Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Quote from: lancaIV on January 02, 2022, 08:49:56 AM
For understanding the #2114 prices prevision :
the "Microcube" with 9x9x9 inches volumes is defined by R.Yost with 9 pounds ~ 4,1 Kg weight and 1500 RPM nominal velocity !
We can compare with alibaba/aliexpress market hub/platform prices per unit/group buy discounted and
http://www.schillergy.com/   http://www.schillergy.com/pdf/schiller-energy.pdf
With permanent magnets 1/10 costs,coils 1/3 costs and plastic bonded iron core 1/2 costs we can assume 1/4 market price to actually offer per unit  !
Group self-organisation buy fob factory and transport costs dividing  : - 80%+ !
From Schiller the given number,total weight active and passive parts,actually conventional material use  :
        alibaba/aliexpress price comparison for costs/price idea
                              2 Kg/KWp/   3000 RPM                             75 Euros
                              1 Kg/KWp/  6000 RPM           linear:       37,5 Euros
                           0,5 Kg/KWp/12000 RPM           linear:       18,75 Euros
                    0,05 Kg/0,1 KWp/12000 RPM           linear:         1,875 Euros
                   0,025 Kg/0,05 KWp/12000 RPM        linear: <      1        EURO
                   0,0125 Kg/0,025 KWp/12000 RPM    linear: <      0,5     EURO
with iron-nitride,alu/sodium coils/plastic bonded iron,.....     dividing with  : 4
Micro-motors/generators/turbines  production :
for
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=52&ND=3&adjacent=true&locale=en_EP&FT=D&date=19800902&CC=US&NR=4220870A&KC=A#
and Solar Passive Energy Standart buildings HVAC with C.O.P. 5 / 0,9 published power savings = 5/0,1  ~ C.O.P. 50
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19951107&CC=US&NR=5463914A&KC=A#
the transmission parts production with liquid plastics (Nylon-type) or liqid metals ,casting
So related the Duke Uni 75 Watt nominal motor equipped low-e mobile we get f.e. a C5 Sinclair citycar for average 30 e-Watt per hour consume !
The electric turbine also in future use for air-mobiles :
https://en.wikipedia.org/wiki/Colomban_Cri-cri
published airplane engine hp power ?
The first flight of the prototype was made on 19 July 1973 and within a few days it had proved to be easy to fly and capable of aerobatics, being stressed to +10g and -5g. It was powered by two Rowena 6507J single cylinder two-stroke engines, each giving 6.7 kW (9.0 hp) and weighing 6.5 kg (14.3 lb).[6]
remembering cars ic engine compared electric drive :
https://overunity.com/6763/energy-amplification/msg548537/#msg548537
http://www.evalbum.com/motor
Gas engines are rated at their peak hp, electric motors are rated at their continuous hp.
The peak hp of an electric motor is usually 8 to 10 times its continuous rating.
Here clearly,for high RPMs,the 2007/2008 developped electric drive has its best application field :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20091130&CC=PT&NR=104078A&KC=A#
One CriCri with 1 KWh electric power consume per flight hour ?  ;D Le dernier CRI for some start-ups in the air-taxi sector !
