Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
r2fpl
You don't understand what I wrote. Ruslan is a liar, but I'm not saying his device isn't working. These are two different things.
I don't have to write anything but you don't have the keys here so for now please respect what they have to say otherwise he will write here himself.
There is no one here for a long time who does experiments because no one likes what he sees.
This forum is not bad there are only a few people like AG who don't like truth or honesty.
By the way: if you say the device is not fake you say it is real. On what basis are you saying this?
color
r2fpl:
Like Wesley, r2fpl deletes his own question and repeats it afterward.
So from now on, I leave the evidence.
You don't have to come here.
Go to your forum and write what you like.
stivep
Quote from: color on June 23, 2021, 12:22:52 PM
You don't need to come here if you don't believe in Ruslan generators.
No need to come here and kindly report that the Ruslan Generator is fake.
For physics god doesn't exist and it doesn't recognize  believes in anything but facts.
For Darwin, dear  color you are  just an Asian Animal, so is me too but I'm  not Asian.
Our American  law  is  respecting  everyone believes.. and I do too.
Ruslan generator  needs to be understood , rejected as concept  or  approved ,
but that has nothing to do with believes.
Feel free and believe in anything you want.. none of my business nor I care  about it.
r2fpl  has his own rights to  deny any of your comment, statement and so on.
Wesley
color
stivep:
A real American citizen does not emphasize that he or she is a real American when he calls 911.
Tesla, more power, better ground (2)
https://www.youtube.com/watch?v=ZccrLKY_k6c
Пояснение по работе предыдущего генератора СЕ
https://www.youtube.com/watch?v=d_IDicPswgw&t=43s
Powered by 9V battery, the generator kacher voltage is 966-1147VAC.
It will not exceed the above voltage even with 12V battery.
Running on a 24V battery, the voltage on the kacher will be around 2000V.
The kacher voltage does not need to be high,
This is because the kacher voltage must pass through the filament of the light bulb.
High kacher voltages cause interfering short circuits between generator components.
The switch, which is a disconnect device, does not work.
The reason Ruslan installed two relays in the kacher circuit is because of phytonite.
This is why Ruslan said in the initial video that he didn't know how to shut off a running generator.
High voltage can cause a lot of problems.
So my dad also wound about 12cm of 0.8mm coil on 45mm PVC pipe.
The output voltage from the 9cm yoke-transformer is about 75V (3A).
The first kacher is activated, and a voltage is required to activate the relay.
The grenade coil provides the voltage to trigger the relay for 220v.
If you don't have a grenade coil, you'll have to find another way.
And not with a kacher potentiometer, but with a push-pull circuit potentiometer.
With this, the kacher is complete.
No need to worry about kacher anymore.
Now we enter the generator structure.
The key is how and where to draw the output of the grenade coil.
How to connect the extracted output to the PSU is also more challenging.
If the power output from the diode bridge is directly connected to the AC-operated PSU,
https://www.youtube.com/watch?v=0TOVIMn-ubs
9 minutes 48 seconds.
https://www.youtube.com/watch?v=Aex2_M-lOeA&t=901s
Like a coffee pot, the PSU explodes.
So special safeguards are required.
I'm not going to tell you what safeguards are needed.
There are many ways.
This is the place to open the brains of our members.
The Shark/Ruslan generator must be tested with the kacher-grenade coil-PSU all connected.
If you exclude even one of these, the generator will not work.
Connecting only the kacher-grenade coil and powering it from a DC power supply or battery will not cause the generator to work.
If you think it will work here, you are mistaken.
Because even if you experiment a hundred years from now, there will be no results.
Be sure to run the experiment with all the kacher-grenade coil-PSU connected.
So I'm saying that the secret to how the generator works is where the grenade coil and PSU connect.
r2fpl
