Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Tuning the coil capacitor
https://www.youtube.com/watch?v=FQjNGhZHzqY
지난 10년간 뭐하는지 모르겠지만 '이보'도 만만찮어. ;D ;D ;D ;D ;D ;D 8) 8)
color
Quote from: ideas99889 on February 09, 2022, 03:37:12 PM
    I think a main reason, or, the other main reason, I posted this idea,  is that I was hoping to prompt someone or some company, to make an alternate internet-search-engine+results-provider,  and possibly also an alternate internet-based-email-service-provider.
    In the english speaking world, the only 'effective' search engine seems to be google .  Basically I was hoping someone could make a company like google,  but with much much fewer services,  a search-engine+results-provider and maybe email service ( and the other services mentioned in this thread ).
  Looking at  https://en.wikipedia.org/wiki/Search_engine  ,  it looks like there's no expectation that there will be an an alternative to google, not if you want effective search results etc.
It's not that forums with similar titles are the problem, it's that they lack authenticity. ::)
For example, 8)
Quote from: stivep on January 31, 2019, 06:43:28 PM
Dla r2fpl:
https://www.youtube.com/watch?v=JGywu9BJJCU
Widze ze sie  zajales  na serio tematem.
Dla mnie to wyglada jak  zmiana impedancji pola przez dodanie zarowek w kierunku  blizej rezonansu.
To samo mozna  zrobic wkladajac reke.
To samo bedzie  rowniez   jesli czestotliwosc  struktury  zmieni sie przez dodanie komponentow LC
w XYZ przestrzeni - w kierunku  rezonansu.
Srobuje zrobic porownania:
Ja wiem ze twoja konfiguracja byla inna.
Chce tylko zebys rozumial co robi co.
Zaczynasz z 52MHz bo wtedy nie  masz  duzych wymiarow.
Robisz  sobie pare  rozdzielona  dystansem.
Czyli odb.  - robisz dokladnie tak jak i nadajnik.
dopiero kiedy  uda ci sie  przekazac energie z punktu a do b. to bierzesz  dokladnie ten sam nadajnik ktory jest teraz  twoim wzorcem.
Teraz traktujesz ten  nadajnik jak by to byl  teraz  twoj nastepny  odb.
i probujesz dostroic do rezonansu  schumanna nizej i nizej.
Orginalnego odb. nigdy nie dotykasz i nic  przy nim nie zmieniasz.
Ale teraz  ten twoj orginalny odb bedzie twoim nadajnikiem.
Czyli podlaczasz do niego  teraz generator.
Patrzysz czy  oba pracuja na przemian.
Potem powracasz do pierwszej konfiguracji.
Twoj nadajnik jest nadajnikiem a twoj odbiornik jest odbiornikiem.
I tu zachodzi  ciekawa rzecz.
Teraz bazujac na twoim juz teraz  doswiadzeniu  z  przekazem  energii
ktore jest kluczowe ,
Z nadajnika wyciagasz  cala cewke  wys nap. w jej miejsce wkladasz  granat Tariela  https://youtu.be/zE4GjB1cWLQ?t=513
Orginalnego pierwszego Odb.  nie ruszasz  wogole. Tak jak  byl dostr. tak go zostawiasz.
Bawisz sie z nawijajac  cewke w lewo , prawo jak popadnie  lub tez tak jak to robil  Akula lub Ruslan, caly czas trzymasz 52MHz na generatorze.
Patrzysz sie czy odb ci  cos pokazuje.
Tak naprawde to nie  ma wielkiego znaczenia .
Za kazdym razem kiedy zmieniasz kierunek nawiniecia  to skracasz fizyczna skladowa.
W rezultacie masz  cos malego  a zachowuje sie jak duza antena.
Podstawowa zasada :
Najpierw dostroj sie do rez.  na najmniejszej cewce  jaka mozesz nawinac  a potem mozesz albo nadawac albo odbierac, Jak sobie chesz.
Ale  odb musi byc na odleglosci ok. 10m   minimum dla 52MHz .
Jak juz  zrobisz ze ci ta cewka Tariela/ Akuly  pracuje to wlasciwie zrobiles  Kapanadze.
Znasz mechanizm dostrojenia sie do harmonicznej.
Wszystko co teraz trzeba  to wiedziec ze jestes kupe za  wysoko musisz zejsc nizej z czest.
Faza jest regulowana w stosunku do ziemi.
Faza potrzebuje  punktu odniesienia i ziemia jest twoim punktem odniesienia
Tariel zbytnio sie nie przejmowal. W pokazie dla mnie  uzyl  wysokowoltowy generator iskry od grzejnika od gazu
Jego koncepcja wymagala pierwszego impulsu aby wzbudzic  Zenneck fale a potem urzadzenie pracowalo samo.
Wesley
All experiments are done on your own risk based on your own decision.
HV is dangerous.
In the case of the above forum, the member who met the drunkard Kappanaze directly distorts the principle of the generator for some reason. 8)
They claim that natural waves, such as weak zenneck waves, that cannot pass through even the thin film of coils are the principle of the Kapanadze generator. 8)
The only reason for him is that he met Kapanadze on business. ::)
And he floods the forum with all sorts of miscellaneous experimental equipment. ::) ::)
Of course I am too. ;D ;D ;D ;D 8)
Quote from: F6FLT on February 17, 2019, 04:01:56 AM
It's not an opinion, it's physics.
