Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 18 Guests are viewing this topic.
color
Quote from: lancaIV on February 10, 2022, 07:23:17 AM
# 2341 :
simple machine :
the human,today often only more to see as system Cobot
conventional bi-cycle use for power/energy conversion without = kinetic/mechanical force conversion /with e-generator = electric force
https://www.econvergence.net/
conventional bi-cycle to http://www.microcarmuseum.com/tour/velo-velocar.html
Charles Mochet then decided to bridge the gap between Velocar and bicycle, by splitting the Velocar in half, discarding the bodywork,and leaving the driver sitting comfortably in a horizontal position.
The design, which worked amazingly well, was intensively developed in the '30's, resulting in a large number of speed records being broken. The two-wheeled Velo-Velocar ("Velo"=bicycle), nowdays called a Recumbent Bicycle (or "Bent"), was unbeatable. So much so, that the Union Cycliste International changed the rules in 1934, barring "unconventional" bicycles from competing in all events. An embittered Mochet blamed the manufacturers of conventional bicycles and professional cycle racing organizations for conspiring against him. Charles died in 1934, leaving his son Georges to carry the flag, which Georges did very well, and continues to do to this day.
Recumbents are today enjoying a huge worldwide renaissance.
Related :
https://patentauction.com/patent.php?nb=7983
a conventional bi-cycle generator output compared velo-generator output ?!
the appropriate lever-use principle !
The velo-driver pedals a velo-egenerator to rotations and by this the electric force loads an in-wheel motor( or bi-in-wheels motors) :
the velo-bike with direct body-force pedal-conversion average/peak velocity
the velo-egenerator/emotor-body pedal force- average/peak velocity conversion ?!
how many times the emotor output/related conventional counterpart and egenerator/related conventional counterpart
with-/out ccw/cw gear transmission effect
can optimize the driver body net force to total kinetic/mechanical or electrical lever-factor ?
this knowledge/experience to :
https://en.wikipedia.org/wiki/History_of_human-powered_aircraft
https://www.youtube.com/watch?v=AlSlXCgF6y4
Kremer Prize successes by Gossamer Condor and AlbatrossIn 1973, Kremer increased his prize money tenfold to £50,000.  At that time, the human-powered aircraft had flown only in straight (or nearly straight) line courses, and no-one had yet even attempted his more challenging figure-eight course, which required a fully controllable aircraft.  He also opened the competition to all nationalities; previously it was restricted to British entries only.
On 23 August 1977, the Gossamer Condor 2 flew the first figure-eight, a distance of 2.172 km winning the first Kremer prize.  It was built by Dr Paul B. MacCready and piloted by amateur cyclist and hang-glider pilot Bryan Allen.
Although slow, cruising at only 11 mph (18 km/h), it achieved that speed with only 0.35 hp (0.26 kW).[20]
The second Kremer prize of £100,000 was won on June 12, 1979, again by Paul MacCready, when Bryan Allen flew MacCready's Gossamer Albatross from England to France: a straight distance of 35.82 km (22 miles 453 yards) in 2 hours, 49 minutes.[citation needed]
only 0.35 hp (0.26 kW) :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19951107&CC=US&NR=5463914A&KC=A#
In general, for conventional motors of 1 HP and 3  HP, the power consumptions are 746 W/H and 2238 W/H. These motors can be operated at high speed with low output torque or operated at low speed with larger torque, no matter how it operates, the power consumptions thereof are respectively 746 W/H and 2238 W/H.
    In comparison, when a DC 12 V mini motor with full load capacity 25 g, 560 mA, running at 13340 rev./min is used, a plurality of such motors can be assembled and operated in association with a suitable number of down-speed gear sets so as to obtain proper operation speed. The power consumptions thereof in the same conditions as above, are compared with the conventional motors to conclude that at most only one eleventh of the power consumed in above cited motors is required.
human electric pedal power as electric input for aircraft drive torque/moment output ?
1 transmission-turbine,2x /3x, ...... for higher velocities than " .....  cruising at only 11 mph (18 km/h) .... "
with/-out solar-cells on wings
https://www.youtube.com/watch?v=fZMFF8QH3ew
wmbr
OCWL
Quote from: lancaIV on February 10, 2022, 07:58:11 AM
https://pod-point.com/guides/driver/how-long-to-charge-an-electric-car
https://www.pcmag.com/news/worlds-fastest-electric-car-charger-offers-a-full-charge-in-15-minutes
ABB promises to change that, though, with its Terra 360 (360 kW) modular charger.