A 2000 Euros DIY-kit CriCri ? By excellent self-organisation no problem :
https://de-m-wikipedia-org.translate.goog/wiki/CriCri?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de
                                                        It had a curb weight of only 63 kg                                                        2000 Euros/63 Kg ~ 30 Euros/Kg By material kind costs/price to compare :https://m.made-in-china.com/hot-china-products/Tricycle.html?gclid=EAIaIQobChMIsoDR-ZeT9QIVU_BRCh14ywuNEAAYAyAAEgJMmfD_BwEhttps://m.made-in-china.com/product/T414-Cabin-Scooter-E-Scooter-3-Wheel-Electric-Scooter-for-Passenger-1908506242.html               < 2000 US$ fob factory for 330,85 Kg material ~  6 US$/Kg
                                     CriCri for first : 2000 Euros - later: 1500 Euros - finally target :  1000 Euros ?  :o ::) ;)
                           https://www.thedrive.com/news/38555/wide-streets-massive-garages-meet-the-neighborhoods-designed-for-pilots-and-small-planes                              above and below the clouds    https://www.youtube.com/watch?v=fZMFF8QH3ewwmbrOCWL
Quote from: lancaIV on January 02, 2022, 09:15:44 AM
with material use optimized Yost/Schiller/Arestov motor/turbines
such ultralights
https://www.aviationnepal.com/top-10-most-popular-ultralight-aircraft/
like the Columban CriCri can become equipped with power saving propulsion systems
                                         like
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1#
The 6,000 rpm flywheel can be compared to a large rotor, and just like the rotor in a 50hp engine, it is not kinetic energy which provides work, but electromagnetic action30 which converts into torque. This action is internal to the mass of the flywheel, the latter is "traversed" by electrical energy, motors supplied by contact wipers, or the like. Kinetic energy is invariable, all moments of internal torques cancel out with respect to the axis of the steering wheel. The output torque at the shaft 25 at 6000 rpm is the same as the output torque of the moving interior device, flywheel. This device equipped with four 500 watt motors, i.e. 2000 wats, with electronic management, is capable of the same torque and power performance as a motor.
                    thermal 50 hp ic engine equivalent 4x 500 Watt nominal with 1000 Watth consume :
50 hp thermal engine, while providing ancillary services including heating and preheating of the vehicle.
5 The average consumption is of the order of IOOO wats per hour.
                                                    the first CriCri has had 2x 9 hp(peak) ic engines !
Quote from: lancaIV on January 02, 2022, 12:05:45 PM
https://www-n--tv-de.translate.goog/politik/Chinesische-Bauern-klagen-ueber-Solarstrom-article23031784.html?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de
35.000 sqkm = 35.000.000.000 sqm
China Academy of Engineering expert Jiang Yi told a state news website that China will need 30,000 to 40,000 square kilometers more land to meet its renewable energy needs.
Over 10.000 KWh per sqm solar cell energy generation,possible,wishable  ?!
https://worldwide.espacenet.com/searchResults?AB=&AP=&CPC=&DB=EPODOC&IC=&IN=&PA=paul+marzahn&PD=&PN=de&PR=&ST=advanced&Submit=Search&TI=&bcId=1&locale=en_EP&page=0&return=true
End 80´ performance per solar panels chamber :
12 x 13 W artificial solar= CFL light to 350 Wp (5 x 70Wp; 5,25% conversion efficiency) solar panels and light concentrated by mirror to 650 Wp output
similar https://www.youtube.com/watch?v=FKhszB4E1_M
2010-2020 : solar cells now in the 20-30% em radiation spectrum conversion efficiency ( tandem 45%+)
from 650 Wp more than 4 times improvement to 2600 Wp+
the simple mirror 80´improvement factor 650/350 = 1,85
with Hyperstealth solar foil https://www.youtube.com/watch?v=l1QZAax0-XA near 3,0 as output amplifiation factor
350 Wp x 4x efficiency improvement x 3x the amplifier foil factor : 4000 Wp+ per hour net ( after lamps consume subtraction)
4 KW x 8766 hours = 1 year =           35.000 KWh per sqm 1 cbm solar tube/chamber energy generation , one stage/2.stages/3. ......
2 stages, assuming 2 metres hight:  70.000 KWh per sqm
installation in cave, .....,everywhere where is a free sqm area (and lamps energy delivery source )
Comparison wind power plant,39.000 sqm area :
2500 KW and 27% effective wind energy conversion = 6.000.000 KWh per annum
6.000.000 KWh/39.000 sqm =              +- 154 KWh per sqm area
Solar energy conversion by not concentrated area and 1400 KWh solar radiation/sqm/a and 20% conversion efficiency =
                                                              up to 250 KWh/sqm/a ,untracked
25% conversion efficiency :                   up to 300 KWh/sqm/a ,untracked
                                 The artificial solar tubes/chamber are world-wide install-able !
