul's body was a Pharisee, that is, Paul's mother was a Pharisee.
The ancestors of the Pharisees were the Philistines.
The main force in southern Judah was also the Philistines.
There is no such story in the Old Testament. This is why the New Testament severely criticizes the Pharisees for hiding this fact by Jesus.
Matthew, the author of the Gospel of Matthew, is a Levite Sadducee.
Paul is a descendant of the Philistines who led Moses into the Red Sea.
In Luke 7, the story of 500-denarii and 50-denarii appears, and Paul is the protagonist of 50-denarii. 500-denarii The main character is Ptolemy XI, and Ptolemy XI is the model of Stephen who is killed by Paul (Saul) in Acts 7.
The abductor is Metridates VI of Pontus, who plays the role of Peter.
Jesus' famous phrase 'a fisher of men' comes from the kidnapping of Ptolemy XI and XII by Mithridates VI as a prince.
Those familiar with Egyptian history will understand what I'm talking about.
In Luke 7, when Cleopatra III pays the ransom for being kidnapped by Peter, the two men soak Jesus' feet with perfume and become women who wash them.
However, this woman is replaced by Mart in the Temple of the Sun.
In the New Testament, mart appears in several roles. From the daughter of Abraham, to the woman who had a blood clot and touched Jesus' body.
Half the blood flowing through Paul's body is also Greek, so Paul instills something important in the dark god Apep-Jehovah.
This event is the biggest cause of the existence of the New Testament and the Old Testament.
The characteristics of the Egyptian gods are well combined with each other.
There are 2, 3, 4, 5, or even gods that combine all of their abilities.
Paul does this experiment with Jehovah, the god of darkness.
Decades later, Egypt was destroyed, so Jehovah was lucky to be chosen and united in the end.
In Luke 10, Jesus summarized this event only to the core,
The Greek god of lightning, Zeus, and the god of darkness, Apep-Jehovah, were united.
The Septuagint authors of the Septuagint do this, but the Christianity that began with Paul did not reject Jehovah, but made things more complicated by choosing Jesus as the Father and God.
It is the foolishness of those who worship the god of darkness that Jesus atoned for good and evil and died on the cross for the forgiveness of sins.
"When a strong man, fully armed, guards his own house, his possessions his are undisturbed.
As Jesus said in Luke 11, if the power of the Jesuits was stronger, it would be enough to remove the power of Jehovah, the god of darkness.
The Jesuits were defeated by the Jehovahs, so simply put, the sun-Jesus was powerless and became a sacrifice to the dark god-Jehovah.
The sun-the fruit of good and evil that the sky god Nut (the angel Michael played) and the earth god Geb (the angel Gabriel role) ate was because they ate the sun and light that the dark god hated, and they were expelled from Eden.
In Greek mythology, Prometheus was the first to bring fire to humans.
If the light gods had completely conquered the dark gods, Jesus would not have died as an Apep snake, but as the dark gods gained power, Jesus died as the son of the dark gods. Otherwise, the darkness would have become the reverse of becoming the son of Jesus, or the darkness would have been removed.
So, the main context of Genesis chapters 1, 2, and 3 is from the Septuagint, not from the pre-Babylonian Jews.
Just as an evil ruler manipulates history, the Samaritan Sadducees, who do not believe in the resurrection, washed Jehovah's robe, the dark god, in a high-powered electric-washing machine.
Thus, the darkness god Jehovah intervened in the beginning of Genesis by equipping it with the light of the god of lightning, leading to the creation of the heavens and the earth in the beginning.
The Jews interpret the Sadducees as Zadok, who was the priest of Solomon, but not. The Sadducees were taken to Assyria by Tiglath-Pileser III of Assyria (745 – 727 BC) and then returned to Samaria in northern Israel during the reign of Esarhaddon (705 – 681 BC), son of Sennacherib, the second king of Sargon, the Levites This is the Djed-Moses closest entourage group.
As Jesus said, the Pharisees descended from the Philistines who had nothing to do with the Exodus sat in the seat of Djed-Moses and rejected the Sadducees as mixed-race Samaritans.
The Pharisees, the main pillars of southern Judah, were taken to Babylon and returned after 70 years.
The Pharisees who were taken to Babylon are more mixed race than the Samaritan-Sadduces.
I'd like to say more, but I won't go into more detail because I don't want to influence the American presidential oath in the current world dominated by the Pharisees-Jews who worship Jehovah the Dark God.
There are many religious people in the world who worship the god of darkness, boasting that they are good, and evangelizing.
Are you in this cafe too?
I'm not sure what the above Russian member knows, but that Djed means gravity and apep-snake is the animalization of darkness, so it's not copper metal.
