Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 28 Guests are viewing this topic.
color
color
One thing which was discussed already, just want to remind about it.
Tesla coil pulses need to be unipolar, antenna coil should be positively charged.
(Supposingly) easy way to achieve this is to add diode.
This is a key to working device, so it is very rarely mentioned.
Attaching two variants which seems reasonable for me, but experiment will show...
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.msg93879#msg93879
The cathode of the diode bridge can transmit the electricity output from the yoke-transformer not only to the cathode but also to the anode,
The positive pole of the diode bridge does not pass the electricity output from the yoke-transformer to the negative pole.
The charges and electrons drawn from the ground copper wire are negatively charged.
AlienGrey
https://www.youtube.com/watch?v=6oo_WOKJNTM
Hoppy master of intrigue I have a problem for you an electron beam travels from a cathode to a display screen with a positively charged final anode, western science says right or no tv display! have you got that ?
Now if the earth is negative and the sky is positive then how come lightning travels down to earth or should I say we are told it travels down ?
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg478364/#msg478364
GeoFusion
Hi Guyz :)
Well I would want to say something.
We could all start on the 37.5 meters of grenade wires or 40 meters long wires. does not matter.
But only If you want to drive it on another freq.
It will all vary to other resonant frequency ranges.
when that is done.
make sure to find the Resonant frequencies of series resonance with cap part on yoke to bifilar on grenade
and add tesla coil pulses to see gain.
In between all of this, the MOST IMPORTANT.
You need to see Synchronization & effect befor even removing wires to adjust freq and more.
no matter if the tuning is not prefect yet, this one of the first steps in my experience!
If you don't see this, then there is something wrong with circuits or some connection missing.
you will need to see a small or big gain on the load ( small bulb at output part )
when kacher is connected with pushpull in synch.
I have let some buddies make nice PCB's of the kacher and Pushpull. They work individually great.
They are not working the same as my old kacher circuit nor pushpull for achieving effect.
It does not give effect, so the slightest change in circuit connection can make differences.
It will go under investigation to see where it does not.
SWR (Spin Wave Resonance)
is what is happening here as what T-1000 has said many times
And Tesla coil or HV coil to pulse is for the acceleration.
Check this out
some guy replicated synchronization and effect, simple.
https://www.youtube.com/watch?v=ivWeWzkoPI0
Cheerz! ;)
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg487699/#msg487699
I am sure roma used interrupter on his simple kacher on his way. just a added transistor to the circuit board.
The collapsing field is where we need to focus on when driving tesla,
It brings that ambient Ion energy to the coils and what we know already to do is mixing them.
Arunas gave a good example on what has to be done to get the maximum on peaks and continue.
In my own way, the mediator core is vibrating and doing something similar but unstable.
I self will be testing how Akula does it with interrupter to see any differences.
yes it's all about ionizing there air
This device needs to work like a Vacuum of Ions.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg494760/#msg494760
Well, I have a file below which will have HD pictures and could Zoom In to see the device of Adrian
very up close and see that there is one more element onboard the kacher.
He does Have an PWM board it's underneath the wooden board where Pushpul yoke is connected.
My last diagram.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg495071/#msg495071
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg493886/#msg493886
Geofusion's Ruslan Device 1 " Resonance Test success "
https://www.youtube.com/watch?v=SdYGq_jhmeg
Here, Geo is experimenting with generators of a very universal structure.
The kacher secondary coils are also of the right size and of the right size with the yoke-transformer windings.
Time passes, but the old man does not wait.
r2fpl
Quote from: color on July 26, 2021, 08:14:48 AM
Diode ? where ?
The Tesla coil always resonates and is positive and negative. It has no unipolar output.
You can give it unipolar pulses, but it will always give a bipolar output.
If it's otherwise show me the unipolar tesla output oscillogram  :o
color
r2fpl
After reading Geo's schematic and remarks, my dad joined this cafe.
In the meantime, no member has been able to accurately describe a specially accelerating kacher device as Geo.
Because my dad had a similar experience in 2015.
It took some time for my dad to sign up because there was a problem with this cafe's subscription system.
The first reason my dad stimulated me by X-marking Geo's schematic with a YouTube video was,
The 494-4420 (4421) combination puts less strain on the 260/460 MOSFET than the 494-2110 (2113) combination.
