Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 18 Guests are viewing this topic.
color
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/msg555098/#msg555098
https://www.youtube.com/watch?v=hDXEC6GeGA0
https://www.youtube.com/watch?v=C0R4Pinl5rE
don't know why those involved in the Lithuanian OU experiment give value to their own strange experiment.
https://www.youtube.com/watch?v=Mn8TLBsR3r0
The above experiment is simple,
https://en.wikipedia.org/wiki/Townsend_discharge
It is just an experiment on the avalanche effect known as Townsend discharge.
Townsend discharge appears in an experiment using spark gaps.
It's true that a high voltage Tesla produces an avalanche effect,
Townsend discharge is not related to the Kappanadze/Acura/Ruslan generator principle.
It does not mean that it is completely irrelevant, but that it has nothing to do with Townsend discharge and the principle of development.
https://www.youtube.com/watch?v=5nxKqfkkndw
The spark gap shown in the video above is not a spark gap for Townsend discharge, but a basic spark gap for Tesla high voltage to work.
In order to activate the earth-ground with a high voltage like lightning, a transformer of a flyback structure must basically have a spark gap.
This is not a spark gap that causes an avalanche effect, it is simply a spark gap for high voltages.
https://www.youtube.com/watch?v=BQuOBBj8D_o&t=331s
Charge unbalanced lightning has a high unbalanced amperage by itself.
Charge imbalanced lightning produces a more transcendentally balanced amperage only when negative and positive charges meet.
It is correct to say that this is a short circuit-spark.
That's why the Kappanadze/Acura/Ruslan generator principle is called the lightning-discharge principle.
so,
The Lithuanian OU experiment is independent of the Kappanadze/Acura/Ruslan generator principle.
The Kacher schematic below is a Tesla that is not directly related to Townsend discharge.
The Kacher role is all about activating the earth-ground and drawing electric charges into the generator.
I would like to ask the Lithuanian OU experimenters.
https://www.youtube.com/watch?v=u3LhwQI6ABw
Do you think my dad's experiment in the video above is Townsend discharge?
It seems that 'It's' cafe members have already completed and tested it.
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.msg93587#msg93587
That's probably why Ruslan chose conductors with thick kacher sheaths.
It really maximizes the fire hazard.
All shards will burn out.
So my dad felt the need to slightly change the strength of the kacher, so he changed it.
But don't change it.
The reason will be explained later.
Are Nick's beloved Geo's experiments still a long way off?
color
카페가 적막강산이야....... ;D ;D
Передача электроэнергии 20кВт по одному проводу толщиной 8 микрон
https://www.youtube.com/watch?v=qO2cIV2wu-0
https://www.youtube.com/watch?v=aOJ12mYpro8
Kapanadze, Akura, Ruslan ::)
To pay tribute to the members of this cafe who, like the three apep-snakes, do not want to admit they are scammers. ::)
Whether it's a regret for the past 10 years, a stubborn obsession, or a mental problem, ::)
Just like fans of Jehovah and Moses hoping for a miracle from a total output 120W generator (24V, 6.3A, PSU), 8)
Fishing so that my daughter will not let go of the string of hope. ;D ;D 8)
color
When electrons escape from a substance, heat is generated.
The departure of electrons from matter is similar to nuclear fission.
The electrons generate more heat on the side where they are absorbed than at the side where they escape.
This is why the positive terminal of the battery is thicker than the negative terminal.
Lightning is the rapid movement of electrons between water molecules in the atmosphere, resulting in heat and light.
Kacher's high voltage creates only negative electrons in the coil.
When the positive charge of the earth-ground meets the high voltage negative electrons in the coil, light and heat are produced.
When the amount of current is high, energy is generated even when positive and negative charges meet, but when the amount of current is small, a resistor is required where the positive and negative charges meet.
The filament acts as a resistor.
color
Karpanadze basically uses an inverter of 220V-400W (about 3A).
For the generator to work, all that remains is to maximize the negative charge and draw the positive charge from the earth-ground.