Your digression on surface waves and Schumann frequencies is harmful to free energy, no extra energy can come from these conventional physics concepts, by definition. You mix anything with anything, misleading everyone.
Kapanadze device is not proven to work, since it has never been duplicated. Explanations on how what is not proven works make no sense.
Please provide:
1) an operational and working proof of concept that every one can duplicate
2) the experimental protocol and the data from the measurements of your own device
It is an advantage for scammers that there is no one in this cafe who can verify the generators of Kapanadze/Akura/Ruslan. 8) ::) 8)
It is free to steal the experimental generators of other members of the cafe, but they did not understand it at all and used them randomly. 8)
When the grenade coil goes out, it dances in the sky. ::) 8) ;D
It is freedom for some members of the cafe to put their hopes on the possibility of collective intelligence, but what I have experienced at this cafe for the past 10 years has been the tricksters' trickery. ::) 8) ;D
There are many scammers in Korea. ::)
They have even received doctoral degrees from Harvard University. ;D ::)
As soon as I start writing about Egypt, they change their stance and put on a performance as if they knew it too. ;D ;D
Of course, his 80 or so various books have nothing to do with it. ::) ::) 8)
color
Quote from: lancaIV on February 09, 2022, 05:16:37 PM
or "Phantasieren"  ::)
https://www.f6s.com/sabyasachihaldar
These coils can be used to create very highly efficient motors, transformers and many other electrical appliances.
Comparison :
https://www.patentauction.com/patent.php?nb=13984
Invented 3G HTS multi-strand electric wire can be used for::
1)  Electric motors, transformers and generator rotors with 5x reduced costs, weights and sizes,
2) Electric cables of any carrying capacity with 5x reduced costs, weights and diameters;
3) Cost-effective electric grids;     4)  Electromagnetic propulsion jet engines for aircrafts and high-speed ships;   5) Supercomputers and a supercollider; 6) Current limiters on the electric systems and grids; 7) Superconducting magnetic energy storage (SMES) systems for: a) an assurance of the electric grids and b) fast recharging of electric cars to support or substitute large batteries;
https://www.sciencedaily.com/releases/2021/04/210422093900.htm
https://patents.google.com/patent/US8736085B2/en
https://blog.go-here.nl/6097
https://web.archive.org/web/20060703055604/http://www.potomacenergyprojects.com/
wmbr
OCWL
A few hours ago, Bill Gates publicly prophesied that there would be an outbreak of smallpox
color
Quote from: lancaIV on February 09, 2022, 05:30:28 PM
I like to think this concept could be used to produce our first single stage to orbit aircraft as well as provide the energy to run very large ion engines with enough thrust to reach Mars in 2 weeks.
        ??? 8) :o
        Whom interests Mars !?
https://www.forbes.com/sites/jamiecartereurope/2021/12/28/nasa-is-set-to-explore-a-massive-metal-asteroid-called-psyche-thats-worth-way-more-than-our-global-economy/?sh=d56cc527ea26
1. Capturing 16 Psyche
2. Schumpeter : Schoepferische Zerstoerung /Constructive Destruction   ;D = (s)melting  ;)
                                                  Better 16 Psyche-EDEL than Psychedelic  :)
Tschau
OCWL
100% working Free energy generator , Amazing self running machine
https://www.youtube.com/watch?v=M0CXZ5LsJn0
color
Please understand that Google Translator does not understand the precise meaning of Korean and delivers only 70% of the meaning.
And there are many Christians in Korea.
Many of them are close to fanaticism.
The reason why there are so many shamans in Korea is because there is such a religious base.
Also, there are a lot of people who do business with these issues.
[미스터리] 전설의 '거인족' 과연 실제로 존재했나?||Ancient Secrets to Prepare for the Coming Days
https://www.youtube.com/watch?v=VJf_KwOXrZ0
필재 음모론 유튜브가 성경 이 외의 내용으로 성서 내용에 맞추는 이른바 창조과학은 환타지라 환타지라면 사족을 못쓰는 인간들은 뽕간다 필재야.
The so-called creation science that YouTube adapts to the content of the Bible with content other than the Bible is a fantasy.
창세기 1장
26   하나님이 가라사대 우리의 형상을 따라 우리의 모양대로 우리가 사람을 만들고 그로 바다의 고기와 공중의 새와 육축과 온 땅과 땅에 기는 모든 것을 다스리게 하자 하시고
27   하나님이 자기 형상 곧 하나님의 형상대로 사람을 창조하시되 남자와 여자를 창조하시고
28   하나님이 그들에게 복을 주시며 그들에게 이르시되 생육하고 번성하여 땅에 충만하라, 땅을 정복하라, 바다의 고기와 공중의 새와 땅에 움직이는 모든 생물을 다스리라 하시니라
Genesis 1 [NASB]
Then God said, "Let Us make man in Our image, according to Our likeness; and let them rule over the fish of the sea and over the birds of the sky and over the cattle and over all the earth, and over every creeping thing that creeps on the earth."
God created man in His own image, in the image of God He created him; male and female He created them.