The grenade coil is a reactive power device for kacher operation.
So there is no need to create a high voltage of more than 100-150V in the grenade coil.
Tesla or Kacher secondary coil windings are only 9 cm long.
No need for high voltage.
The 494-2110 (2113) combination creates a high voltage and generates a lot of unnecessary heat in the device.
A lot of energy is wasted.
In comparison, the 494-4420 combination has less unnecessary energy wastage.
494-2110(2113) combination cannot get 46VAC(2KW light),
The 494-4420 combination was able to get 46VAC (2KW light).
The second reason is,
Geo was stuck in the grenade structure and was meant to be tampered with and advised.
But it was rejected.
Another reason was that with the exception of a few members, the rest of the members did not listen to Geo.
And Geo left.
No results are shown in any experimental course.
This is the truth.
Know the truth but only give out results Anyone who provokes members to experiment with fear leaves them.
Now the experiment is up to you.
I'll scare you until you get the results.
My fear is silence.
A communist who cannot wait does not understand the experiment-process.
color
1234p
GeoFusion
Hi all :)
About the device, Just a recap on some what I experienced and some good tips.
The pushpull or any other HF drivers for mosfets to able to do the same action and I say,
just make sure there are no filter caps right after the IC (TL494 as example) which makes freq for you which feeds the drivers for the Fets
on the driver board, that kills the operation completely. This is the reason why I shared the exact same diagram long time ago.
the TL494 and the IR2110 config.
The point of output.
The Kacher or better to say Tesla coil is what manifests this energy at the output. More to say, has the full control of this energy which we
all are looking to see manifest at the output.
What I do believe now is that small tweak recently I did with closer antenna to
bifilar inductor is what made me to understand this more clearer also. ( this is only for this method , there are more ways )
Imagine the tuning has to be such condition with Antenna's harvestation of the charged particles ( Ions/,radiant and positrons which are anti electrons ) and having it to be right in the zone of the magnetic field which the bifilar inductor has generated which it will resonate to the antenna incoming charges,
(not the full resonance of the bifilar it self )
distance of Antenna  close to the bifilar is crucial depending the Kv range it produces.
This made the difference in my latest recording about the test that has been done without 28T from toriod/yoke and only the 3T series.
By this time it is already shown on video and even scope readings on what we expect what kacher should be doing.
Since it calls upon the charged particles being excited by the interruption cycles of
the Tesla coil/ Kacher operations. So the Cycle needs to be interrupted, (Dead Time).
Also repeated so much times per time to manifest it even more.
So it should not be generating normal Sinus waves, but interrupted ones at the peak of each and cut off after and repeat.
Better to say to generate spikes.
With that new dead time controller I am able to get a bit more lumins out from that 300W bulb in previous recording.
This is only Tesla coil at work here.
The rate of power into the series resonance coming pushpull /yoke to 3T series cap  which is generating the HF magnetic field is
insufficient to even light or even burn the filament of the 300W bulb. Also already shown on recording.
Right now there is also greater white arcs  present and they do not only burn but give nasty shocks.
Regular setting is pure plasma stream which burns.
Look, if the kacher can produce just abit this " white arc " you will see light manifestation. which I had many times befor.
The amount of amps IN with kacher determines  the amount of turns of Primary and diameter of copper if to see increase of decrease.
The IN amps can vary in many ways depending the setup.
What's interesting here is when the effect is running, the amount of Amps IN is set amazingly to a point which I still do not understand fully
and what happens is everytime to put load it will show where it will not increase Amps IN
but it shows that it has a threshold until where it will  start to decrease Amps IN  after,
so the  more load you add the lesser Amps IN you will see at IN and this is where you can determine
the amount stored energy it created/ harvested and accelerated within the field of control.
Think I shed some more light on the subject to understand what we are looking for.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg512973/#msg512973
1239p
color
It is not only kapanadze that intercepted Moray's merit.
Maybe somebody will claim the biggest financial gain in decades later.
- Citing articles -
yes I agree it may cause new untaught yet apocalyptic crises just around 7 years from now if FE is given to humanity now.
But if the device is real it is gold mine of unprecedented value for just few bucks.
Literally billions of dollars.
Is the contradictory word assurance of maximum financial benefit guaranteed?