The technology of combining the Tesla coil and radiant energy as we know it is to place an electric light in the place where the Tesla coil and the Earth-Earth ground are connected,
https://www.youtube.com/watch?v=YsGwdPqCpX0
It is common to place a metal that absorbs negatively charged particles around a tesla coil or kacher coil and connect it to a light fixture.
https://www.youtube.com/c/OkkiMoeljadi/videos
2017. 5. 4
4x Slayer Exciter - 230 V Lightbulb Test
https://www.youtube.com/watch?v=fSHtMmNf1yk
2017. 5. 7
Electro Radiant Energy - Ultimate Receiver Test
https://www.youtube.com/watch?v=Yhl5kc7ddck&t=7s
2017. 5. 7
Electro Radiant Energy - Soft Plasma Effect
https://www.youtube.com/watch?v=nd6MozD2FDA
2017. 5. 16
Electro Radiant Energy - Dual Layer Receiver Test
https://www.youtube.com/watch?v=Il0YtijAyi0
2017. 6. 20
Electro Radiant Energy - Copper Pipe Receiver Test
https://www.youtube.com/watch?v=sRxwj_Idsoc&t=328s
2017. 11. 22
Electro Radiant Energy - Grounding Effect
https://www.youtube.com/watch?v=rdPDRR2J4Xo&t=3s
2018. 2. 4
Simple Cold Electricity - Battery Current Measurement
https://www.youtube.com/watch?v=_L--KkMFh7Y&t=2s
So the generators of Karpanadze, Akura and Ruslan were also directly connected to the Tesla (kacher) secondary coil.
How to connect this is a difficult yet easy way.
If so, you might ask, what is the difference between the same method used by Ingener99?
The method Ruslan introduced us to is the same method that Ingener99 provided.
Did Karpanadze and Akura use the same method?
no.
Ingener99 connected the light to point Ⓐ, but Karpanadze and Akura connected the light to point Ⓑ.
What is the difference between Ⓐ and Ⓑ?
In a typical Tesla coil, Ⓐ and Ⓑ are connected to each other, so there is no voltage difference.
However, the difference in radiant energy emitting negatively charged particles is large.
In Ⓐ, little radiant energy is generated, but in Ⓑ, a lot of radiant energy is emitted.
So, I connected the secondary coil of the transformer to Ⓑ of Karpanadze and Akurado.
By the way, Ruslan has released a schematic of the generator connected to point Ⓐ.
https://www.youtube.com/watch?v=PHm3OLHBxX0&t=549s
I color it there with a pink pen and kindly explain it.
Of course, it is not a circuit diagram drawn by Ruslan, but a video has been released that connects point Ⓐ and earth-ground.
So my dad also made an experiment by making a Tesla secondary coil that is independent of the circuit and not the kacher.
The problem is that the tesla-coil doesn't match the generator's working principle.
The thing is that the generator reacted only to the kacher-coil.
My dad did a lot of experiments to figure out the cause,
The tesla or kacher's secondary coil must be connected to the circuit for generator resonance to work.
My dad doesn't know the cause either.
This is a problem for members with oscilloscopes and good equipment to figure out.
That's why my dad presented the TL494-74HC00-TC4420-2sk2611 schematic completion game to the members.
At the 'It's' cafe, 'It's' is experimenting with the independent Tesla secondary coil, so we expect the results to come out soon.
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.1525
My dad failed because of his lack of skills, but I expect 'It's' to succeed.
If 'It's' succeeds, it proves that Ruslan's schematic is correct.
The Ruslan generator also cheats that the secondary coil of the transformer is connected to point Ⓑ but connected to point Ⓐ.
Ruslan also shows a screen that seems to hint at this in an early video, but shows a duality in words and actions.
The only way to find out what conspiracy lies inside the 45mm PVC pipe that Akura and Ruslan hide is for members to experiment and prove.
https://www.youtube.com/watch?v=LjVPSDrnP-Y&t=17s
There are many open-minded members who love electricity.
Cheering from afar.
color
https://www.youtube.com/watch?v=cNFImcWPK7s
Akura is evil.
https://www.youtube.com/watch?v=Sb1ArA10SKE
kacher coil 9 cm.
https://www.youtube.com/watch?v=PMtKcCSOFVc&t=62s
Akura's grenade coil and 45mm PVC pipe
https://www.youtube.com/watch?v=qqECT3g5V1o
Ruslan's Grenade Coil and 45mm PVC Pipe
https://www.youtube.com/watch?v=Sb1ArA10SKE&t=1s
The kacher coil wound tape has a rough surface.
It means that some evil conspiracy is lurking in the thick coil.
