Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
The value thinking of intellect and reason is only one way in which a particular creature perceives light, not of the light (the other) nor of the dark (the other).
Evgray VS Prométhélios
https://www.youtube.com/watch?v=-GRPSS8n7wQ
Like Moses with the serpent in the wilderness, Djed has the power to move Apep. So Apep (spear) is passive.
Those who look at Apep are the Septuagint writers, and the purpose is to point out the Septuagint authors.
The reason why a Roman soldier pierced Jesus in the side with an Apep-spear was because Paul made Abba (Apep)-Father and his adopted son-Roman relationship as mentioned in Romans.
There is no particular reason why Rome, which uses the Julian solar calendar, should point at the moon, but Pharaoh-Paul did not leave Rome as an Egyptian invader. He loved his enemies like Paul. Apep's love is dark love. It drags everything that approaches Apep into the darkness. So whoever loves Apep loves death. The suicide of Judas Iscariot is a prime example.
The problem of choice and coercion is only a modern ideal, and everything is a continuation of the past.
The bizarre utopia that loves death and resurrection together is not a special value, it is just a reckless mental illness that has lasted for thousands of years.
Because some rulers have fostered such a religion, their sins are great.
https://prd-cam-website-statics.s3.eu-west-1.amazonaws.com/content/uploads/2018/09/giphy-1.gif
Weak human body is difficult to adapt to the space environment. Placenta of astronauts suffer from disease shortly after space travel. After a week, she catches a cold and complains of arthritis.
The universe is the environment in which humans can have a special body.
In the distant future, whatever body a human being will have, it will be the will to survive.
Some of you have the real special key of the will to survive, but you only use it for the desires of your feeble flesh.
While he loves light, he presents the darkness of silence to others.
Whether he loves the Light God or the Dark God, it is only darkness to others.
If he loves light, he must do the work of light.
He is not only for himself, but also for others.
I hope he wakes up.
지성과 이성이라는 가치 사유는 특정한 생물이 빛을 인식하는 하나의 방식일 뿐이지 빛(他者, the other)의 생각도 아니고 어둠(他者, the other)의 생각도 아닙니다.
광야에서 뱀을 든 모세처럼, 아펩을 움직이는 힘은 Djed에게 있습니다. 그래서 아펩(창)은 수동적인 입장입니다.
아펩를 바라보는 자들은 72인역 저자들이니, 72인역 저자들을 지목하기 위한 목적입니다.
로마 군병이 아펩-창으로 예수 옆구리를 찌른 것은, 바울이 로마서에서 언급한대로 Abba(Apep)-Father과 양아들-로마 관계로 만들었기 때문입니다.
율리우스 태양달력 사용하는 로마가 달에게 삿대질 할 특별한 이유는 없지만, 이집트 침략자로서 로마를 파라오-바울이 그냥 놔두지 않았습니다. 원수를 바울식으로 사랑한 겁니다. 아펩의 사랑은 어둠의 사랑입니다. 아펩에게 다가가는 모든 것을 어둠속으로 끌어갑니다. 그래서 아펩을 사랑하는 자는 죽음을 사랑합니다. 가룟유다의 자살이 그 대표적이죠.
선택과 강압의 문제는 현대의 이상일 뿐 모든 것은 과거사의 지속입니다.
죽음과 부활을 함께 사랑하는 기괴한 이상향은 그래서 특별한 가치관이 아니라 수천년 지속된 무모한 정신병일 뿐입니다.
일부 지배자들이 이런 종교를 양성했기에 그들의 죄가 큼니다.
나약한 인간의 몸은 우주 환경에 적응하기 어렵습니다. 우주 비행사들 태반이 우주여행 직후 질병에 시달립니다. 일주일 후부터 감기에 걸리고 관절염을 호소합니다.
인간이 특별한 몸을 가질 수 있는 환경이 우주입니다.
먼 훗날 인간이 어떤 몸을 갖게되든 그것은 생존 의지일 것입니다.
여러분 중 일부가 생존 의지라는 실질적인 특별한 열쇠를 가지고 있지만 나약한 육체의 욕망에만 사용합니다.
자신은 빛을 사랑하면서 타인에게는 침묵이라는 어둠을 선물합니다.
그가 빛신을 사랑하든 어둠신을 사랑하든 타인에게는 어둠일 뿐입니다.
빛을 사랑한다면 빛의 일을 해야 합니다.
자신에게 뿐만 아니라 타인에게도.
나는 그가 깨어나길 바랍니다.
color
어둠과의 싸움에게 그가 이길 것이라 믿습니다.
지금은 고개를 돌리고 있지만 빛이 된 자신의 약속을 언젠가 지킬 것이라 믿습니다.
I believe he will win the fight against darkness.
He is turning his head now, but he believes that one day he will keep his promise that has become a light.
color
Пояснение по работе Теслы (качера)
https://www.youtube.com/watch?v=NwYmLoToWzw&t=8s
Для Бровина
https://www.youtube.com/watch?v=hdZeHtmOq9g
Генератор "Две Башни" по немецкой системе Акулы
https://www.youtube.com/watch?v=zgEecYI5ZQU
Ruslan K's video was released before Ruslan X's video.
Expensive DC power supplies and cheap PSUs ($10) seem different.
Ruslan K uses 14 volts.
It didn't work on 12V, so if you used 14V
Ruslan X tested, phytonite (фитонит), which did not occur in the 24V DC power supply, occurred in the battery use.
However, if the phytonite(фитонит) occurring only in the battery is irrelevant to the working principle of the generator, you must find the generator working principle elsewhere.
41.9145khz ........... 4.19145Mha  ;D
3.19715Mhz(3.199Mhz) ........... 1.5444Mhz  ;D ;D
color
아빠, 대부가 잠깐 보제👹👺❤
The Egyptian lotus also contains some hallucinogenic narcotic properties, but it does not compare to the poppy, which was grown exclusively for royal funding by the royal families of Babylon and Assyria.
color
글구봉께 도때비 면상때기 본지도 꽤 됐네..... 와~? 건달바성 툇방에 물러앉아있으니 좀쑤신다니? ;D ;D ;D ;D ;D