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg513618/#msg513618
1240p
GeoFusion
Well, I do have the right measuring equips to see what the frequencies which things are and
even a probe if needed to see what happens to the field near the Antenna and grenade.
Btw, the Kacher, Yes without the ferrite choke and the antenna you can see the normal violet color,
But it's the whole configuration of how you connect the ferrite piece and the antenna, especially the direction! is very important
and the distance to the inductor wounded ontop of grenade. this brings amps in the high voltage end. even without the grenade it is
manageable to get those orange arcs. Has to do very less about how the freq should be and yet good amount of power pumped in,
duty cycle or so. but it's  all about the winding directions.
This was already done with simple kacher circuit, still on vidoes for view.
without that result I am unable to get the manifestation which was presented in lastest videos.
It show's how the Tesla coil/kacher is actualy calling upon the charges which that will be accelerated within the
induction pulsed inductor on grenade. Frequencies can differ everymoment, It was everytime on each setup different but
getting it to do that , there are methods.
lets say the last time it was working on bench, was reading 21khz pwm over toroid and about 880khz freq tesla coil antenna.
with the tapping points on the secondary of tesla coil, it changes values and might get better results on harmonics of it.
but I assure you, freq at some point is to overclock the energy coming in that is it, is part of how I see it and has something more to it.
I'll give you a tip, the series resonance does not have to be on point ( Top and best series resonance area with the 3T and cap)
for it to resonate with incoming charges from antenna,
this is where many don't understand and it was hard for me to figure this one out while doing  wicked experimentation.
It has sweet spots, Imagine the magnetic field bubble and how the antenna is sitting in it, and accelerate.
Nickz is close by doing this, he is hitting those sweet spots. where things get very fragile and even the hand creates capacitance.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg513657/#msg513657
1256p
GeoFusion
Happy New Year 2018 guyz :)!
NickZ, :)
Yes, Tesla had his beyond the earth contacts during his time on here. He had also contact
with his tesla radio even to have some conversations with his friend westinghouse when he past away.
Talking about the response from mars is one of them but there was direct and exchange of knowledge.
There is information I would like to share with you and now the forum will also read, see this as a present. :)
Also have been getting info beyond my body but not constant, but this is what I can share. limited
I don't expect you to believe me for what I'm about to say, but keep an open mind on the subject
Nikola Tesla, befor he reached earth,
He was/is one of the few top officers of "The Domain Expeditionary Force" ( galactic officer )
who have taken it upon themselves to provide technology to Earth during their off duty time.
These officers leave their "doll" at the space station and, as an IS-BE ( spirit, as we are as well) assume or take over a biological body on Earth. In some cases an officer can remain on duty while they inhabit
and control other bodies at the same time.
Mission orders,
to assist you in your efforts to advance scientific and humanitarian progress on Earth.
There is a bit more which I can tell but it goes very deep for the reasons also he came here to help.
They also are and still taking care of a quadrant of this galaxy we live in, Milkyway.
His co worker "Airl" ( Domain Galactic Officer as well) which was one also here on earth
back then shared this info as well.
Tesla was selected to be send to earth in his time and was born as Nikola tesla,
To give the planet and the inhabitants a gift to know how to utilize radiant and
incoming charges all around us and in space via devices he presented.
It's nice to know there are different Ionospheres with different potentials, and chem compositions which make
conditions for energetic flows to be possible in many ways.
He also had Craft models which worked on anti-gravity where T. Otis Carr ( a friend, look him up on youtube )
experimented on which was learned from Tesla.
Tesla came to earth to experience the human life and in exchange shared and left knowledge behind
for what is still available to us.
Btw Nick,
I will share some important stuff with you later on. ;)
after this.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg514899/#msg514899
1262p
GeoFusion
Hi Nickz, and All
Ok lecture time. pls take time to digest.
Aether (dark matter) is matter which fills space / cosmos and our very surroundings which also
is still being used to form/create and shape our universe using photons with specific freq ranges and laws.
will not elaborate to much on this.
As it is just only a part of what we are looking for.
What we are looking for and need to comprehend is;
We need to focus on Atoms of Charges and to see them separated.
We have to view the earth's Ionosphere and ground-earth as huge capacitor with split charges.
The  Positron (Ion) (+) / Electrons (-).
Since forever we have seen when lighting strikes happen which manifest this.