God blessed them; and God said to them, "Be fruitful and multiply, and fill the earth, and subdue it; and rule over the fish of the sea and over the birds of the sky and over every living thing that moves on the earth."
창세기 God이 만든 사람이 지구상 모든 동식물을 다스리는 것은 누트와 게브가 하늘과 땅을 모두 다스리는 신이라 절대 가능하다.
인간은 불가능하다.
문제는 여호와 하나님의 형상은 아펩뱀이라 여호와 하나님의 형상대로 사람을 만들면 아펩뱀이 사람이 된다.
이런류 충돌이 창세기 6장에 발생한다.
It is absolutely possible for a man created by God in Genesis to rule over all animals and plants on earth, as Nut and Geb are gods who rule both heaven and earth.
Humans are impossible.
The problem is that the image of Jehovah God is an Apep serpent, so if you make a man in the image of Jehovah God, the Apep serpent becomes a human.
This kind of conflict occurs in Genesis 6.
창세기 6장
1   사람이 땅위에 번성하기 시작할 때에 그들에게서 딸들이 나니
2   하나님의 아들들이 사람의 딸들의 아름다움을 보고 자기들의 좋아하는 모든 자로 아내를 삼는지라
3   여호와께서 가라사대 나의 신이 영원히 사람과 함께 하지 아니하리니 이는 그들이 육체가 됨이라 그러나 그들의 날은 일백 이십년이 되리라 하시니라
4   당시에 땅에 네피림이 있었고 그 후에도 하나님의 아들들이 사람의 딸들을 취하여 자식을 낳았으니 그들이 용사라 고대에 유명한 사람이었더라
Genesis 6 [NASB]
Now it came about, when men began to multiply on the face of the land, and daughters were born to them,
that the sons of God saw that the daughters of men were beautiful; and they took wives for themselves, whomever they chose.
Then the LORD said, "My Spirit shall not strive with man forever, because he also is flesh; nevertheless his days shall be one hundred and twenty years."
The Nephilim were on the earth in those days, and also afterward, when the sons of God came in to the daughters of men, and they bore children to them. Those were the mighty men who were of old, men of renown.
하나님의 아들들(the sons of God)이 사람의 딸들(the daughters of men)과 결혼하면서 사람의 딸들은 하나님이 만든 사람의 자손이지만, 하나님의 아들들은 창조바깥에서 갑자기 창조세계 안으로 느닷없이 개입한 낙하산이라는거야.
누트가 첫째 날 만든 번개-빛이 하나님의 무수한 아들들이지만, 하나님의 아들들 정체가 여기서 드러날 경우 하나님의 정체가 아펩뱀이 되어 사람은 아펩뱀의 창조물이 될 수 없다.
When the sons of God marry the daughters of men, the daughters of men are the descendants of man made by God, but the sons of God intervene suddenly and unexpectedly from outside creation into creation. It's called a parachute.
The lightning-light created by Nut on the first day is the countless sons of God, but if the identities of the sons of God are revealed here, God's identity becomes an Apep serpent, and man cannot become an Apep serpent's creation.
요한복음 1장
1   태초에 말씀이 계시니라 이 말씀이 하나님과 함께 계셨으니 이 말씀은 곧 하나님이시니라
2   그가 태초에 하나님과 함께 계셨고
3   만물이 그로 말미암아 지은바 되었으니 지은 것이 하나도 그가 없이는 된 것이 없느니라
4   그 안에 생명이 있었으니 이 생명은 사람들의 빛이라
5   빛이 어두움에 비취되 어두움이 깨닫지 못하더라
John 5 [NASB]
In the beginning was the Word, and the Word was with God, and the Word was God.
He was in the beginning with God.
All things came into being through Him, and apart from Him nothing came into being that has come into being.
In Him was life, and the life was the Light of men.
The Light shines in the darkness, and the darkness did not comprehend it.
요한복음 1장의 WORD-하나님은 아펩뱀이고, GOD은 누트다.
누트(미카엘)가 자신과 닮은 사람을 여섯 째날 창조한다.
그런데 누트가 사람을 창조한 장소가 5두 아펩뱀의 영역(에게 헤)이라  아펩뱀이 사람을 창조한 것이 된다.
여기서 갑자기 창세기의 창조자가 둘이 됐다.
창조자가 둘이 된 것은 누트와 게브도 마찬가지다.
번개 아펩뱀은 단지 태양에 대항마적인 입장의 텐션이다.
The WORD of John 1 - God is the Apep Serpent, and GOD is Nut.
Nut (Michael) creates a person who resembles him on the sixth day.
However, the place where Nut created man is the realm of the five Apep serpents (Egehe), so the Apep serpent created man.
Here, suddenly, there are two creators of Genesis.
The creation of two creators is also true for Nut and Geb.
The lightning apep snake is just a tension against the sun.
출애굽기 21장
22   사람이 서로 싸우다가 아이 밴 여인을 다쳐 낙태케 하였으나 다른 해가 없으면 그 남편의 청구대로 반드시 벌금을 내되 재판장의 판결을 좇아 낼 것이니라
23   그러나 다른 해가 있으면 갚되 생명은 생명으로,
24   눈은 눈으로, 이는 이로, 손은 손으로, 발은 발로,
25   데운 것은 데움으로, 상하게 한 것은 상함으로, 때린 것은 때림으로 갚을찌니라
Exodus 21 [NASB]
"If men struggle with each other and strike a woman with child so that she gives birth prematurely, yet there is no injury, he shall surely be fined as the woman's husband may demand of him, and he shall pay as the judges decide.