펌글)
    언어의 의미는 맥락에 따라 결정된다. 자유에 책임이 따른다는 표현도 물론 가능하다. 그런데 굳이 사랑에는 이별이 따른다고 말해서 사랑이라는 근사한 단어를 엿먹일 필요가 있을까? 이건 초를 치는 거다. 회자정리라 했으니 만남이 있으면 반드시 이별이 있다. 언제 이별해도 한 번은 이별한다. 한꺼번에 교통사고로 가는 수도 있지만 그래도 이별은 이별이다.
    '너희는 자유다.' 하고 생색을 낸 다음 '책임이다.' 하고 뒤통수친다면 곤란하다. 언어도단이라 하겠다. 물론 책임이 따를 수 있지만 그건 참된 자유가 아니다. 진정한 자유에는 책임이 없다. 자유를 행사하다보면 권력을 휘두르게 되고 권력에 맞대응이 있을 뿐이다. 즉 다른 사람에게 피해를 주지 않으면 책임이 없다. 남에게 피해를 주는 짓은 참된 자유가 아니다.
    사람들은 짝짓기 좋아한다. 자유에는 책임으로 대칭시키고 권리에는 의무로 대칭시킨다. 이런 식의 이분법적 사고가 위험하다. 권리에 의무가 따르는게 아니다. 의무는 사실 권리의 전개된 형태다. 노예는 세금을 내지 못한다. 납세의 권리다. 노예는 군대에 가지 못한다. 입대의 권리다. 교육의 의무라고 하는데 교육받을 권리다. 납세자에겐 참정권이 있다.
    원래 뭐든 주는 자에게 권리가 있다. 그것이 구조론의 마이너스 원리다. 받는 자에게는 권리가 없다. 인간에게 기본 인권이 있다는 것은 인간은 태어나면서부터 뭔가를 국가에 줬다는 거다. 일단 인구를 늘려줬다. 프롤레타리아라는 말은 세금 낼 돈은 없지만 병역자원을 냈으니 나름 밥값은 했다는 거다. 여자도 병사를 만들어낼 수 있으니 뭔가를 국가에 냈다.
    인간은 아기 때부터 가족의 결집에 기여한다. 아기가 있으므로 가족이 화합한다. 그러므로 모든 인간은 탄생과 동시에 기본인권을 가지며 기본인권은 국가에 뭔가를 제출했다는 거다. 국민이 국가에 준 것이 있다. 주는 것이 권리다. 주식회사라도 투자자에게 권리가 있다. 그런데 말이다. 일부 외상으로 남겨뒀다가 나중에 제출하는 수도 있는데 그것이 의무다.
    애프터서비스다. 삼성과 엘지가 물건만 팔고 입을 닦는 게 아니라 몇 년간은 고장에 책임을 져야 한다. 그것이 의무다. 권리는 먼저 주고 큰소리 치는 것이고 의무는 나중에 주는 것인데 어느 쪽이든 주는 것이다. 그러므로 권리와 의무를 대칭적으로 보는 시선은 위험하다. 나는 의무를 안질테니까 권리도 빼줘라 이런 식으로 농단하기 없다. 이미 주고 태어났다.
    주고받기 상거래가 아니다. 의무를 주고 권리를 받는다는 식의 발상이 위험하다. 권리든 의무든 모두 주는 것이며 권리는 태어나기 전에 주고 의무는 적당한 때 준다. 모두 주는 것이며 준 만큼 각자에게 돌아갈 몫이 있다. 세상은 일원론이다. 자유와 책임 그리고 권리와 의무를 대칭적으로 보면 이원론이 된다. 그것은 입자로 보는 관점이다. 세상은 질로 봐야한다.
    질은 결합한다. 결합되어 하나다. 자유가 있다는 것은 권력이 있다는 것이며 다른 사람에게 피해를 주지 않는 이상 자유에 책임은 없다. 자유는 그냥 일방적으로 자유다. 단, 민폐를 끼치는 자는 자유를 손상당한다. 자유가 없는게 아니고 자유를 통제할 기술이 없는 것이다. 이는 정신병자가 병동에 격리되는 것과 같다. 정신병자에게도 물론 자유와 인권은 있다.