                                                   Bow eyye  :o : 360 kW (DC) ! Question : AC, Hz ?
                                                  https://new.abb.com/ev-charging
         " BOW eyye"²  ::) -solutions [without battery (s-)melting/"vaporizing :P " ] :
https://patents.google.com/patent/US8847720B2/en
Net Power Output after Feedback of 13.32 Kva
The net output at 400 Hz is 16.871 Kva (22.6 Hp); at 800 Hz, 33.7 Kva (45.2 Hp); at 3 KHz=128 Kva (171.5 Hp); at 6 KHz=256 Kva (343 Hp); at 60 Khz=2.560 Kva; at 600 KHz=25.60 Kva; at 780 KHz=33.254 Kva.
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1#
To clarify the operation of this embodiment according to the invention, the following dimensioning of the transformer windings is given using Figure 17 as an example, the iron cores being dimensioned in accordance with the manner usual for transformers:
    - winding 81: 1000 windings, 220 V/50 Hz, 5 A at full load;
    - winding 82: 1 winding, 5000 A;
    - winding 84: 1000 windings, 5000 A; - winding 85: 1100 windings, 4500 A, 220 V/50 Hz.
From the above example it is evident that, with a coil 82 having 5000 ampere windings, a flux variation of 5000000 ampere windings can be generated with the superconducting coil 84. Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1 . 1 kW, and this corresponds to a power gain of approximately a factor of 1000.
repeating the SUPERCONDUCTOR TECHNOLOGY ERA in front of us :
https://www.patentauction.com/patent.php?nb=13984
Invented 3G HTS multi-strand electric wire can be used for::
1)  Electric motors, transformers and generator rotors with 5x reduced costs, weights and sizes,
2) Electric cables of any carrying capacity with 5x reduced costs, weights and diameters;
3) Cost-effective electric grids;     4)  Electromagnetic propulsion jet engines for aircrafts and high-speed ships;   5) Supercomputers and a supercollider; 6) Current limiters on the electric systems and grids; 7) Superconducting magnetic energy storage (SMES) systems for: a) an assurance of the electric grids and b) fast recharging of electric cars to support or substitute large batteries;
Alternatively : on-board
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20200402&CC=DE&NR=102018007240A1&KC=A1#
as
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20190328&CC=DE&NR=112017003611A5&KC=A5#
These are know -2022 p.C.n.- "herrenlose= owner-free Patent/-Anmeldungen/-Applications "
wmbr
OCWL
Quote from: lancaIV on February 10, 2022, 08:51:53 AM
the weather over the seasons changes = natural -periodical- climate change
how to act/react ? :
a body textile overall !?
coated with https://www.patentauction.com/patent.php?nb=11044
11.    We can paint our clothes with it and with every theen layer of clothing we can stay hot, or cool.
or /and - for body conditioning :https://spectrum.ieee.org/wristify-thermoelectric-bracelet-would-reduce-energy-consumptionDIY alternatives ? with simple Peltier (Seebeck)effect elements ?or/andhttp://www.rexresearch.com/cuinanoagwire/cuinanoag.htmlthe ambient "green house" tect : https://ic.pics.livejournal.com/calzephyr77/1027708/125261/125261_original.pnginside ,f.e. : https://www.ebay.de/itm/393791713832?mkevt=1&mkcid=1&mkrid=707-53477-19255-0&campid=5338624525&toolid=10029&customid=53aa7f90a24a22460c761e5aac7beb86https://en.wikipedia.org/wiki/Biosphere_274 000 sqm under (pro-)tect(ion) :https://www-olympiapark-de.translate.goog/de/touren-und-sightseeing/gefuehrte-touren/zeltdach-tour/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
How many sqm by "translucent wood shape" https://en.wikipedia.org/wiki/Transparent_wood_composite
in which time errectable , http://www.fishrock.com/conics/  ?
"translucent" fishrock or fishplastics  ::) : https://www-trendingtopics-eu.translate.goog/erfinderin-entwickelt-plastik-alternative-aus-fisch-resten/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
Millions of sqm "green house"-area by https://judbarovski.livejournal.com/14181.html? use !?
for   http://www.canlaser.com/en/Home.html    http://www.canlaser.com/en/Deserts.html
We brought Desert Sand from Mali.(West Sahara,in Africa).