"But if there is any further injury, then you shall appoint as a penalty life for life,
eye for eye, tooth for tooth, hand for hand, foot for foot,
burn for burn, wound for wound, bruise for bruise.
누트가 창조자가 되면 태양이 첫째 날의 빛이 된다.
번개신(어둠신 합체신) 입장에서 절대 용납될 수 없는 사건이다.
그래서 아펩뱀은 대항마적인 입장에서 똑같이 복수한다.
5두 아펩뱀의 영역(에게 헤)도 누트의 몸통 일부라 누트가 사람을 창조한 것이 되고, 누트의 성기에 기생해 살고있는 5두 아펩뱀도 자신의 영역에서 사람이 창조된 것이라 자신이 사람을 창조한 것이 된다.
창조신이 갑자기 둘이 되면서 이 사건을 창세기 2장에 할애해서 여호와-하나님이 아담을 흙으로 만들었고 하와가 아담의 갈비뼈로 만들었다고 명시하면서,
창세기 1장 창조신인 누트가 아담의 마누라로 전락?하는 수모를 받는다.
When Nut becomes the creator, the sun becomes the light of the first day.
This is an event that is absolutely unacceptable from the standpoint of the lightning god (the combined god of darkness).
So, the Apep snake takes revenge in the same way from an antagonistic standpoint.
The realm of the five apep snakes (Egehe) is also part of Nut's body, so Nut created a human being, and the five apep snakes living parasitic on Nut's genitals are also human beings created in their own realm. becomes the creation of
When the Creator God suddenly became two, this event is dedicated to Genesis 2, stating that Jehovah-God made Adam from dust and Eve made it from Adam's rib,
Genesis 1 Nut, the god of creation, is humiliated to become Adam's wife.
이사야 34장
2   대저 여호와께서 만국을 향하여 진노하시며 그들의 만군을 향하여 분내사 그들을 진멸하시며 살륙케 하셨은즉
3   그 살륙 당한 자는 내어던진바 되며 그 사체의 악취가 솟아오르고 그 피에 산들이 녹을 것이며
4   하늘의 만상이 사라지고 하늘들이 두루마리 같이 말리되 그 만상의 쇠잔함이 포도나무 잎이 마름 같고 무화과나무 잎이 마름 같으리라
5   여호와의 칼이 하늘에서 족하게 마셨은즉 보라 이것이 에돔 위에 내리며 멸망으로 정한 백성 위에 내려서 그를 심판할 것이라
13   그 궁궐에는 가시나무가 나며 그 견고한 성에는 엉겅퀴와 새품이 자라서 시랑의 굴과 타조의 처소가 될 것이니
14   들짐승이 이리와 만나며 수염소가 그 동류를 부르며 올빼미가 거기 거하여 쉬는 처소를 삼으며
15   부엉이가 거기 깃들이고 알을 낳아 까서 그 그늘에 모으며 솔개들도 그 짝과 함께 거기 모이리라
16   너희는 여호와의 책을 자세히 읽어보라 이것들이 하나도 빠진 것이 없고 하나도 그 짝이 없는 것이 없으리니 이는 여호와의 입이 이를 명하셨고 그의 신이 이것들을 모으셨음이라
17   여호와께서 그것들을 위하여 제비를 뽑으시며 친수로 줄을 띠어 그 땅을 그것들에게 나눠주셨으니 그것들이 영영히 차지하며 대대로 거기 거하리라
Isaiah 34 [NASB]
For the LORD'S indignation is against all the nations, And His wrath against all their armies; He has utterly destroyed them, He has given them over to slaughter.
So their slain will be thrown out, And their corpses will give off their stench, And the mountains will be drenched with their blood.
And all the host of heaven will wear away, And the sky will be rolled up like a scroll; All their hosts will also wither away As a leaf withers from the vine, Or as one withers from the fig tree.
For My sword is satiated in heaven, Behold it shall descend for judgment upon Edom And upon the people whom I have devoted to destruction.
Thorns will come up in its fortified towers, Nettles and thistles in its fortified cities; It will also be a haunt of jackals And an abode of ostriches.
The desert creatures will meet with the wolves, The hairy goat also will cry to its kind; Yes, the night monster will settle there And will find herself a resting place.
The tree snake will make its nest and lay eggs there, And it will hatch and gather them under its protection. Yes, the hawks will be gathered there, Every one with its kind.
Seek from the book of the LORD, and read: Not one of these will be missing; None will lack its mate For His mouth has commanded, And His Spirit has gathered them.
He has cast the lot for them, And His hand has divided it to them by line They shall possess it forever; From generation to generation they will dwell in it.
개역개정,14 들짐승이 이리와 만나며 숫염소가 그 동류를 부르며 올빼미가 거기에 살면서 쉬는 처소로 삼으며
새번역,14 거기에서는 들짐승들이 이리 떼와 만나고, 숫염소가 소리를 내어 서로를 찾을 것이다. 밤짐승이 거기에서 머물러 쉴 곳을 찾을 것이다.
