Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
AlienGrey
color
Why doesn't the magic happen?
Now then I have removed the EHT circuit to make it easy to see what is sugested to be happening in our remaining circuit, Some how our coil should be generating standing waves, should it not?
Now if I lose wind 2 or 3 turns of wire I should be able to see this on a scope, but to coin a phase "I shourd be so lucky" ! So if not whats the problem???????????
My dad copied the schematic below and made the schematic above.
If something is missing, refer to the circuit diagram below.
If you make a generator by imitation of the schematic below, magic will happen.
Paradoxically, the magic doesn't happen to members who haven't made the schematic below.
The difference between the two schematics is the push-pull method.
A standing wave in a push-pull circuit would mean that the yoke-transformer works without disturbing the kacher's high voltage.
A kacher unbalanced acceleration can burn your oscilloscope.
My dad never knew what was missing from the schematic above.
How an electrical short works the magic is clearly exposed in the schematic below, but few can see it.
So to say that it worked by chance.
Another key is that you know what to say.
If you just understood it in a paradoxical sense, you are likely to fail.
I think it is the limit of members who are extremely reluctant to expose generators.
color
Sorry, but your idea will not work...and it is simple why...
Magnetic Fields can not be "cut" nor blocked...
https://overunity.com/15864/friedrich-luling-magnet-motor/msg560090/#msg560090
반자성 알루미늄이 자력을 차단한다
https://www.youtube.com/watch?v=VgGGzVq-fa8
https://www.youtube.com/watch?v=14ayyu9PVSI
반자성체는 근본적으로 자력을 차단합니다.
알루미늄 호일이 공중부양하는 것도 자력차단 원리에 의한 것입니다.
최고의 반자성체 비스무트-플레이트로 자석을 밀봉시키면 자력 차단 효과가 더 클 것입니다. ::) ::)
아까 어떤 조센징 유튜버가 약한 핵력, 강한 핵력, 전자기력, 중력까지 통합할 수 있다고 그럴듯한 가설 제시하며 어려운 수학/과학공식 섞어가면설 한 20분간 썰을 풀길래 내가 반박 댓글 좀 달았더니 유튜브에 댓글이 안 달린다.
아마도 유튜브가 내를 블랙리스트에 올린 것 같은데.... 망할놈들... ;D ;D
해서 예다 올린다. ::) ::)
강력, 약력은 미시세계 물질들의 관계고, 전자기력은 특정 금속이라는 단일 물질들의 관계며, 중력은 다양한 물질들의 모집질량 또는 고온에 의한 합성질량의 관계입니다. 중력은 다양한 물질들의 평균값입니다. 돌과 쇠 중 어느 것이 더 무겁냐고 묻는 것과 같습니다. 그리고 허블상수는 우리은하와 안드로메다 은하간의 충돌이 발생하는 중력간섭공간에서는 무용지물이 됩니다. 빅뱅이 있고부터 가속(암흑의 힘?)이 붙어 현재 70% 더 빨라졌다고하는 결과값은 은하들간 중력간섭이 작용하는 공간에서는 하나의 가설(무용지물) 추측에 불과합니다. 좀 다른 이야기를 하자면 아인슈타인은 이스라엘 최초 대통령 자리까지 권유받은 유대인입니다. 유대교의 여호와는 이집트의 어둠신 아펩과 그리스의 번개신 제우스를 합성시킨 신입니다. 일부 유대인 과학자들과 유대자본 지원받는 학자들이 가설에 불과한 암흑물질이나 빛을 굴복시키는(event horizon) 블랙홀에 열광하는 것은 과학에 앞서 그들 사유에 개입한 어둠/암흑신화 증명을 위한 發惡과 같습니다. 그렇지않아도 우주는 어둡습니다. 과학을 빙자한 신화에 가설이란, 가설 만큼의 기묘한 믿음과 같습니다(믿음은 바라는 것의 실상이요 보이지 않는 것들의 증빙이라-그들의 성서내용 일부 발췌). 해서 4대 힘의 통합을 특정 물질(들)간의 간섭과 질량값과 凡우주적 물질들의 분포값이 아닌 단순한 평균값으로 중력값을 계산하면, 현재 360도 3차원 방위로 관측되고 있는 우주의 넓이 외 더 큰 우주가 바깥에 존재한다면 중력값을 다시 바꿔야 할 겁니다. 약한 핵력값의 문제가 아니라 평균-중력값의 문제입니다. 빅뱅이 존재하는 우주공간은 빅뱅 발생점부터 일정 공간이 텅 빈 암흑공간이 있어야 한다고 생각하는 것이 보편적일 겁니다. 우주가 너무 넓어 텅 빈 140억년 이전의 어둠공간을 발견하지 못하고 있다면 그게 더 이상한 것 아닌가요. 현재 우주과학계는 빅뱅(가설)이 발생한 시작점 텅 빈 어둠의 공간을 발견하는 것이 제 일의 목적입니다. 어둠신의 최초 천지창조를 증명하는 일일테니까요. 빅빙을 증명하기 위해서라도 필수입니다. 최초 빅빙이라는 우주에서 가장 큰 힘을 은하들간 중력작용으로 텅 빈 최초 공간이 사라졌을 수도 있습니다(말이 안되는 농담급 가설) . 다양한 의견들 만큼 칼세이건 같은 신화와 과학을 넘나드는 이상주의자들이 과학계를 교란하는 한 미시세계 법칙을 광대한 우주에 적용하려는 통합시도는 아직은 시기상조 같습니다. 글이 두서없어 죄송하고 제 개인적인 생각일 뿐이니 괘념치 마시기 바랍니다. 전문가적인 식견 많이 배웁니다.
color
[ MQHC4 ] 부록05 - 중력, 약력, 전자기력, 강력, 4대 힘의 통합
조회수 없음 2021. 9. 5.
https://www.youtube.com/watch?v=6qTdA_D7j5w&t=2s
아빠! 댓글은 사라지고 없는데 답변왔어. 대꾸가 뭐 저래 진짜 개갈딱지 안난다 진짜.
이곳 사이비 회원들처럼 사이비 학원 강사같다.
