Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Самый Простой Вечный Двигатель из Авто Генератора И Двигателя
https://www.youtube.com/watch?v=thvA4bQ2KHs
알아내기 쉽지 않을게야.... ;D 8)
내도 의외의 곳에서 실마리를 풀었다네. 8)
유튜브 구독자가 많다는게 이래서 좋은게야. ;D ::) ;D ::)
color
Update Free energy forever no wind no solar no gas READ DISCRIPTION!!!
https://www.youtube.com/watch?v=TpvXEp1Idis
The World 1st(portable) Free Energy Generator. Car Alternator spinning clean Power. No Emission.
https://www.youtube.com/watch?v=q6x0JIB0vYA
Here we take two automotive alternator, mount it together side by side on a set of 5/8 threaded rods. With one alternator converted in to brushless three phase 12-40 DCV motor and the other alike alternator in its OEM standard battery charging capability. The brushless AC/DC motor spinning the alternator, let see what happen?. This video is part of a experiment to electrify the circuit with 14.5 DCV@ 100Ah with BLDC motor consumption below 30Ah at 12-24 DCV or approximately 40DC volts for more motor speed(RPM). This device can be consider to be a self-power AC/DC Eletric generator, that require no fuel or physical action from man or nature.  The self power Eletric generator consumes 10% energy of the its total output. the self-power electric generator also known as the "ULTIMOTOR"(DYNAMO) is constructed of three phase permanent magnet rotor inside a AC/DC three phase coil field. the 3-phase brushless AC/DC motor only require about 10-15amp at 12- 40dcv. The car alternator produce 14.5v of 100amp @3000rpm. The brushless AC/DC motor uses the same battery energy that the alternator is recharging. The #alternator is capable of recharging many banks of batteries(wet-cell type or others) while providing electricity to refrigerator, air conditioner, washing machines, micro wave and many other house utility electronic device. The self-power electric generator can work in conditions of no sunlight or wind and off-grid with no fuel or fire and smoke. THIS IS ONE OF THE BEST CLEAN ENERGY DEVICE. non pollution. safe in the home. low voltage. No electrical Shock. it's all automotive energy inverted to meet your 120-240 AC voltage needs. a similar device can be found with two permanent magnet alternator working side by side. its a much quieter device when in operation. Since it does not have to brake its rotation on a electro-magnetic field found in a alternator. stay tune
Use a six volt heater blower motor with a three way toggle or dimmer switch to control speed. Then add a capacitor from a aftermarket car stereo system. And add it between your charging alternator and your battery. Then add an alternator for AC power which will be 120 to 240v @ 90amps (enough to power your house or weld) by taking out the diode pack and running your three wires off the coils through an AC regulator ,(can be found in most inverter generators) and then to an AC outlet. (You can put a small breaker panel with 100 amp blowable breaker or a 100 amp fuse in between your reg and your outlet which I highly recommend) so recap auto heater blower motor high rpm low power usage pully to unaltered car alternator with double pully which runs 12v back through a capacitor to battery for continual charge and consistent motor rotation. From second pully to a second car alternator altered by removing diode pack for 120-240v AC power @90amps. Wire the three coil wires through an AC regulator into a small fuse panel with 100 amp breaker. Or through reg to 100 amp fuse each for both the red and white wires. Then to an outlet. Now 100 amps is too much for most appliances or electronics to take at once so I recommend breaking down the hundred amps into one 30 amp outlet and three 20 amp outlets. You'll never need to charge your batteries and will be able to run absolutely anything. The more you consume at once though the more  12v capacitors will be needed  wire them in series.
Electric Motor Generator
https://www.youtube.com/watch?v=daP1zkUqoeU
color