    본인이 써먹지 못할 뿐. 환자에게도 자유는 있다. 단지 신체가 불편해서 써먹지 못할 뿐. 병원에 입원한 환자가 왜 나는 자유가 없지 하고 화를 내면 안 된다. 자유가 있다. 환자가 병원을 나서려면 민폐를 줄 수 있으므로 돈으로 해결해야 한다. 돈이 많으면 환자도 간호사를 대동하고 여행할 수 있다. 자유를 빙자하여 민폐를 가한다면 그건 별도의 사건이 된다.
    교도소에 갇힌 재소자에게도 자유가 있고 인권이 있지만 환자와 마찬가지로 그 자유와 인권을 사용하지 못한다. 날아가는 비행기에서 중간에 하차할 수 없는 것과 같다. 이는 물리적 현상이다. 재소자가 자유와 인권을 말하는 것은 몰래 비행기에 탑승한 사람이 중간에 내려달라는 말과 같다. 가끔 비행기 바퀴에 숨어드는 사람 있다. 그러다가 얼어죽는 것이다.
    참된 사랑에는 이별이 없고 참된 자유에는 책임이 없고 참된 권리에는 의무가 없다. 에너지는 한 방향이다. 사랑하면 이별하지만 그것은 논외다. 살면 언젠가 죽게 되지만 삶 안에는 죽음이 없다. 자유를 누리다가는 뒷탈이 나곤 하지만 자유 안에는 뒷탈이 없다. 사랑이든 자유든 권리든 좋은 단어다. 나쁜 단어를 붙여서 물타기 하지 마라. 초를 친다면 곤란하다.
    근사한 단어는 근사하게 써야 한다. 자유에는 책임이 따르는게 아니라 청소년은 부모의 지갑에 의지하는 만큼 민폐를 끼치므로 자유가 별로 없는 것이다. 자유는 타인에게 민폐를 끼치지 않을 능력만큼 주어지며 민폐를 끼치면 보통 돈으로 해결하는데 청소년은 돈이 없어 자유가 제약되며 결론적으로 청소년은 자유가 조금밖에 없는 거라고 솔직하게 말하자.
    자유는 자유다. 권리는 권리다. 사랑은 사랑이다. 에너지는 언제라도 일방향성을 가진다. 뒤에 꼬리표를 붙이지 말라. 아기는 요람을 벗어나지 못한다. 자유가 없는게 아니고 있어도 써먹지 못한다. 자동차가 없는게 아니고 운전기술이 없다. 운전면허가 없는 청소년이나 현지적응 안 된 이방인들은 권리를 제약당한다. 권리가 없는게 아니고 누리는 기술이 없다.
    자유는 자유대로 있고 권리는 권리대로 있다. 기술 만큼 누리는 것이니 예술가는 더 누린다.
https://blog.naver.com/whatsthelife/221320131164
자유는 원칙이 없다.
자유에 원칙이 부여되는 순간 자유가 아니다.
누리는 기쁨도, 감정의 솔직함도, 인간미도, 거짓도, 진실도, 아름다운 잔악과 죽음도 모두 자유다.
자유의 적은 죽음이다.
자유의 기반이 인간의 욕구본능에 있어서다.
자유의 끝이자 영원한 자유의 시작일테니?
죽음이 영원한 자유의 시작이 되려면 죽음예찬이 필요하다.
네가 자유하는 순간부터 빛과 어둠과 모든 율법은 네가 투쟁해야 할 상대이자, 누리는 대상이자, 예찬이 필요한 죽음이다.
Freedom has no principles.
The moment freedom is given a principle, it is not freedom.
The joy you enjoy, the honesty of your emotions, the beauty of humanity, the lies, the truth, the beautiful cruelty and death are all freedom.
The enemy of freedom is death.
The basis of freedom lies in the human instinct to desire.
Will death be the end of freedom and the beginning of eternal freedom?
For the death of liberty to be the beginning of eternal liberty, the praise of death is necessary.