We have the Protons which have the electron(-) and we have the anti-proton which has the positron (+).
Earth is (-) ionosphere is (+).
Hydrogen (+) carries positive charges, The sun's Fusion surface is filled with it
and spreading just like any other sun out there which lets us know, space is bombarded with charges.
Earth is simply harvesting it and collected thru the Ionosphere.
Celestial bodies like Earth will then carry negative charges then to make
necessary conditions to electrify most around.
Every planet has it's potential ionosphere if they have.
Now take a look at the Grenade and the Antenna,
Grenade is connected to earth ground (-) charges,
Antenna calling/harvesting/Manifesting the (+) charges (only!)
They are separated in charges.
Tesla coil secondary, when in operation looks like it's shooting lightning (plasma (RF) for solid states)
from it and want's to reach out.
Indeed it has a part of it which reaches out (Corona) but In fact it is calling charges (Ions) from the surroundings.
trying to connect.
It is pulling energy towards it from backround ...
this is caused by spark gap by generating sudden magnetic field and collapses after.
The collapsing of this field is attracting these (+) charges to the secondary and secondary is connected to (-)
which then makes contact and you have lightning!
The beautiful purple Corona which is present on top of Tesla secondaries
when in operation of a spark gap, clearly shows it's vacuuming or trying to harvest the opposite charges (+).
Now to put cherry on top,
With all the electronics for tesla coil or any HV pulse device in right condition
,it's to speed up the process of gathering the charges (+) and quantity and acceleration to multiply amount.
Akula's device with the Inductor (bifilar on the grenade) is to multiply that which  has been harvested
and then overclocked, the speed of process. making a super field.
Series resonance over that part of the grenade could also be seen as a accelerator of the charges (particles).
Example, the spin , just like a delco generator does, needs to reach certain rpm to reach condition.
Balance needs to be searched for,
if you see what you are feeding tesla coil input
and getting effect is small in manifestation, what do you thing you have to do ? ;) think.
The only reason why these devices self run,
is the collected charges coming from backround ( Positrons/ions) in great quantity ( greater than) ;)
which is a external power source then the mains created on earth. (battery /power supply)
in order to make something self run, it needs two separate sources of energy
and in balance for it to be autonomous operation. ;)
Edit** Tesla coil is the Heart of these devices
This is happening with these Akula/Ruslan/Dniester/Kapanadze Devices.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg514520/#msg514520
1380p
GeoFusion
Hi Nick,
About the 150V input to Kacher primary, it is not from grenade it it from 28T yoke being rectified.
If you see closely on Akula schematic you can also see he is ranging a voltage around 30-60V and then rectified
for use from his x amount of turns from yoke. It is necessary to get a certain voltage lvl to get things right condition.
I recently did a sweep of 12VDC up till 50VDC on primary Tesla kacher which I am using.
what i saw was reaching 43VDC i saw similar effect happening with the grenade, while having it on 110VDC+
which was recorded.
It is somehow necessary to have a variable voltage to primary to see where sweet spots are.
Your current kacher  handles up around 24VDC, but adding more as you said burned it. That is so because of the
arrangement of the protection and dividers and their values.
Nick, when you disconnect the 28T from the grenade ends that is when the real journey begins.
Let only the 3T with cap in series to bifilar area connected and drive your kacher with 24V + side from your yoke center tap.
As how the mediator way was connected befor. Play with your Primary left to right and see where the spot is, and connect heavy loads, 100W up. strait from grenade and one of the ends with the ground wire.
this is where the interesting moments and knowing why the spike HV is the main key.
Here this is what I just explained,  this link. take a look at it completely till end
https://youtu.be/_wKZ9ehCciU?t=353
Try to do the same and you will realize one day that you will need variable voltage for desired input voltage for primary for Tesla for
a good load out.
This is one thing I would say now here, in that video when you saw that 300W light 10%.
You notice an arc when I place the ground wire?, that is the same yellow arcs I have shown in my recent recordings but in
higher  voltages.
You will see when you reach this type of stage you will see more voltage is required, maybe not soo much but you will see.
This is just my experience on bench.
try out what I told you, because all of the higher powered selfrunners as what they are called are running in this way.
Grenade device that is.
