Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Joshua of the Old Testament, the origin of the name of Jesus, is from the Philistines because he plays the role of a dancer next to Djed above.
Floor
③ For information-gathering questions, it is often difficult to expect high-quality answers.
④ I'm not looking for any kind of reward.
⑤ I think it's just a question that can be answered.
⑥ The only problem for observers like us is the pitiful sympathetic interference.
⑦ If, like us, you were thinking of getting answers from observers, a little bit of information is all you need.
⑧ The schematics created by the Russian far-right head are uselessly complex.
⑨ Experiment until Ruslan reveals the generator secret.
⑩ Wouldn't it be that if we or someone continued to put pressure on him, he might get some sympathy that he could reluctantly reveal?
Now Moses was pasturing the flock of Jethro his father-in-law, the priest of Midian; and he led the flock to the west side of the wilderness and came to Horeb, the mountain of God.
The angel of the LORD appeared to him in a blazing fire from the midst of a bush; and he looked, and behold, the bush was burning with fire, yet the bush was not consumed.
So Moses said, "I must turn aside now and see this marvelous sight, why the bush is not burned up."
When the LORD saw that he turned aside to look, God called to him from the midst of the bush and said, "Moses, Moses!" And he said, "Here I am."
Then He said, "Do not come near here; remove your sandals from your feet, for the place on which you are standing is holy ground."
The Saudi Arabian Peninsula, which serves as the sole foot of the 4th floor Djed, is Moses' shoes. When Moses took off his shoes, Moses' body was divided into four and moved to the Temple of the Sun in Djed on the first floor.
The bush is the sun temple headjet, which is why Moses is separated into 4 Djeds on the first floor and is parasitic in the sun temple.
color
But things get worse when the Jews who follow Moses covet the Great Wall of China, the body of Moses' four split Djed
color
Hints are everywhere, but no one jumps off the cliff.
Even those who made the generator do not know how the 2KW-generator that Ruslan made was manufactured.
color
https://realstrannik.com/forum/ustanovka-kulabukhova/178-analiz-kachera?start=54#7168
The circuit diagram of TOPRusran7 in Ruslan started from this cafe.
Although it's short at 19 pages, it has a lot of useful information.
And no more kacher makes sense.
It is now more likely that you will be successful if you step away from the kacher and focus on the generator structure.
In the case of a 24V 6A PSU, the circuit breaker operates at about 5A and the PSU stops working.
The advantage of being powered by a battery is that you can get frequencies beyond the limits that 24V 6A PSUs cannot provide.
This doesn't make sense unless you experiment with batteries.
And if you're lucky, you might even get a decisive hint.
Problems arise when you touch and handle them yourself, and there are also efforts to solve them.
Without this, even hundreds of years of experimentation would have no results.
The role of the kacher is pumping, nothing else makes sense.
The kacher does not work with the grenade by creating a special frequency, but rather as an electric vacuum, an imbalanced charge generator to draw the earth's charge.
So that's what Ruslan said about the kacher, all you have to do is work.
A closed electrical device draws the necessary charge from the atmosphere or the ground to compensate for the imbalance in the preceding paragraph.
Like the negative and positive poles of a magnet.
So the Ruslan generator no longer has a special power generation principle.
Ruslan adds one more thing to this, as he says, in a way that is difficult to understand with conventional electrical formulas.
This is a problem that my father, a few years ago, also pondered for a long time.
And this is not a surface wave that anyone claims, but a movement of electric charge based on the simple lightning principle.
color