From the moment you are free, light and darkness and all the laws are your opponents against which you must fight, the objects you enjoy, and the death you need to glorify.
자유자 철학의 관여는 여기까지다.
종교의 관여는, 현생의 자유까지 율법과 권면이란 이름으로 억압한다.
영원한 자유이자 죽음의 절대자 이름으로.
선택에 관한 언질이 아니다.
철학자는 자서전을 쓰는 사람들이다.
철학자는 자신이 알고있는 언어적 능력을 기록으로 남기는 사람들이라 신종 단어를 배우는 것 말고 배울 것이 없는 사람들이다.
자유가 역대 철학자들을 통해 유지됐다고하는 철학의 계보가 아니라, 언어적 능력이 생대적으로 뛰어난 사람들의 기록이다.
자유는 누구를 통해 전달된 것이 아니다.
도리어 철학자들을 통해 자유가 억압당했다.
맑스같은 투쟁 철학은 말할 것도 없이, 우상론 철학은 자유를 억압하는 종교의 다른 이름이다.
자유는 제약 설정이 없다.
악마의 광포함도, 신의 선량함 자유다.
철학자는 자유가 제약되는 현세에서 선생이 될 자격이 없다는 뜻이다.
자유하는 사람들의 선생으로는 완전하게 자유하는 철학자다.
역사이래 이런 철학자는 없다.
앞으로도 나타나기 어렵다.
죽음의 권면은 모든 것 위에 있다.
주제가 자유이든,,,,,,,,,,,,자유에 책임이 따르든?
남에게 피해를 주는 짓은 참된 자유가 아니다.   ,,,,,?
무한의 욕구본능 자유하다 삼천포로 빠지는 말실수는 아니다.
행렬을 한 칸 떨궈놔 행렬 결론처럼 보이는 서론이다.
철학의 자유권면은 책임없는 자유지만,
종교의 자유권면은 빛과 죽음의 처벌이 기다린다.
철학은 자유란 이름으로 죽음에서 끝나지만,
보편적 종교는 영혼구원이 최대 목적이다.
종교인이 자유하면 영혼구원까지 얻겠지만,
종교인이 범죄하는 경우 목회자가 태반인 것도 교리와 자유를 자의대로 분리해서다.
욕구본능 자유로 범죄하는 철학의 경우는, 고대부터 권력자들과 함께했다.
언어적 철학의 소용은 배우는 사람들이 많다.
무소불위 권력이 철학을 배운다.
권력은 또한 종교를 이용했다.
수십억이 죽은 것은 종교에 의해서고, 욕구본능 자유철학의 개입이다.
성서에도 자유가 있다.
갈라디아서 5장 [개역한글:NASB]
1   그리스도께서 우리로 자유케 하려고 자유를 주셨으니 그러므로 굳세게 서서 다시는 종의 멍에를 메지 말라
It was for freedom that Christ set us free; therefore keep standing firm and do not be subject again to a yoke of slavery.
굳세게 서서 멍에를 멘 것에 대한 역발상이다.
바울의 자유는 죽음과 빛을 십자가로 짊어진 그리스도를 통하는 자유다.
눈뜬 소경(Djed)의 전유물이거나 기도하는 사람들의 것이다.
빛과 어둠 모두를 사랑해야 하는 아주 아주 제약이 많은 자유다.
[자유에는 책임이 따른다]
바울의 말에서 시작했다.
욕구본능 자유를 신인냥 섬기는 철학에 의해 빛/어둠/죽음을 신으로 섬기는 종교가 비판 당한다.
누가 누구를 비판할 입장이 아니다.
빛과 어둠이 준 자유나, 빛과 어둠을 신으로 섬기는 자유나 똑같다.
그러나
완전한 자유란 이름으로 철학의 타도 대상된 종교는 근세부터 동네북이였다.
중세 많은 사람들이 종교권력, 종교재판으로 죽거나 침묵을 강요당했다.
불행한 역사라고 표현하기 어려울 정도로 참혹한 시대였다.
과거 종교 권력자들은 백번 죽어 마땅한 자들이다.
지옥은 그들의 것이다.
이의 없다.