우리말성경,14 들짐승들은 이리 떼와 마주치고 숫염소들은 자기 친구 염소를 부르며 울어댈 것이다. 물론 밤 짐승들도 거기 드러누워 쉴 곳을 찾게 될 것이다.
가톨릭성경,14 그곳에서는 사막 짐승들이 늑대들과 만나고 염소 귀신들이 서로를 부르리라. 도깨비도 그곳에 쉬면서 안식을 얻으리라.
영어NIV,14 Desert creatures will meet with hyenas, and wild goats will bleat to each other; there the night creatures will also repose and find for themselves places of rest.
영어NASB,14 And the desert creatures shall meet with the wolves, The hairy goat also shall cry to its kind; Yes, the night monster shall settle there And shall find herself a resting place.
영어MSG,14  Wildcats and hyenas will hunt together, demons and devils dance through the night. The night-demon Lilith, evil and rapacious, will establish permanent quarters.
영어NRSV,14 Wildcats shall meet with hyenas, goat-demons shall call to each other; there too Lilith shall repose, and find a place to rest.
헬라어구약Septuagint,14 και συναντησουσιν δαιμονια ονοκενταυροις και βοησουσιν ετερος προς τον ετερον εκει αναπαυσονται ονοκενταυροι ευρον γαρ αυτοις αναπαυσιν
라틴어Vulgate,14 et occurrent daemonia onocentauris et pilosus clamabit alter ad alterum ibi cubavit lamia et invenit sibi requiem
히브리어구약BHS,14 וּפָגְשׁוּ צִיִּים אֶת־אִיִּים וְשָׂעִיר עַל־רֵעֵהוּ יִקְרָא אַךְ־שָׁם הִרְגִּיעָה לִּילִית וּמָצְאָה לָהּ מָנֹוחַ׃
우파게슈 치임 엩 이임 웨사이르 알 레에후 이크라 아크 솸 히르기아 리리트 우마체아 라흐 마노아흐
Hebrew text
In the Masoretic Text:
Hebrew: ,וּפָגְשׁוּ צִיִּים אֶת-אִיִּים, וְשָׂעִיר עַל-רֵעֵהוּ יִקְרָא; אַךְ-שָׁם הִרְגִּיעָה לִּילִית, וּמָצְאָה לָהּ מָנוֹח
u-pagšu ṣiyyim et-ʾiyyim, w-saʿir ʿal-rēʿēhu yiqra; ʾak-šam hirgiʿa lilit, u-maṣʾa lah manoaḥ
34:14 "And shall-meet wildcats with jackals
the goat he-calls his- fellow
lilit (lilith) she-rests and she-finds rest
34:15 there she-shall-nest the great-owl, and she-lays-(eggs), and she-hatches, and she-gathers under her-shadow:
hawks [kites, gledes] also they-gather, every one with its mate.
Lilith
https://en.wikipedia.org/wiki/Lilith
시랑(Hyena)
하이에나과에 속하는 야행성 육식 동물로 히브리어 '이임'('iyyim)을 개역성경에서 시랑으로 번역했다(사 13:22; 렘 50:39). 성경에서 이 동물은 황폐함이나 사막과 관련해서 언급되었다(사 13:22; 렘 50:39).
It is a nocturnal carnivore belonging to the hyenadae, and the Hebrew word 'iyyim' is translated as shirang in the King James Version (Isa 13:22; Jeremiah 50:39). In the Bible this animal is mentioned in connection with desolation or desert (Isaiah 13:22; Jeremiah 50:39).
이사야 34장 14절에 등장하는 릴리스(לִּילִית/Lilith)를 나타내는 비유가 타조와 제비뽑기(cast the lot)다.
모두 이베리아반도와 로마, 그리스를 나타내는 태양신전 관련한 것들이다.
하와가 릴리스다.
바울의 세계관에서는 이베리아반도부터 인도까지 누트지만,
아브라함과 모세의 세계관의 하와는 터키부터 인도까지다.
히브리 전설에서 아담의 첫째 마누라 릴리스는 이베리아반도부터 그리스까지를 릴리스로 해석했다는 뜻이다.
이사야 13장에서 바벨론에 대해 시랑(Hyena)이란 표현을 쓴 것은 태양신전 바깥계 터키지역에 해당한다.
이사야 34장 13절, 시랑(자칼)의 소굴(a haunt of jackals)은 지중해 전체가 자칼의 소굴이라 이메리아반도, 로마, 그리스에 자칼이 배속된다.
이사야 34장 4절,
누트는 첫째 날 번개-빛을 만들어서 아펩뱀을 창조했지만,
아펩뱀은 아담(게브)의 갈비뼈로 누트(하와)를 만들어서 한 단계 높게 복수했다는 것이 요점이다.
또한 태양, 달, 별을 네째 날 만들어서 누트의 태양 천지창조를 교란시켜버렸다.
태양은 동쪽에서 뜨는 관계로 사우디아라비아반도가 떠받들고 있는 아펩뱀이 첫째 날의 빛으로 창조되고,
궁창 위에 물과 아래 물로 나뉜 것이 누트와 게브라서 둘째 날 창조된다.
