Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
When the kacher was not working, the grenade coil voltage was around 75VDC.
Activate the kacher and the grenade coil voltage is about 100VDC.
If I run the kacher and turn on a 30W light on the diode bridge, the voltage comes out to about 81V.
The output voltage can be raised further by about 10V by adjusting the potentiometer.
All voltages were measured across diode bridges.
These are all pure measurements with no diode bridge and no PSU connected.
But even in this state,
The digital tester cannot measure itself due to the influence of kacher high voltage. Digital numbers dance like crazy.
500W X 4 light voltages vary from 21 to 50V.
In this case, measurement was performed with a digital tester because it was impossible to measure with an analog tester-device due to the wiring structure.
Эффект Тесла толкает ток
https://www.youtube.com/watch?v=LGvNv2EXKkU
A member of zlatko2013 is experimenting with a light of 300W X 4, but I am not sure how many volts come out by running only an ammeter measurement, but if I guess from the brightness of the light and my dad's experimental data, it will be about 40V.
zlatko2013 members are also members who understand that it is difficult to measure the output voltage in a normal way.
The zlatko2013 member used battery power, and my dad used a regular 220V power PSU.
color
https://strannik-2.ru/index.php/forum/t-kapanazde/514-generatory-tarielya-kapanadze-obshchaya-tema-2?start=4455
just bragging about the oscilloscope, not being able to get the same results as my dad with the generator someone is experimenting with.
It's never too late to create results and show off your oscilloscope.
What will happen in a cafe where they gather only to derive meaningless experimental results, to organize electronic terms they do not know well, and to show off their knowledge as thick as a sheet of writing paper?
If you cheated for 10 years, that's it.
Let go of regret.
color
"While in bed on Winter Solstice evening I had a download for a "free energy" device, that I call the Light Transformer!"
The extraterestrials should have sent you a money producing idea first. Begging for donations is not very original.
You mentioned the bed, so I donate it.
Genesis 28 [NASB]
Then Jacob departed from Beersheba and went toward Haran.
He came to a certain place and spent the night there, because the sun had set; and he took one of the stones of the place and put it under his head, and lay down in that place.
He had a dream, and behold, a ladder was set on the earth with its top reaching to heaven; and behold, the angels of God were ascending and descending on it.
And behold, the LORD stood above it and said, "I am the LORD, the God of your father Abraham and the God of Isaac; the land on which you lie, I will give it to you and to your descendants.
"Your descendants will also be like the dust of the earth, and you will spread out to the west and to the east and to the north and to the south; and in you and in your descendants shall all the families of the earth be blessed.
"Behold, I am with you and will keep you wherever you go, and will bring you back to this land; for I will not leave you until I have done what I have promised you."
Then Jacob awoke from his sleep and said, "Surely the LORD is in this place, and I did not know it."
He was afraid and said, "How awesome is this place! This is none other than the house of God, and this is the gate of heaven."
So Jacob rose early in the morning, and took the stone that he had put under his head and set it up as a pillar and poured oil on its top.
He called the name of that place Bethel; however, previously the name of the city had been Luz.
Luke 5 [NASB]
One day He was teaching; and there were some Pharisees and teachers of the law sitting there, who had come from every village of Galilee and Judea and from Jerusalem; and the power of the Lord was present for Him to perform healing.
And some men were carrying on a bed a man who was paralyzed; and they were trying to bring him in and to set him down in front of Him.
But not finding any way to bring him in because of the crowd, they went up on the roof and let him down through the tiles with his stretcher, into the middle of the crowd, in front of Jesus.
Seeing their faith, He said, "Friend, your sins are forgiven you."
The scribes and the Pharisees began to reason, saying, "Who is this man who speaks blasphemies? Who can forgive sins, but God alone?"
But Jesus, aware of their reasonings, answered and said to them, "Why are you reasoning in your hearts?
"Which is easier, to say, 'Your sins have been forgiven you,' or to say, 'Get up and walk'?
"But, so that you may know that the Son of Man has authority on earth to forgive sins,"--He said to the paralytic--"I say to you, get up, and pick up your stretcher and go home."
Immediately he got up before them, and picked up what he had been lying on, and went home glorifying God.
They were all struck with astonishment and began glorifying God; and they were filled with fear, saying, "We have seen remarkable things today."
In this situation, Djed and the Apep snake are one body.
However, as the paralyzed man gets up and carries his bed, the standing Apep snake and Djed are mixed.
This is possible because the sun can overcome the darkness of the dark night.
Modern Christians imitate the force of gravity in nature to heal diseases.
These are funny incidents that occurred when Christians imitated the humanism-Jesus created by the Roman Christian priests.
God said to Moses, "I AM WHO I AM"; and He said, "Thus you shall say to the sons of Israel, 'I AM has sent me to you.'" [NASB]
Darkness exists by itself when light is absent.
The reason Jehovah revealed his identity to Moses was because Djed had the power to summon darkness.
So, to ask if Djed could be a Creator, neither light nor darkness yielded the place of Creator to Djed.
This is a question that modern people will approach with science, not a question of religion or mythology.
Darkness donates darkness, and light donates light.
So do you teach others to give their pride?
color
Karpanadze 5KW
https://www.youtube.com/watch?v=2oGHuHy-xEc&t=634s
Ruslan 2KW
https://www.youtube.com/watch?v=6jZ5How6G8Q
Karpanadze the two circuit diagrams below.
The huge diode bridge that Karpanadze uses is for output.
So the electricity flowing through the grenade-coil is also DC.
But there is AC in Ruslan's grenade coil.
The output of Ruslan's 2KW generator is on a diode bridge.
Same as Karpanadze and generator.
-203VDC ........ 203VDC
Where did the research of these cafe members go wrong?
color
너무 많이 얘기해주는거 아녀?! ㅋㅋㅋㅋㅋ ;D ;D ;D ;D ;D
