Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 28 Guests are viewing this topic.
color
Quote from: AlienGrey on August 11, 2021, 11:43:52 AM
some thing wrong here in this circuit
Quote from: color on December 05, 2020, 08:20:06 AM
Пояснения по генератору
https://www.youtube.com/watch?v=dogI9z4mZoY
Пояснения по схеме реального БТГ
https://www.youtube.com/watch?v=qva7Z5R2tgY
Пояснения по схеме реального БТГ продолжение
https://www.youtube.com/watch?v=dJWwQUdQ_RU
Пояснения по генератору Видео №4
https://www.youtube.com/watch?v=4XPA__Kfets
Пояснения по настройке генератора Алексеева
https://www.youtube.com/watch?v=kDnRYnH6B44
ВЫСОКИЕ ТЕХНОЛОГИИ В КАЖДЫЙ ДОМ
https://www.youtube.com/channel/UCdBuEc6CBlLXeX-5ZXHgW-g/videos
missispots
https://www.youtube.com/user/missispots/videos
color
K9 자주포 이집트에 수출..."2조원 규모 역대 최대"
https://www.hani.co.kr/arti/politics/politics_general/1029408.html
2조원의 십일조가 얼마더냐.
그래그래 2000억원이니라.
아빠 농협통장번호 그대로 있느니라.
아브라함과 건달바성 후까시 드론 멜기세텍의 계약은 아직도 유효하니라.
계약이 무산될시 대한민굴 헌법이 규정한 모든 국토를 이방인에게 양도하겠다.
Floor
Quote from: color on February 01, 2022, 10:39:08 AM
Update Free energy forever no wind no solar no gas READ DISCRIPTION!!!
https://www.youtube.com/watch?v=TpvXEp1Idis
The World 1st(portable) Free Energy Generator. Car Alternator spinning clean Power. No Emission.
https://www.youtube.com/watch?v=q6x0JIB0vYA
Here we take two automotive alternator, mount it together side by side on a set of 5/8 threaded rods. With one alternator converted in to brushless three phase 12-40 DCV motor and the other alike alternator in its OEM standard battery charging capability. The brushless AC/DC motor spinning the alternator, let see what happen?. This video is part of a experiment to electrify the circuit with 14.5 DCV@ 100Ah with BLDC motor consumption below 30Ah at 12-24 DCV or approximately 40DC volts for more motor speed(RPM). This device can be consider to be a self-power AC/DC Eletric generator, that require no fuel or physical action from man or nature.  The self power Eletric generator consumes 10% energy of the its total output. the self-power electric generator also known as the "ULTIMOTOR"(DYNAMO) is constructed of three phase permanent magnet rotor inside a AC/DC three phase coil field. the 3-phase brushless AC/DC motor only require about 10-15amp at 12- 40dcv. The car alternator produce 14.5v of 100amp @3000rpm. The brushless AC/DC motor uses the same battery energy that the alternator is recharging. The #alternator is capable of recharging many banks of batteries(wet-cell type or others) while providing electricity to refrigerator, air conditioner, washing machines, micro wave and many other house utility electronic device. The self-power electric generator can work in conditions of no sunlight or wind and off-grid with no fuel or fire and smoke. THIS IS ONE OF THE BEST CLEAN ENERGY DEVICE. non pollution. safe in the home. low voltage. No electrical Shock. it's all automotive energy inverted to meet your 120-240 AC voltage needs. a similar device can be found with two permanent magnet alternator working side by side. its a much quieter device when in operation. Since it does not have to brake its rotation on a electro-magnetic field found in a alternator. stay tune
Use a six volt heater blower motor with a three way toggle or dimmer switch to control speed. Then add a capacitor from a aftermarket car stereo system. And add it between your charging alternator and your battery. Then add an alternator for AC power which will be 120 to 240v @ 90amps (enough to power your house or weld) by taking out the diode pack and running your three wires off the coils through an AC regulator ,(can be found in most inverter generators) and then to an AC outlet. (You can put a small breaker panel with 100 amp blowable breaker or a 100 amp fuse in between your reg and your outlet which I highly recommend) so recap auto heater blower motor high rpm low power usage pully to unaltered car alternator with double pully which runs 12v back through a capacitor to battery for continual charge and consistent motor rotation. From second pully to a second car alternator altered by removing diode pack for 120-240v AC power @90amps. Wire the three coil wires through an AC regulator into a small fuse panel with 100 amp breaker. Or through reg to 100 amp fuse each for both the red and white wires. Then to an outlet. Now 100 amps is too much for most appliances or electronics to take at once so I recommend breaking down the hundred amps into one 30 amp outlet and three 20 amp outlets. You'll never need to charge your batteries and will be able to run absolutely anything. The more you consume at once though the more  12v capacitors will be needed  wire them in series.
Electric Motor Generator
https://www.youtube.com/watch?v=daP1zkUqoeU
Why go to so much trouble, when its easier to insert
two wires into the opposite ends of a large cucumber for
an endless supply of electricity ?
             OR
            free HHO
Buy a little unobtainium off ebay then dissolve 19 mg in 8 oz reagent grade
celery juice along with 2 teaspoons of  NaCl.    8)
                             vwala
color
Quote from: Floor on February 03, 2022, 09:04:53 PM
             OR
            free HHO
                             vwala
Show me the car generator you're experimenting with.
https://www.youtube.com/watch?v=h-vJEALeZMw