별개로,
소크라테스가 죽은 것은 종교인들에 의해서가 아니라, 아테네 유명 정치인들이 그리스의 법과 신들의 이름으로 죽였다.
또한 소크라테스는 철학자가 아니라 아몬의 신탁을 받던 유명 종교인이다.
종교인-소크라테스를 철학이 강탈한 것은, 스파르타(펠로폰네소스반도)를 고향으로 둔 플라톤 같은 무신론자 제자들에 의해서다.
플라톤이 무신론자였는지는 알려진게 없으니, 그 가 쓴 [소크라테스의 변명]으로 유추하자면 [아몬의 변명]과 다름없다.
추론의 영역이다.
다윗의 시온이며, 바울의 시온이 플라톤의 고향으로 향하고 있는 것은, 틈만나면 플라톤의 고향을 약탈하던 해적들의 고향 크레테(갑돌)가 해적-바리새인들의 고향이라서다.
약탈은 전리품이고, 어둠의 수하인 소경-Djed은 그렇게 그리스의 빛을 약탈해서 눈을 떴다.
태반의 문제가 몰라서 발생한다.
기독교 성서 언어는 어렵다.
태반이 본질을 회피한 은유(a metaphor)와 비유(figures of speech)의 문장들이다.
본질을 알아도 드러내기 어려운 언어다.
더 큰 문제는 언어 해석할 능력도 없으면서 잘못된 해석으로 사람들을 속이는 사람들이다.
목회자는 모조건 일반화다.
맞든 틀리든 배운대로 써먹는다.
천국이든 지옥이든 맺힌 한들이 많은 것 같다.
목회자를 부모로 뒀거나 교회에 미쳐있거나 갖다바치는 돈이 많으면 많을수록 비판강도가 세진다.
도올처럼, 누구처럼.
그런다고 부모가 회심한다든?
천국이 목적이면 어렵다.
씨알도 안먹힌다.
위 내용을 구글번역기 자동해석하면 [경제적]으로 변한다.
주요 내용이 왜곡되고 사라진다.
[우아한] 것과는 거리있다.
출애굽기 3장 [개역한글:NASB]
2   여호와의 사자가 떨기나무 불꽃 가운데서 그에게 나타나시니라 그가 보니 떨기나무에 불이 붙었으나 사라지지 아니하는지라
3   이에 가로되 내가 돌이켜 가서 이 큰 광경을 보리라 떨기나무가 어찌하여 타지 아니하는고 하는 동시에
4   여호와께서 그가 보려고 돌이켜 오는 것을 보신지라 하나님이 떨기나무 가운데서 그를 불러 가라사대 모세야 모세야 하시매 그가 가로되 내가 여기 있나이다
5   하나님이 가라사대 이리로 가까이 하지 말라 너의 선 곳은 거룩한 땅이니 네 발에서 신을 벗으라
The angel of the LORD appeared to him in a blazing fire from the midst of a bush; and he looked, and behold, the bush was burning with fire, yet the bush was not consumed.
So Moses said, "I must turn aside now and see this marvelous sight, why the bush is not burned up."
When the LORD saw that he turned aside to look, God called to him from the midst of the bush and said, "Moses, Moses!" And he said, "Here I am."
Then He said, "Do not come near here; remove your sandals from your feet, for the place on which you are standing is holy ground."
출애굽기 4장 [개역한글:NASB]
1   모세가 대답하여 가로되 그러나 그들이 나를 믿지 아니하며 내 말을 듣지 아니하고 이르기를 여호와께서 네게 나타나지 아니하셨다 하리이다
2   여호와께서 그에게 이르시되 네 손에 있는 것이 무엇이냐 그가 가로되 지팡이니이다
3   여호와께서 가라사대 그것을 땅에 던지라 곧 땅에 던지니 그것이 뱀이 된지라 모세가 뱀 앞에서 피하매
4   여호와께서 모세에게 이르시되 네 손을 내밀어 그 꼬리를 잡으라 그가 손을 내밀어 잡으니 그 손에서 지팡이가 된지라
Then Moses said, "What if they will not believe me or listen to what I say? For they may say, 'The LORD has not appeared to you.'"