Remember when Ruslan was connecting bulbs outside in the wilderness and wanted to connect another aray of 500W bulbs,
did it not sound like HV arcs ?
https://youtu.be/F_P90Q4fskE?t=344
here is that part within the vid.
till here for now
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg532224/#msg532224
1389p
GeoFusion
Hi Nick,
Yes type 3 mod was very successful test back then but was limited by voltage at the output.
Where I could have lit alot of load was holding inbetween a 68 till it drops to 60 and below when
connecting 1Kw worthy on bulbs but are on low lumens lvl because of voltage. Was not enough for loop.
3T from yoke with the series caps area was not meant to be output but somehow it became,
I just had a thought that maybe I had it working in reverse.
Grenade became very warm when in operation. Without the ground there was nothing.
Input amperage did not decrease/increase while adding load.
only when reaching threshold ( when placing alot of load till things happen)  only then you can see decrease in
input DC Amps and lose the effect for the moment.
But I was close those days, yet I did not like the sensitivity of the antenna so something els should be done,
that is why I stopped on that one and figuring other ways out and learn why others have it differently connected.
To know the Whole core we need to conduct series of experiments as to back engineer and see where it is.
All,
One thing I want to point out on is  at the Roma Gritz device and Vasmus are almost or are the same operation.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg532487/#msg532487
1402p
GeoFusion
Hi All,
The my recording according to the schematic
https://www.youtube.com/watch?v=s9YqkzlKulE
what I can say is that I have the manifestation happening on different spot which was not ment.
Anything can happen and should be prepped for anything.
As I disconnect the ferrite piece from antenna you see clearly that It aint producing much.
Kacher here is doing it's job, and the synchronization connection area is very important
and how you connect ground and emitter side of Kacher.
Should be repeated this to see if it can be done by anyone els but one word, this is very unstable.
you will get maybe 60V ac out and constant at hat point of caps at 3T used for load
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg533181/#msg533181
1416p
GeoFusion
Hi Urfa :), it has been a while and Hi all,
Yes that is what we need to focus on.
the discharge creates so much amps after fast charging with DC.
I have blown two diode bridges by doing this and was able to light up 500W very bright.
I did a pause after accident... but will continue.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg534550/#msg534550
GeoFusion
Hi all :),
There is alot of talk on the forum lately and about the freq's and coils and more but
the one that has to be focused on is the tesla coil operation and how the ground is connected
thru the system and acting as a capacitor plate with the rest of grenade and inductor.
2 videos will be uploaded today, been busy and ready to continue on the Journey with some new info.
Will also be showing how to set e dead time control mod within one of the vids.
After that the next vid will be with measurements with CT's i've build recently and with scope.
Some pics below of a new grenade being wound special yet simple way by following unknown diagram.
;) lets see what will play out of it.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg535483/#msg535483
Hi All :),
Two new recording for you guyz.
Video 1
https://www.youtube.com/watch?v=SfPtyHylzSo
Video 2
https://www.youtube.com/watch?v=1Nn6cOmpcCE
The difference it made when i changed the Transistor to Mosfet on the Akula kacher tesla controller.... is crazy
if someone tries to replicate this and how i have it ... please be careful as it shocks the hell out of ya or kills now.
More to come up and especially the test with the ground using CT's. (current transformers (coreless)
Hi All,
   Forest;
Yeah it is all about matching the frequencies with the LC arrangements. but to me that is half of the real work that makes it
all tik as what we are all looking for but that is but the start of the resonance process.
The real secret begins at tesla coil. We all have to see where current peaks are best at certain freq while scoping ground.
It's the search for the best freq in the areas that we all are ( which is all different) that will show where particle flow is best
from ground. The best response from ground best said. That will be around external power supply.
The frequency,  and pulse it has to be tuned at were it will be coiled to the length that
it should be to keep resonating on that feq.
If you look closely at the pictures of the diagram which is blured , do you see that orange connection going from fets to the
negative rail of kacher? on/off process going there...and that only takes away 0.08amps which was provided info to
operate. So meaning Tesla has to be only brief moment on only, not oscillating like crazy but ofcourse on pulse it
will show differently.