We used only normal water and we succeeded.
low cost drink/potable water generation examples/ideas : https://patentauction.com/search.php
Drop-watering ?
CO2 gas use ?
https://www-technica--gmbh-de.translate.goog/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapphttps://www-technica--gmbh-de.translate.goog/garten-und-landwirtschaft/carborain/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
The role of Laser technology in the structure of soil is very important. Laser beams and necessary support systems help to cure the structure of soils. It helps to stable the heat differences of soil. By the help of this technology the humidity of soil becomes normal. The chemical and physical structure of soil develops. As result we are able to grow plants in these soils.
Alone the people can not and will not solve the next generation phase - 30 years- /-2050 phase,but together,with teamwork help, and technical help some strong evolution barriers can be resolved !
https://en.wikipedia.org/wiki/Demographics_of_Africa
the most african countries became between 1960-1975 independent :
+- 400 millions habitants to 2100 p.C. 4300 millions habitants
compared total western Europe 1960-1970                           to 2100 p.C. demography
https://en.wikipedia.org/wiki/Demographics_of_Europe       https://www.populationpyramid.net/western-europe/2100/
living with changes !
wmbr
OCWL
Quote from: lancaIV on February 10, 2022, 12:59:27 PM
and Prospection :
https://www.fai.org/news/thirty-years-longest-human-powered-flight-history
His record-breaking flight – the longest human-powered flight in history – took 3 hours, 54 minutes, and began at 7am on 23 April 1988. The super-fit cyclist used the power in his legs to fly Daedalus over 115km of open sea and set two FAI world records that still stand today.
Powered by a 3m propeller and weighing just 31kg, the Daedalus - an elegant aircraft with an impressive 34m wingspan - required extreme fitness to fly, as the propeller was turned by leg-power alone.
https://www.youtube.com/watch?v=xHGkOQUtlRk
0:09 Flyboard Air ( https://www.youtube.com/watch?v=YBaBhEPHzjM )
2:45 Alpha Jetman
3:45 Jetpack Aviation JB10 193km/hr
4:40 Ultralight can be flown without a pilots license
5:23 Gravity jetsuit
7:10 Hoverbike Scorpion 3 by Russian company, Hoversurf; carbon fiber frame
8:17 Martin Jetpack
9:30 Kittyhawk Flyer
color
Попытка повторить Руслана Гаджиомарова. Этап 1_2.
https://www.youtube.com/watch?v=qldXcEzL8AI
Other members doing similar experiments, but the fact that your experiment is the same as it was 5 years ago inspires respect among the viewing members.
color
낮잠잘만~~~~하닝께 알람 울리게 맹글어..... ;D ;D ;D ;D 8)
I Am A Singer #25, Yim Jae-beum : For you - 임재범 : 너를 위해
https://www.youtube.com/watch?v=cDS3vu_Ep6E
;D ;D 8) 8)
내 거친 생각과.... '불안한 눈빛'과 ......... 그걸 지켜보는 너.... 그건 아마도 전쟁같은 사랑..... 난 위험하니까 .......... 사랑하니까~ ............
My rough thoughts... 'Anxious eyes' and... You watching it... Maybe it's a love like war... Because I'm in danger... ...because I love you~ ............ ::)
;D ;D ;D ;D ::) 8)
https://ncache.ilbe.com/files/attach/new/20220211/377678/10240896407/11394671860/4708bc58708d0a7ec5cdf145f9773ad7_11394671948.mp4
color
[도올김용옥] 동경대전 101 "모든 공통의 상식적 세계를 벗어나면 종교가 아니다" - '개천'에서 '용'났다? - 공자와 나는 '대동소이'
https://www.youtube.com/watch?v=9sbz2aBL4FU
이건 또 무슨 개소리야
color
람세스 5세 기원전 1146년 ~ 기원전 1142년
람세스 6세 기원전 1142년 ~ 기원전 1134년
Ramses V 1146 BC - 1142 BC
Ramses VI 1142 BC - 1134 BC
기원전 1200년경에 중국의 공자가 도마뱀이랑 이집트에 놀러왔다가 얼어뒈졌다는 얘기(禮記)지 뭐..... 헤헤헤헿 ;D ;D ;D ;D 8)