The LORD said to him, "What is that in your hand?" And he said, "A staff."
Then He said, "Throw it on the ground." So he threw it on the ground, and it became a serpent; and Moses fled from it.
But the LORD said to Moses, "Stretch out your hand and grasp it by its tail"--so he stretched out his hand and caught it, and it became a staff in his hand--
color
자살고픈 비트겐슈타인
https://www.youtube.com/watch?v=XJrxMwUYHns&t=199s
멋있는게 아니라 죽고싶어 환장한 자들 특징 그래로 나타난게야. 8) 8)
자살한 고흐가 생전에, 모세처럼 여호와를 만나고 싶었던가,
많은 그림에 불에 타지않는 나무를 많이 그려놨어. 8) 8)
웃픈얘기야...... 8) 8)
(웃기고 슬픈 이야기)
Vincent van Gogh
https://en.wikipedia.org/wiki/Vincent_van_Gogh
작년에 귀순한 기계체조 탈북민이 뭐땀시 일년만에 다시 월북했다는겨?
color
color
tuk-tuk이가 그랴? ;D ;D 8) 8)
공짜 좋아하는 사람은 똥구멍에 털난다 아놈아~ ;D ;D ;D ;D ::) ::) ;D
현재 국힘이 얼마나 개판이 되었는지 오늘자 사건들만 보면
미제사건전담
http://www.ilbe.com/view/11387324857
2022-01-03 20:11:03
1월 3일에 있었던 일들만 정리한 것임
1. 신지예 사퇴 →
2. 선대위 6개 본부장 전원 사퇴 예정 →
3. 윤석열 향후 일정 잠정 중단 →
4. 김종인 "선대위 개편 후보 동의 구할 필요 없다" →
5. 김종인 "윤석열은 연기만 잘해라" →
6. 권성동, 사의 표명 보도에 "사실무근" →
7. 원내대표, 정책위의장 사퇴 →
8. 이준석 외통수 →
9. 김종인 쇄신 선언, 윤석열도 몰랐다 →
10. 김한길 사의 표명 →
11. 김기현 김도읍 권성동 사의 표명 →
12. 김종인, 김병준도 사의 표명 →
13. 이준석 "손학규한테 배운 게 많다. 조수진 김재원 사퇴한다면 대체 최고위원 임명할 것. 최고위원에 안철수 임명할 수도" →
14. 김종인 사퇴 부인 →
15. 김종인 사의 밝히며 윤석열 캠프 떠나 →
16. 나경원, 이준석 저격 →
17. 국민의힘, 김종인 사의 발표는 "착오" →
18. 국힘 선대위 "신지예 활동 안한다" 신지예 "확인을 해봐야할 것 같다. 그쪽(선대위) 대변인이 얘기한 거고, 새시대위에서 얘기한 건 아니다. 계속 활동하기로 내부 논의"
결론 : 개판
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
ㅋㅋㅋㅋㅋㅋㅋㅋㅋㅋㅋㅋㅋ 8) 8)
넣었다뺐다반복
http://www.ilbe.com/view/11387329971
2022-01-03 20:48:11
정권수사한 검사들 싹다 좌천시킨 이성윤이 서울고검장으로 있고,
원래 이성윤 자리였던 서울중앙지검장 자리에는 박범계 후배가 있음 ㅋㅋㅋㅋㅋㅋㅋㅋㅋ
가세연이 그동안 방송에서 주장한 민주당쪽에서 이미 사건을 알고있다는 사람 = 박범계임
그리고 그 박범계의 후배가 서울중앙지검장이고 ㅋㅋㅋㅋㅋ
대충 혐의없음으로 결론날 확률 518%임. ;D ;D 8) 8)
오사카의대 알아주는데냐? 1 ᄋᄋ(223.62) | 2022.01.03 17:15
조회수 2011 | 추천 151 | 댓글66
project
【国民への緊急メッセージ】
大阪市立大学医学部・井上正康名誉教授より
DNA O 遺子組換葉!!! mRNAワクチンは安全&有効性が不明の 第3&4 相試験中の実験薬で
接種者は全員モルモットであり 今世界中でその実験結果が出始めている!!