아펩뱀이 누트와 게브보다 먼저 창조된다.
아펩뱀의 복수는 늘 이런식이다.
아펩뱀(관련된 모든 것)을 항상 앞에 배치한다.
궁창 위에 물은 페르시아만, 오만만, 인도로 이어지는 누트구역이고,
궁창 아래 물은 홍해다.
Seth가 낳은 에노스(이베리아반도) 때 여호와 이름이 불려졌으니,
네째 날 태양이 창조되고 번개신의 이름도 제우스에게 여호와(I AM WHO I AM)로 개명된다.
누트의 머리가 에노스라, 에노스가 태양이고 첫때 날의 빛이 되야했지만 뒤로 밀리고 밀려나 Seth의 아들로 태어나는 수모를 겪는다.
이베리아반도가 그리스의 동쪽에 있었다면 누구도 바꿀 수 없는 태양의 천지창조가 되겠지만,
이베리아반도가 이탈리아반도 서쪽에 위치해 있어서 그리스 지역 아펩뱀들에게 빌미를 제공한거다.
세째 날 창조된 물이 한 곳으로 모인 곳은 지중해다.
누트와 게브가 합체된 것이 지중해를 나타낸다.
이베리아반도를 중심으로하는 태양신전이 완성되는 조건을 지중해가 제공했다.
노아의 홍수는 이렇게 하늘과 땅의 만남에서 시작하면서 네피림으로 이어진다.
누트 입장에서 하나님의 아들들은 사람의 모습과 똑같지만,
아펩뱀의 입장에서 하나님의 아들들은 아펩뱀이다.
누트 입장에서 하나님의 아들들은 이탈리아반도, 사우디아라비아반도라 Djed이다.
아펩뱀의 입장에서 하나님의 아들들도 Djed이다.
누트는 자신의 모습대로 아담을 창조했지만,
아펩뱀은 자신의 모습대로 아담을 창조하지 않았다.
그래서 네피림의 모습은 사람과 아펩뱀과 Djed이 얽혀있다.
요한복음 14장에서 예수가 말하는 보혜사(Counselor)는 그리스 중심의  ΑΩ로 비롯된,
The parable for Lilith in Isaiah 34:14 is the ostrich and the cast the lot.
They are all related to the Sun Temple representing the Iberian Peninsula, Rome, and Greece.
Eve is Lilith.
In Paul's worldview, Nut from the Iberian Peninsula to India,
Eve in the worldview of Abraham and Moses is from Turkey to India.
In Hebrew legend, Lilith, Adam's first wife, means Lilith from the Iberian Peninsula to Greece.
The use of the word hyena for Babylon in Isaiah 13 corresponds to the Turkish region outside the Temple of the Sun.
Isaiah 34:13, a haunt of jackals (a haunt of jackals) is a haunt of jackals in the entire Mediterranean Sea, so jackals are attached to the Imerian Peninsula, Rome, and Greece.
Isaiah 34:4,
Nut created lightning-light on the first day to create the Apep Serpent,
The point is that the Apep snake made Nut (Eve) from the ribs of Adam (Geb) and took revenge on a higher level.
He also created the sun, moon, and stars on the fourth day, disrupting Nut's creation of the sun.
Since the sun rises in the east, the Apep serpent supported by the Saudi Arabian Peninsula is created as the light of the first day.
The division of water above and below the firmament is Nut and Gebra, which are created on the second day.
Apep snakes are created before Nut and Geb.
The revenge of the Apep snake is always like this.
Always place the Apep snake (and everything related) in front.
The water above the firmament is the Nut region that leads to the Persian Gulf, the Gulf of Oman, and India,
The water under the firmament is the Red Sea.
The name of the LORD was called in the days of Enosh (Iberian Peninsula), which Seth gave birth to,
On the fourth day, the sun is created and the name of the lightning god is changed to Jehovah (I AM WHO I AM) by Zeus.
Nut's head is Enosra, Enos is the sun, and he was supposed to be the light of the first day, but he is pushed back and pushed back and suffers the disgrace of being born as Seth's son.
If the Iberian Peninsula was to the east of Greece, it would be the sun's creation that no one could change.
Since the Iberian Peninsula is located in the western part of the Italian Peninsula, it provided an excuse for the Greek Apep snakes.
The place where the waters created on the third day were gathered in one place is the Mediterranean Sea.
The combination of Nut and Geb represents the Mediterranean Sea.
The Mediterranean Sea provided the conditions for the completion of the Temple of the Sun centered on the Iberian Peninsula.
Noah's flood begins with the meeting of heaven and earth in this way and leads to the Nephilim.
From Nut's point of view, the sons of God are identical in appearance to men, but
From the point of view of the Apep serpent, the sons of God are the Apep serpent.
From Nut's point of view, the sons of God are the Italian peninsula and the Saudi Arabian peninsula, Djed.
From the point of view of the Apep serpent, the sons of God are also Djeds.
Nut created Adam in his own image, but
The ape serpent did not create Adam in his own image.
So, the appearance of the Nephilim is intertwined with a human, an Apep snake and a Djed.