If you ever imagined lightning, it would be quicker to find it from the Greek god Zeus.
Google's English translation is sloppy, so I leave the original Korean text.
color
встречные катушки 100ват
https://www.youtube.com/watch?v=_2kegqFSSVw
встречные катушки 200ват
https://www.youtube.com/watch?v=ZLud4-OVymM
Lighting a 200W light with 200mA is easy. Except for the hypnosis and illusion that Tesla was used.
Bunk is like a prophet leading people in the wrong direction.
Параметрический резонанс в трансформаторе на броневом сердечнике
https://www.youtube.com/watch?v=odrPqhklAak
энергия из эфира. Простой опыт
https://www.youtube.com/watch?v=FO64FF-roqo
For free power generation, the generator structure is also important, but the principle must be understood.
Most people choose a detour when they encounter a cliff at a dead end.
But Kapanadze, Shark and Ruslan jumped off the cliff.
https://disk.yandex.ru/i/Edmx66WjWz4XZA
https://disk.yandex.ru/i/DxVDFC4t-48hKg
The Communist Party of China does not like ordinary people living well.
It is the policy direction of the Communist Party to make the rich concentrate only on a few Communist Party members who are loyal to the Communist Party.
Graham Gunderson Free Energy - Magnetic Implosion Transformer
https://www.youtube.com/watch?v=WvSBVu3c_BE&t=284s
https://www.youtube.com/watch?v=aqxFC70wyM0&t=241s
https://www.youtube.com/watch?v=qj6QXTPi7u8
https://www.youtube.com/watch?v=O_IvGiKePAc
People who detour at a dead end take a detour in a direction they understand.
https://www.youtube.com/watch?v=qTp_nYQ0CRs
Алекс ЛАСТ
Очередная ... разводиловка. Нужна повторяемая схема+описание наладки. Иначе все это прямо можно назвать очередным фейком.
Алекс ЛАСТ
@Edward Lee  ну так объясни теоретическую часть то. Будем делать. Этих "Капанадзе" тысячи. Реально повторимых нет. Да и большинство - откровенные фейки. Откуда профит ? Кпд выше 100% не бывает в закрытой системе. Значит надо тянуть откуда-то. Земля тут точно не при чем. Откуда дровишки то ?
Ruslan K
Мозгами поработать не пробовали ?
Алекс ЛАСТ
@Ruslan K  пробовали. Много раз. Выхлопа нет. Зато куча таинственных видосиков, по итогу в большинстве оказывающимися фейками.
Алекс ЛАСТ
@chiksat1  смешно. У меня просто между нулем и землей 25 вольт "свободной энергии". Без диодов и неонок.
Леонид Новиков
@Edward Lee  но а почему и нет не всеже  думают как вы
N20BlackWolf
@Алекс ЛАСТ  - ну дать схему  а вы не сделаете..я примерно знаю какая тут схема..
Алекс ЛАСТ
@N20BlackWolf  главное чтобы дали. А мы попробуем собрать.
N20BlackWolf
@Алекс ЛАСТ  почту можно?
Vladimir Tag
@N20BlackWolf  Тут дело не в схеме, а в настройке.
Алекс ЛАСТ
@Vladimir Tag  вопрос в теории. Без теории физика превращается в магию.
N20BlackWolf
@Vladimir Tag  настройку тебе никто не расскажет. Сергей А. давал схему но ее все проигнорили! Тут подобная же схема...
Ruslan K
@Алекс ЛАСТ  Понимаешь, надо немного выйти из классики и задуматься что такое электричество. Я сам  сперва не поверил когда увидел подобные фокусы. Теперь точно скажу - ЭТО РАБОТАЕТ !   Просто наверное я сам связан с эфиром . Потому знаю много об этом. И что самое главное, не доверяю физике. Враньё , подкреплённое формулами !
Алекс ЛАСТ
@Ruslan K  я догадываюсь, что можно поиграться с процессом "конденсации". Но вот куда копать ...
