Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Hoppy :
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #160 on: October 01, 2012, 12:01:09 PM »
I have attached a scope shot (x10 probe) taken collector to ground of an inverter MJL21194 transistor operating at 4.6KHz.
Current draw - 2.86A @ 12.3V. Output - 111.7V into a 1K resistive test load.
The transformer is a big mains toroid with 2 x 9.4A primaries.
I have used a P6KE30A (30V) transorbs with 33R series resistors for snubbers across C/E of each MJL21194. A smaller 24V transorb with 33R resistor is also fitted across the TL494 supply rail.
There is ringing on the waveform but I'm reasonably happy with it for this application. However, it is clear to me that given that Dally used bipolar transistors for his inverter, with the circuit as drawn, this would have not delivered very much power to a load irrespective of the transformer type. We need to see the full spec on the toroid transformer he used.
Hoppy
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg338456/#msg338456
color
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg338657/#msg338657
When Verpies mentions thyristors, the T-1000 (Wesley) tries to divert the point of view to the trolls, like licorice in the drugstore.
Of course, both are conversations without knowing the principle of the free generator.
color
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg338754/#msg338754
Vasiliy Buslaev :
« Reply #228 on: October 04, 2012, 10:10:30 AM »
Quote from: Сергей Ð'. on October 03, 2012, 05:42:41 PM
You may use bigger ring up to 2 cm outer diameter.  М6000НМ or better.
I do not agree with Sergei, this fundamental error which began to make in our forums. In this scheme, the core must  to work in saturation mode, otherwise the effect DSRDs diode is not going to happen.
It is necessary to use small-diameter ring, as shown in basic scheme, it is 7 mm outer diameter.
In the scheme, sloping line indicates on the  transformer in  saturation mode.
The larger the size of the ring, the more difficult to enter it into saturation.
Ferrite is going hot so must be sealed or glued on KT926 radiator.
Yes, the ring will heat up, it will need to be glued on the radiator.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg338827/#msg338827
color
Работа магнитного накопителя с ТЭНами.
https://www.youtube.com/watch?v=CExkHnGWths&t=0s
Эффект независимости.
https://www.youtube.com/watch?v=ya6vaBRO2f0&t=10s
Russians have similar names, so I can't tell who is who.
color
verpies :
« Reply #230 on: October 04, 2012, 12:10:57 PM »
Quote from: Vasiliy Buslaev on October 04, 2012, 10:10:30 AM
I agree. The transformer method of driving the DSRD requires the saturation of the ferrite core in order to create asymmetrical currents in the forward and reverse conduction of the DSR diodes.
I think that tunning the saturation point of this transformer is tricky.  That is why I prefer the transformerless method of driving the DSR diodes.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg338833/#msg338833
Vasiliy Buslaev :
« Reply #231 on: October 04, 2012, 12:47:44 PM »
Quote from: verpies on October 04, 2012, 12:10:57 PM
You need not reinvent the bike. This scheme works quite good without complicated settings. The scheme was worked out in the Institute of Nuclear Physics, Academy of Sciences of the USSR. The document is in Russian, sorry. If necessary, can translate the most interesting moments.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg338834/#msg338834
And verpies speak of the principle of free-generator resonance.
Verpies quickly unveiled the generator principle and some members were puzzled.
Later, after I realized the principle of the free-generator resonance, I laughed for a long time when I remembered this article.
