Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 36 Guests are viewing this topic.
color
Hно
https://www.youtube.com/watch?v=WC04b_S1S68
Для этого видоса использована данная схема: – нанопульсёра.... (не Мейер)
NR
ІН
Т. 300л/мин - легко!...
NANO-PULSE power supply это в данном варианте не резонанс, а только сверхкороткие импульсы пиздякающие малећулу воды!....
When the generator research is jjamppong, the boat goes to the mountain.
color
I Make Powerful Generator Use Free Electricity
https://www.youtube.com/watch?v=XyBunKazv7s
It's blatantly more complicated than building a Ruslan generator. ;D ;D ;D ;D ;D
color
Kapanadze The Continuation Reverse Engineering N°2
https://www.youtube.com/watch?v=jD-sfRmU59U
Here is the second part of the Kapanadze Reverse Engineering N ° 2 video.
On some well-known forum some people criticize what I do.
You have understood that these people comment only to destabilize us and prevent us from sharing our discoveries.
I want to tell you that I will not give up and I will continue to multiply the tests and the manufacture of reels until the day when I will discover the real functioning of Tariel Kapanadze's video "2004 video".
Even if this video is a montage to lie to people, I will be proud to present it at least to all the subscribers of the Youtube Channel, Résonance by Tesla, who trusted me.
But believe me, the reason I'm spending so much time on this subject is that there are a few things to be discovered, so "PERSEVER", let's not let the detractors stop us from telling the whole world, that energy is there, it is enough simply to change our Aristotelian way of thinking.
Voici la deuxième partie de la vidéo Kapanadze Reverse Engineering N°2.
Sur certain forum très connue quelques personnes critique ce que je fais.
Vous avez bien compris que ces gens commentent uniquement pour nous déstabiliser et nous empêcher de partager nos découvertes.
Je tiens à vous dire que je n'abandonnerai pas et je continuerai à multiplier les essais et les fabrication de bobines jusqu'au jour ou je découvrirai le réel fonctionnement de la vidéo de Tariel Kapanadze " vidéo de 2004 ".
Même si cette vidéo est un montage pour mentir aux gens, je serai fier de le présenter au moins à tout les abonnés de la Chaine Youtube, Résonance by Tesla, qui m'ont fait confiance.
Mais croyez-moi, si je passe autant de temps sur ce sujet, c'est qu'il y à quelques choses à découvrir, alors " PERSÉVÉRONS ", ne laissons pas les détracteurs nous empêcher dire au monde entier, que l'énergie est là, est qu'il suffit simplement de changer notre mode de pensée Aristotélicien.
There are no meaningless experiments in the physical world.
We hope your dreams come true.
color
Освѣщеніе при посредствѣ резонанса по системѣ пёпина. – ІІрии описаній системы телеграфiн и телефонія IIёнина было упомянуто, что изобрьтатель приспособляетъ свой сподобъ II для получения свѣта. Недавно онъ доказали возможность этого практІІчески, произведя слѣдүюшій опытъ въ Columbia College. Онъ взялъ 100 лампы Эдисона, так какъ не было подъ рукамі трубокъ съ IIүстотой, но угольEIі лампъ не играютъ никакой ролін въ явленіяхъ.
Схема опытовъ представлена на фиг. 4. 1.500 — вольтовая динамомашина Слэттера А обыкновеннаго типа достав.Iяла токъ съ 130 періодам і в'секушду Въ трансформаторъ, который понижаль напряженіе до 150 вольтовъ. Во вторичную цѣь введены два конденсатора си двѣ индуктивныхъ катушки 10, одну изъ которых можно регулировать, вводя и выводя из'ь цѣi111
1500
К-01
- ЕООВ
Фиг. 4
ся секці. Лампы L, распред..тенныя въ три ряда іно 33 iптук, введены въ вѣтвь у конденсаторовъ. Каждая лампа вводилась в цѣь, соединяясь съ цѣпью своей метал.IIIческой надѣлкой съ одной стороны и съ другой листиком станіоля, который покрывалъ нижнюю часть колпач около 16 поверхностн). - вольтметр, а ESV — электростатическій вольтметрь.
Прії Іпусканіи въ ходъ динамомашины унастраивали" цѣнь упомянутой индуктивной катушкой. При постепеномъ повышенін потенціала у ламиъ до максимума (2.500 вольтовъ), сіяніе лампъ постепенно усиливалось и поддерживалось съ одной напряженностью, пока катушка оставалась въ точкѣ резонанса. Во время настрailванія" цѣні, при всѣхъ измѣненіяхъ потенціала Вь ламповой цѣшI, и по достиженііі резонанса вольтметруь у показывалъ неизменно 150 вольтовъ, а это доказывает, что повышеніе потенціала въ ламіновой ДѣIIії обусловливается вполнвліяніемъ резонанса.
(Electr. Engincer).
https://strannik-2.ru/index.php/forum/temy-pavel-a/557-svobodnaya-energiya-gde-ona-budem-iskat?start=900#81740
AlienGrey