For Nick and AlienGrey and all,
this is my Dead time control mod on the Akula Kacher circuit. Enjoy
Whole Circuit
https://clk.ink/25aJF6
And Zoomed in Circuit
https://clk.ink/yx6J2u5
Click on the box I'm not a robot and click on the " Click here to continue " button in blue till it says
wait 10 seconds and  click on the " Get Link " in green.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg535493/#msg535493
Hi all,
Nick,
The current transformer that will.go over the ground
line needs to be like a toroid and making it from plastic
Not ferrite. See image of example.
The L2 of kacher's needs to be grounded with the ground
To see results. See image.
Reminder that we all are searching for that power coming in back.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg535643/#msg535643
Hi  :)
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg539716/#msg539716
Hi Nick,
Yes, busy as always with many things that are important.
I'm just here to give hints that will help.
To understand the system is to focus on the Collapsing field part and using a HV swing right when that happens.
this is what gives it the multiplication method. resonances are used to keep in tune for the system to work and the amount that
you want to receive corresponding to the LC configs. Sync is needed as well otherwise it wont work.
then you have to see when kacher needs to be fired on the correct moment when Mosfet of pushpull is off.
The simple kacher has to be turned off completely by a switch, ( MOSFET) for a brief pulse when the collapse of field is
happening on the grenade. You can add an extra FET that will control the simple kacher negative terminal on or off in fast.
tricky part is that, to sync that specific part.
As what Ruslan said long back or Akula, the Tesla coil/ Kacher is what is doing all the massive output work after.
Make sure you only tap from out put after diode bridge. not befor! otherwise resonance is broken.
Bemf is what this output is, I have seen to much but had to say it.
Important EDITED **
** Nick, I reflected on my old videos where in 2016 was a year I almost had it but it was unstable
Yet it performed as Ruslan did but was limited power yet it did not effect the input at all when changing output
load. In those days I had no idea precisely what was going on but was doing my best to understand, but now I do.
The BEMF was present that day at the output , this is why it did not effect the input.
If there were another tesla coil circuit that could handle higher voltages input such as 60VDC would have made this output greater that day without increasing the input.
this is the video from 2016
The output is not affected by touching the antenna that also shows that the operation is different as I am stating.
https://www.youtube.com/watch?v=1weV296sjHU&t=
Now I know what to do ;), It has taken me 4 years to figure it out since that day.
It does not matter of his circuit now, yet he had some success but we are working on the Akula/Ruslan/Dniester Device here.
Focus on that.
I'm simply helping giving hints and my findings over the period of times.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544887/#msg544887
Hi Dave,
Yes I am aware of this device and have spoken to T-1000 about it many times.
The way this is making energy is completely different from the Akula/Ruslan Devices.
STAAR Yoke device is doing Ferrite Transmutation energy output. this leads to nasty Radiation from the extra material
they had inside the composite of the Ferrite material. those two frequencies Exited it and release it and within certain
resonance. Not sure if it was mixed of Barium inside the Ferrite.
**On thing Ruslan did not talk about nor Akula is how this energy comes about to existance.
that is where they are bastards for a long time... my time invested to see and experiment what it is all about
came to an realisation.
By my findings it is Bemf harvesting and havign resonance all over to keep the balance.
The collapsing field energy and having a brief HV HF pulse right after is what accelerated the output.
This is the type of output when loading it, will not have effect on input. Simple as that.
Ruslan's lastest videos back then for sure did show he using other ways how to
but it is the same outcome and method he is using but difference devices to get it.
Again, STAAR device is comepletely different, Unless you are trying to to nuclear resonance on copper
which is not the thing here right now.
Ruslan did not infact never say what is happening at output but at the video I just posted of my experiment in 2016
RUSLAN did msg me and told me I am close to figuring things out but I had still no clue back then.
Right now, I have.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544890/#msg544890
Nick,
This link will bring you to the diagram that I am using is also the one that Arunas posted today.
https://i.imgur.com/p8ffNQW.jpg
You will need to zoom in alot to read and see details it is a picture of size 11Mb so very high detailed.
Look at the left design, that si the one we are building, and you will see the kacher circuit at the top side
and see the positive and negative inputs for it and you will see that negative rail is given in orange color.
that is being interrupted through a mosfet on timing. check it out.
It will be necessary also for your setup. This diagram was once found somewhere and no one know from whom it came from
and was one time on a site that existed only for a few moments and then got shut down for unknown reasons, but this was
one of the salvaged materials I got from that site since last year.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545357/#msg545357