Ruslan K
@Алекс ЛАСТ   Копать в направлении заряженных частиц и их резонанса. То что на видео , Эдуард делает вакуум при помощи ВЧ двух качеров . Как там работают они , это становиться ясно по нагрузке. Она к сожалению слабовата .  Но что многие не понимают ?! Так это то что заряженная частица вездесущая и она может проникать через всё и накапливаться везде в виде энергии например на диэлектриках или двигаться по проводнику. Я не называю это электронами, так как это не электроны. Кто знает что такое электрон , читал сперва классику, а потом квантовую физику...Понимает что это путаница мозгов . От того и категорически не хочу так называть частицы из которых и состоит электрический ток. Теперь ближе к делу... Оба качера работают возможно и на близкой частоте или одинаковой,но явно не синхронно . Что и вызывает интерференцию между ними , а соответственно и сам вакуум. Вот именно это и добавляет в систему энергию . Так как вакуум при нарушении оного заполняется тут же заряженной частицей и соответственно увлекается магнитным полем в катушку . Энергия растёт в разы ,не затрачивая при этом ресурсов на получения процессов. Как например при обычном вращении магнита вокруг катушки или на оборот .  Нужно просто понять то , что классическая физика путает мозги человека . Электричество в генераторе  обычном не берётся тем способом что рассказывает нам физика. А совершенно иначе !  так же как и гроза возникает не при трении каких то льдинок или хрен там чего, а при резонансе заряженных частиц которые вокруг нас. Образуется воронка из-за разности двух потоков воздуха. Холодный идёт вниз, тёплый вверх . Вихрь крутит окружающую среду и частицы которые в этот момент под воздействием магнитного поля земли входят в резонанс и их энергия умножается. Далее вся эта энергия ищет куда ей уйти . Вот вам и молния !  Два вихря рядом - горизонтальный пробой  , один большой вихрь - бьёт в землю ! это изучал Тесла прежде чем создать генераторы переменного тока и радио !!!  Теперь идём дальше . Энергия в генераторе так же как и в грозе берётся не из свободных электронов , а заряженных частиц . Проводник(от слова проводить) является проводящим звеном энергии , втянутой при помощи вращающего магнитного поля и выпускающий в нагрузку уже результат . Кстати , образующая в этот момент обратная ЭДС будет ниже ,но от куда она взялась ? От туда же ! От куда и прямая ЭДС . Это вам подсказка,где копать
Алекс ЛАСТ
@Ruslan K  Прикольно, но, к сожалению, не понятно. "Эдуард делает вакуум при помощи ВЧ двух качеров" - объясните физику процесса. Можно на базе гидравлики. Её видно, и принципы очень даже схожи. Про заряженные частицы я понимаю. Воздух - диэлектрик. И как и в конденсаторе, заряд находится в диэлектрике. Интерференция - не равно вакуум. Чтобы вакуум образовался, надо слить энергию из некоего объема пространства. А гроза, это пробой диэлектрика из-за того, что диэлектрик резко меняет свои характеристики. Из-за пыли и воды резко падает сопротивление, и получается пробой диэлектрика. Резонанса я тут в упор не вижу. Тесла же скорее формировал ионизированный псевдо-проводник с регулируемыми характеристиками. По принципу того, как японцы разряжают грозовой фронт. Рентген-лазер, и импульс в небо. И бъет молния в специальные решетки - приемники, на заземление. Хорошо бы это искричество использовать, но управлять такими параметрами тока/напряжения пока не научились. Да и запасти разом такой объем энергии пока некуда. Так что опять - не понятно куда копать то ??? Я понимаю, что классическая физика путает мозги человека. Ну так давайте обсуждать другую, а не говорить, что все тупые, а одни вы - гении, с некоей магией.
Vladimir Tag
@Ruslan K  Руслан, ждем ваших видео))) Без скрытых коробочек.
Ruslan K
@Vladimir Tag   Никогда и никаких скрытых коробочек у меня не было.
Ruslan K
@Алекс ЛАСТ  Вот вы меня не услышали по поводу грозы. И потому все остальные обсуждения бессмысленны !   Потому что именно так всё и есть. Резонанс частиц вы не усмотрели в моих объяснениях . Про теслу и ионизацию  я вообще молчу. Очередная классика пошла . Что и тормозит всех ! Повторюсь ещё раз - все эти объяснения противоречат друг другу в разных науках. И это уже тревожит !  А что касается мною написанного , то я это проверял экспериментально и после чего делал выводы. Я занимаюсь каждый день этим на протяжении 8-и лет . Поэтому считаю себя специалистом в этом. Так как каждый эффект я исследовал заново без обращения к классике и квантовой физике. Ибо эти науки противоречат друг другу. Не хотите читать что я написал - Разговор окончен. Но сразу скажу что просто это не будет. Хотя просто всё выглядит. И да...Насчёт вакуума.... Интерференция может создавать вакуум легко !  Надо просто понимать как это работает.
Vladimir Tag
@Ruslan K  Руслан, к тебе такой вопрос. Что ты имеешь ввиду под словом, (резонанс частиц)? И как ты определяешь что образовался вакуум вокруг установки?