In John 14, the Counselor that Jesus speaks of is derived from the Greek ΑΩ,
요한계시록 1장
7   볼찌어다 구름을 타고 오시리라 각인의 눈이 그를 보겠고 그를 찌른 자들도 볼터이요 땅에 있는 모든 족속이 그를 인하여 애곡하리니 그러하리라 아멘
8   주 하나님이 가라사대 나는 알파와 오메가라 이제도 있고 전에도 있었고 장차 올 자요 전능한 자라 하시더라
9   나 요한은 너희 형제요 예수의 환난과 나라와 참음에 동참하는 자라 하나님의 말씀과 예수의 증거를 인하여 밧모라 하는 섬에 있었더니
10   주의 날에 내가 성령에 감동하여 내 뒤에서 나는 나팔 소리 같은 큰 음성을 들으니
Revelation 1 [NASB]
BEHOLD, HE IS COMING WITH THE CLOUDS, and every eye will see Him, even those who pierced Him; and all the tribes of the earth will mourn over Him. So it is to be. Amen.
"I am the Alpha and the Omega," says the Lord God, "who is and who was and who is to come, the Almighty."
I, John, your brother and fellow partaker in the tribulation and kingdom and perseverance which are in Jesus, was on the island called Patmos because of the word of God and the testimony of Jesus.
I was in the Spirit on the Lord's day, and I heard behind me a loud voice like the sound of a trumpet,
5두 아펩뱀(여호와)이 코앞에 있는 밧모 섬에서 기록이라 아펩뱀을 벗어나지 못한다.
그래서 요한은 5두 아펩뱀에 속한 아버지와 아들의 예수를 벗어나지 못한다.
5The two Apep serpents (Jehovah) are recorded on the island of Patmos in front of them, so they cannot escape the Apep serpents.
So John does not escape from Jesus the Father and the Son, who belong to the two Apep serpents.
요한계시록 12장
1   하늘에 큰 이적이 보이니 해를 입은 한 여자가 있는데 그 발 아래는 달이 있고 그 머리에는 열 두 별의 면류관을 썼더라
2   이 여자가 아이를 배어 해산하게 되매 아파서 애써 부르짖더라
3   하늘에 또 다른 이적이 보이니 보라 한 큰 붉은 용이 있어 머리가 일곱이요 뿔이 열이라 그 여러 머리에 일곱 면류관이 있는데
4   그 꼬리가 하늘 별 삼분의 일을 끌어다가 땅에 던지더라 용이 해산하려는 여자 앞에서 그가 해산하면 그 아이를 삼키고자 하더니
5   여자가 아들을 낳으니 이는 장차 철장으로 만국을 다스릴 남자라 그 아이를 하나님 앞과 그 보좌 앞으로 올려가더라
6   그 여자가 광야로 도망하매 거기서 일천 이백 육십일 동안 저를 양육하기 위하여 하나님의 예비하신 곳이 있더라
7   하늘에 전쟁이 있으니 미가엘과 그의 사자들이 용으로 더불어 싸울쌔 용과 그의 사자들도 싸우나
8   이기지 못하여 다시 하늘에서 저희의 있을 곳을 얻지 못한지라
9   큰 용이 내어 쫓기니 옛 뱀 곧 마귀라고도 하고 사단이라고도 하는 온 천하를 꾀는 자라 땅으로 내어 쫓기니 그의 사자들도 저와 함께 내어 쫓기니라
10   내가 또 들으니 하늘에 큰 음성이 있어 가로되 이제 우리 하나님의 구원과 능력과 나라와 또 그의 그리스도의 권세가 이루었으니 우리 형제들을 참소하던 자 곧 우리 하나님 앞에서 밤낮 참소하던 자가 쫓겨 났고
11   또 여러 형제가 어린 양의 피와 자기의 증거하는 말을 인하여 저를 이기었으니 그들은 죽기까지 자기 생명을 2)아끼지 아니하였도다
12   그러므로 하늘과 그 가운데 거하는 자들은 즐거워하라 그러나 땅과 바다는 화 있을찐저 이는 마귀가 자기의 때가 얼마 못된 줄을 알므로 크게 분내어 너희에게 내려 갔음이라 하더라
13   용이 자기가 땅으로 내어쫓긴 것을 보고 남자를 낳은 여자를 핍박하는지라
14   그 여자가 큰 독수리의 두 날개를 받아 광야 자기 곳으로 날아가 거기서 그 뱀의 낯을 피하여 한 때와 두 때와 반 때를 양육 받으매
15   여자의 뒤에서 뱀이 그 입으로 물을 강 같이 토하여 여자를 물에 떠내려 가게 하려 하되
16   땅이 여자를 도와 그 입을 벌려 용의 입에서 토한 강물을 삼키니
17   용이 여자에게 분노하여 돌아가서 그 여자의 남은 자손 곧 하나님의 계명을 지키며 예수의 증거를 가진 자들로 더불어 싸우려고 바다 모래 위에 섰더라
Revelation 12장 [NASB]
A great sign appeared in heaven: a woman clothed with the sun, and the moon under her feet, and on her head a crown of twelve stars;
and she was with child; and she cried out, being in labor and in pain to give birth.
Then another sign appeared in heaven: and behold, a great red dragon having seven heads and ten horns, and on his heads were seven diadems.
And his tail swept away a third of the stars of heaven and threw them to the earth And the dragon stood before the woman who was about to give birth, so that when she gave birth he might devour her child.
