Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Nick:
You are welcome, I'm here to help.
Yes i know you are using the Stalker diagrams but
trust me to use this new diagram for the next step to make it really work.
It is the simple kacher that it is showing in the big diagram if you follow it but look what controls it is interesting and is
needed. Gonna show you a pic right here soon enough to show you what I mean ;)
Thing is the kacher can't just free oscillate, it has to be interrupted ( short pulse )
and it ain't so hard to replicate something extra to it.
It will help and you will see results.
We are beyond the point to make this thing work as how it should now and we have everything to try it out right here
right now. The bigger reason why I am showing it is because Believe in it.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545360/#msg545360
Nick
Geo: Ok, I've seen the simple Kacher circuit that you are refering to now.Yes it is similar to my own version, but where is the interuptor circuit part (not shown). As that is what I am asking about.
Alright :) good.
yes it is a simple one.
Now do you see where on the minus leg of the Kacher is?
It is given a Orange color, orange wire which then goes to one side of a Mosfet if you follow the wire.
It connects to a IRFP3205.
The link to the diagram
https://i.imgur.com/p8ffNQW.jpg
I will do my best to show you on a modified pic if you have problems finding it. it is right there.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545363/#msg545363
Here, Geo lies to Nick.
It is a lie of the intermediate result that appeared in the course of the experiment.
Geo wasn't intentionally lying, he was just stating the results of his experiments.
My dad has also been deceived by the results of the interim test many times.
This is proof that Geo's experiments have yet to yield results.
If Geo reappears in this cafe, ask questions.
color
Hi Nick,
Yes, I am about to do a good recording this week so to show the 3T series resonance area.
Something I have to show and for others to see. after that will connect everything and some more stuff that
I have stumbled across for the findings and the last pieces of puzzles.
Stay tuned
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545553/#msg545553
The greater ground the better connection and attraction for good output.
The less ground in my experience is less power out.
In comparison with the signals sharing from the TL494 in shown diagram,
where on my setup it is shared after the amplifier which is the 1R2110 to the kacher circuit.
Busy replacing small caps on the Pushpull driver, TL494 was limited till 27Khz.
Now will be able to have the range of till 50Khz which is necessary, maybe this was limiting me
Since very beginning.
Yes it has AG, to busy with life and other human alike experiences.
1.7mhz is one of the values ​​depending on my tapping point ( lenght ) of the secondary Tesla I tune too.
I had good results back then around 800Khz - 1Mhz ~ range on the tesla when Pushpull circuit was driving around 16Khz-18Khz.
All depends where the standing waves are good and the resonance to set too.
Just make sure your push-pull driver AKA TL494 chip set can drive up till 50Khz range, It is important and will be sufficient for @ 40 meters
grenade coil receiver. All HV caps connected between yoke and grenade and grenade output are all in series for tuning...after that
the HF HV FWBR to caps that will be charged in Parallel, this is what I am about to go thru as approach. did it once before on outside bench
but on a different approach, some variant of Ruslan back then, Video is on my channel. Don't forget the ground, it cannot operate well
without it.... Well this design then... because there is one that does not need ground and utilizes 2 antennas with double HV coils with
centertap. ;) that will be next after we finish this.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg547693/#msg547693
color
And in addition to experimental purposes, capacitor capacity is a waste.
You can make it the simplest.
So it is the circuit that has to be made simplest.
You need to understand why there are two yoke primary coils.
This is why it should be made with 3525(494) and Operational Amplifier (op-amp) 4421x2, not 494/2110.
I understood and changed that Geo's circuit is not suitable for a Ruslan generator.
This is not my words, but Ruslan's understanding.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg548400/#msg548400
It would be a good idea to send a wedding message to Geo.
My daughter saw Geo's experiment and appreciated her chances of success her. ;D
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg549875/#msg549875
In addition to the resonance method, Ruslan has exposed the most important parts of the system in which the generator is operated in a very ordinary place.
Geo is the only member to experiment with the system method.
Perhaps that is why Ruslan praised Geo.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg549983/#msg549983
r2fpl
Breaking a Tesla coil is the same as energizing it. Of course it depends on the duty.
Probably 'Steven Mark Design' has no effect on FE. These are just schematics. He made several of them.
color
r2fpl
'Steven Mark Design' is the epitome of universal distortion.
How is it different from the schematic drawn by Ruslan?
Not working is the same.
It is a bad thing to confirm what anyone can imagine and distort it as if it were real.
Experimenting with common things and distributing elaborate drawings have very different meanings.
https://www.youtube.com/c/OkkiMoeljadi/videos
Russians have long been good at applications here and there.
The bunk device is one of them.
Russians are very good at copying other people's skills.
It is very different from the atmosphere of capitalist society.
It is a natural survival strategy created by the oppressed social atmosphere.
https://www.youtube.com/watch?v=QrW-NRIko2I
https://www.youtube.com/watch?v=regE-smlsZ0
https://www.youtube.com/watch?v=SxNYG3BwzP8
Even in capitalism, technology replication for research purposes is actively allowed.
All development begins with 'a chance[an accidental] discovery' and 'research' and 'experiment'.
'Steven Mark Design' is also in this category.
And I just passed it on as it is.
color
I built test setup for Tesla coil with slightly different driver schematic, but functionally equivalent to Stalker's driver.
HV coil is 37.5m on 50mm tube wound with 0.5mm wire.
6 turns primary works better for me then 3 turns, it seems that number of turns need to be selected experimentally.
pic. 1 show current in ground wire and voltage (close to antenna)
There is interesting effect that last most powerful pulse comes after the burst, when driver already switched off
(may be it is a driver artifact ?) pic.2
In both, voltage and current, two main frequencies present 1.3 and 5.9Mhz
1.3MHz is LC resonance (was 2.45 without antenna), 5.9Mhz I guess is HV coil wave resonance
With 200v power supply I can obtain sparks 0.5-1cm long from antenna, but they are not white, just white blue.
Some people suggested that for better results LC need to be tuned to 1/3 of wave resonance...
Regards,
Vasik
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.msg93936#msg93936
The intention of someone who says that the LC needs to be tuned to 1/3 of the wave resonance to graft the grenade main coil and the kacher secondary coil is very different from the 'Steven Mark Design' intention.
A power distribution ratio or a direct connection may be better.
Those who expect some special resonance of the kacher and grenade cling to the illusion.
It is far from the attitude of the researcher.
The 4KW lighting electric-spark that Ruslan demonstrated in the peatlands was a white plasma.
This is not a wave resonance, but a direct attack like 'Steven Mark Design'.
Once upon a time, my dad said, 'Ruslan said he uses diodes to replace spark gaps'.
Capacitor combinations don't fall out like drugstore licorice.
Experience knows more intuitively than oscilloscope waves.