Алекс ЛАСТ
@Ruslan K  ну так объясните понятно. Что за эффекты, какие закономерности. Фраза - вы меня не поняли, разговор окончен это вообще супер. Расскажите принцип - откуда вдруг вакуум при интерференции.
Ruslan K
@Алекс ЛАСТ   Вот именно это и есть причина, по которой я не рассказываю ничего. Это всё достигалось путём экспериментов и траты времени длинной в 8 лет !!!  Не хочу заниматься бесплатным обучением. Намёк дал, куда копать -рассказал. Не поняли ?!  Извините ребята.... Ничего личного. Просто работайте и фиксируйте каждый этап. Не ленитесь. Мне легче было разобраться. Так как большую часть жизни я занимаюсь радиовещанием . От туда пришли многие понимания.
Ruslan K
@Ruslan Shakhov  А ты разобрался ? Думаю что нет !
Ruslan K
@Edward Lee  Вот кстати правильно вы сказали сейчас. Но теперь по теме. А почему вы не захотели использовать один качер - Теслу ? Ведь для создания того же эффекта вполне пригоден один качер-Тесла. нужно просто отвязать по питанию фильтрами и сделать как у Васи , типа автогенератор. Как раз получается в противофазе . И стабильность сразу выше . П.с. Мой скайп есть у Вас. звоните . Поделюсь опытом в настройке.
Vladimir Tag
@Ruslan K  Руслан, просто сказано, но на деле.... Но и принцип настройки будет другой. Руслан, ты меня не узнал?
Ruslan K
@Алекс ЛАСТ   Земля тут причём ещё как...Точнее опора или другими словами конденсатор. Энергия из среды. Точно так же как гроза и всё остальное. Вы же не слушаете что я говорю !
Ruslan K
@Ruslan Shakhov  Что пройдено ? А воз и ныне там !  судя по комментариям могу сразу сказать что никто из вас не знает как это работает. В этом и прикол !
Ruslan K
@Vladimir Tag   Принцип настройки ? По сути всё очень просто,но надо понимать от куда энергия. Это и есть ваша проблема.
Алекс ЛАСТ
@Ruslan K  да слушаю я. Сложно  услышать, когда в ответ с гордым видом молчат. Расскажи так, чтобы даже тупой понял.
Ruslan K
@Алекс ЛАСТ  Ещё по поводу КПД и 100% - Согласен полностью !  КПД тут не причём и вообще сама установка имеет низкий КПД даже по сравнению с солнечной батареей . Увы,но это так ...!   Есть куча недостатков и когда люди поймут что это всё не на долго , прекратят споры и весь этот срач в целом. Эксперимент интересный, не спорю. Но !  довольно затратный и не долговечен.
Vladimir Tag
@Ruslan K  Я знаю откуда энергия. То что ты описываешь, если я тебя правильно тебя понял, это дисбаланс электронов между положительной и землёй.
Edward Lee
@Ruslan K  Да я вроде как настроил))) Скайпом уже не пользуюсь , есть телега.
Edward Lee
@Ruslan K  Насчет КПД не согласен. Насчет недостатков есть такое.
Edward Lee
@Алекс ЛАСТ  Теория... Это так сложно. Я не могу это обьяснить. Можно долго разглагольствовать по этому поводу, но так и не обьяснить.
Andrei Shadyn
@Алекс ЛАСТ  1) кпд там ни к черту, если иметь в виду именно кпд ))   2) система открытая    3) без земли не арбайтн.   4) дровишки из леса ))
Алекс ЛАСТ
@Edward Lee  тогда остается повторяемость.
Ruslan K
@Vladimir Tag  Электроны тут не причём вообще !
color
Even worshipers worship without knowing the identity of the god they believe in.
Is it similar to the generator of Kapanadze, Akura, and Ruslan?
Is it wrong for those who fight while worshiping the same dark god, or is it the fault of their ancestors who taught them to worship the dark god?
Cyprus lies down, but the commander-in-chief Apep Snake, born 7 days old, pretends to be standing.
For the sky god and the earth god to bow down to the Apep serpent pretending to be standing was only the intention of the ruler who made it, and it is neither the fault of the earth nor the fault of the heavens.
Even the dark-skinned descendants of Ham do not want to worship the Dark God.
Because they want light too.
Gone are the days when ignorant and good citizens were forced to believe in a god created by greedy and ignorant rulers.
Whether you worship it or not, it is your choice, as always.
Neither Gabriel's camp nor Michael's camp would like to be involved in a battle instigated by the Dark Gods.
The role of the Dark God, rest and death are sufficient.
When the darkness of the night fights, the lights only have to watch.
If the darkness wants to be respected by the light, it can either live as a shadow by tradition or quietly disappear with the sun of tomorrow.