And she gave birth to a son, a male child, who is to rule all the nations with a rod of iron; and her child was caught up to God and to His throne.
Then the woman fled into the wilderness where she had a place prepared by God, so that there she would be nourished for one thousand two hundred and sixty days.
And there was war in heaven, Michael and his angels waging war with the dragon The dragon and his angels waged war,
and they were not strong enough, and there was no longer a place found for them in heaven.
And the great dragon was thrown down, the serpent of old who is called the devil and Satan, who deceives the whole world; he was thrown down to the earth, and his angels were thrown down with him.
Then I heard a loud voice in heaven, saying, "Now the salvation, and the power, and the kingdom of our God and the authority of His Christ have come, for the accuser of our brethren has been thrown down, he who accuses them before our God day and night.
"And they overcame him because of the blood of the Lamb and because of the word of their testimony, and they did not love their life even when faced with death.
"For this reason, rejoice, O heavens and you who dwell in them Woe to the earth and the sea, because the devil has come down to you, having great wrath, knowing that he has only a short time."
And when the dragon saw that he was thrown down to the earth, he persecuted the woman who gave birth to the male child.
But the two wings of the great eagle were given to the woman, so that she could fly into the wilderness to her place, where she was nourished for a time and times and half a time, from the presence of the serpent.
And the serpent poured water like a river out of his mouth after the woman, so that he might cause her to be swept away with the flood.
But the earth helped the woman, and the earth opened its mouth and drank up the river which the dragon poured out of his mouth.
So the dragon was enraged with the woman, and went off to make war with the rest of her children, who keep the commandments of God and hold to the testimony of Jesus.
요한계시록 12장의 붉은 용은 지도를 뒤집어야 보인다.
거개한 드래곤의 머리는 사우디아라비아반도고 인도는 용의 꼬리에 해당한다.
The red dragon in Revelation 12 is visible only when the map is turned over.
The big dragon's head is the Saudi Arabian peninsula, and India's is the dragon's tail.
Grogu All Scenes (Book of Boba Fett Episode 7) SPOILERS
https://www.youtube.com/watch?v=NJkt66nE_W4
마태복음 5장
38   또 눈은 눈으로, 이는 이로 갚으라 하였다는 것을 너희가 들었으나
39   나는 너희에게 이르노니 악한 자를 대적지 말라 누구든지 네 오른편 뺨을 치거든 왼편도 돌려 대며
40   또 너를 송사하여 속옷을 가지고자 하는 자에게 겉옷까지도 가지게 하며
41   또 누구든지 너로 억지로 오리를 가게 하거든 그 사람과 십리를 동행하고
42   네게 구하는 자에게 주며 네게 꾸고자 하는 자에게 거절하지 말라
43   또 네 이웃을 사랑하고 네 원수를 미워하라 하였다는 것을 너희가 들었으나
44   나는 너희에게 이르노니 너희 원수를 사랑하며 너희를 핍박하는 자를 위하여 기도하라
45   이같이 한즉 하늘에 계신 너희 아버지의 아들이 되리니 이는 하나님이 그 해를 악인과 선인에게 비취게 하시며 비를 의로운 자와 불의한 자에게 내리우심이니라
Matthew 5 [NASB]
"You have heard that it was said, 'AN EYE FOR AN EYE, AND A TOOTH FOR A TOOTH.'
"But I say to you, do not resist an evil person; but whoever slaps you on your right cheek, turn the other to him also.
"If anyone wants to sue you and take your shirt, let him have your coat also.
"Whoever forces you to go one mile, go with him two.
"Give to him who asks of you, and do not turn away from him who wants to borrow from you.
"You have heard that it was said, 'YOU SHALL LOVE YOUR NEIGHBOR and hate your enemy.'
"But I say to you, love your enemies and pray for those who persecute you,
so that you may be sons of your Father who is in heaven; for He causes His sun to rise on the evil and the good, and sends rain on the righteous and the unrighteous.
마태복음 5장 45절의 태양이 선악과(the evil and the good) 주체라서 태양을 먹는 누트와 게브가 번개신 여호와의 복수 대상이 된 것이고,
누트와 게브를 닮은 사람에 대한 여호와의 복수가 노아의 홍수로 이어지며 끝없는 복수의 칼날을 갈아온 것이다.
Since the sun in Matthew 5:45 is the subject of the evil and the good, Nut and Geb, who eat the sun, became the object of revenge of Jehovah, the god of lightning.
Jehovah's revenge against those who resembled Nut and Geb led to Noah's flood, sharpening the edge of endless revenge.
그리고 마태복음 5장은 유대인들 끝없는 복수를 정당하는 말이고 유대인들의 복수를 그대로 수용하라는 뜻이다.
이것이 네 하나님 목숨같이 사랑하고 네 이웃을 네 몸과같이 사랑하라는 예수의 2가지 율법이다.
그래서 나는 니체의 죽은 신을 '절대로' 부활시키고 싶지 않다.
And Matthew 5 justifies the endless vengeance of the Jews, and it means to accept the vengeance of the Jews as they are.
These are the two laws of Jesus: Love your God as your life and love your neighbor as yourself.
So I don't want to 'never' resurrect Nietzsche's dead god.