<判明した事実>
新型コロナ病態の本質は血栓症 2 기
소 (Circulation & Y- 究所) BmRNA GEO業 0 21年 10 月 0
1325 ~ 9 月1
It 5.1 以上 3後因大半在血性 書 (Circulation & ) OmRNA型は卵巣や精巣にも集積するが感染予防と重症化抑制効果は低い ( & 05度もの PCR陽性波で無症候性感染した日本人にはコロナのT細胞免疫記憶があり (理化学研究所より、重症化&死亡率は著している。但し、 9日 依 存性 ADE O LTBS(Cell), 接種継続で感染病態が重症化するフェズに入りつつある!!
大半の医師がこの事実を知らずにコロナ無リスクの児童や 生世代(接種!
の接種後に異変を感じたら早急に肺CTと血中Dダイマーを検査して血栓予防治療を依頼し、 死亡時には火事前に病理解剖"を依頼する!! オミクロン株感染者の大半は無症状で急速に収東予定であり、 ワクチンは逆効果になるのでメディアに隠されて過剰反応しない事が賢明!! 医師は「弱毒株への自然感染が最良の免疫軍事訓練である事実と感染免疫学の基本」を 思い出し、いい歳の大人は正気に返り国民の生命を守る為に正しく起しよう!!
政府はポピュリズムを排して人災的国難を終らせよ!!
"風邪は万病の源なので「口腔ケア、手法、うがい、鼻洗浄、トイレ消毒」をしながら仕事や勉学に励もう
국민여러분에게 긴급메세지
DNA백신은 유전자조작약 mRNA백신은 안전 유효성 불명의 제 3,4차 임상시험 중의 실험약으로 접종자는 전원 모르모트 (실험쥐)이며 | 전세계에서 실험결과가 나오고 있다.
판명된 결과 1. 코로나질환의 본질은 혈전증 2. 스파이크는 혈관장애성혈전독 3. mRNA형은 심근염과 심장병유발약 4. 21년 10월까지의 접종후 단기사망자는 1325명이 며 9월의 초과사망자수는 5.1만명 이상 5. 접종후 사망원인의 대부분은 혈전성순환기장애 (일본후생성) 6. mRNA형은 난소와 정소에도 집적 축적되지만 감 염억제와 중증화억제효과는 낮다.즉 코로나 예방효과 는 없다. 7. 5도 PCR 양성파로 무증상 감염된 환자에게는 코로 나의 T세포면역 기억이 있어 중증화 사망률은 줄어들 고 있다.다만 8. 일본에서도 항체의존성 증강 ADE의 항체가 발견되 고 있고 * 중요 백신의 연속된 접종지속으로 감염증세가 중증 화 되는 경향이 높아지고 있다.
| 대부분의 의사들이 이사실을 모르고 코로나에 전혀 무해한 아동접종과 전세대에 접종을 하고 있다.
9. 접종후에 이변을 느끼면 신속히 폐CT와 혈중 D 다 이머를 검사해서 혈전예방치료를 의뢰하고 사망후에는 반드시 화장전에 병리해부를 의뢰한다. 정 확한 사망원인규명
오미크론감염자의 대부분은 무증상이며 급속히 증상 이 완화될 것이며 백신은 역효과이고 미디어에 속아 과민반응하지않는 것이 현명하다.
의사는 약독균의 자연감염이 최선의 면역군사훈련이 라는 사실을 잊지말고 감염면역학의 진실을 상기하여 현명한 지식인 어른으로서 제대로된 정신으로 돌아가 일본국민의 생명을 보호하고 지키기 위해 궐기한다.
일본정부는 포퓰리즘을 배제하고 인재적국난을 끝내 라!!
| 오사카 시립대학 의학부 명예교수 일동
개념
비추
;D ;D ;D ;D 8) 8)
https://rumble.com/vroyoj-the-truth-about-vaccines..html
