Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
NickZ :
The conversation between Pierrot and the Samaritan
https://www.youtube.com/watch?v=v1Cb4j1l2lo
Some time ago my computer monitor died.
This model has been used for over 20 years.
And two years ago, I got a 15 year old used monitor for free from a second-hand shop.
It seems like your Costa Rica doesn't have a basic computer monitor with a 1:2 ratio.
There are only such monitors in Korea.
The ratio is the same whether the monitor is large or small.
You ordered the most to set it to 960px.
If you live in a place with good air and a good background, there will be some inconveniences.
This can also be one of the more uncomfortable things.
I think that changing your computer monitor will help other members provide high-quality photos.
I have to work hard to edit photos on my old-computer.
And,
I hope Geo's experiment starts again soon.
I don't think I've made Geo's experimentation heavy.
No matter how long you hold on, you don't succeed.
Not long ago, Geo said he knew something.
Whether that is the principle of resonance is unknown.
And I waited, but Geo didn't show up.
If Geo doesn't appear in this cafe in the future, he might have been afraid of somebody's threats.
Or is it because I have a lot of personal work.
Wesley and you talked the most about people dying.
This is what you know better.
Human greed is endless.
And the choice is free.
https://www.tripadvisor.com/VacationRentalReview-g313829-d2514028-Casa_Mira_Mar_Ocean_View_200_meters_to_ocean-Dominical_Province_of_Puntarenas.html
color
I am waiting for the experiment of the two.
I am waiting for someone to break down the free-generator I have made. 8) ;D
color
Ntambi
Some Food for the brain
The circuit below is from some of the first videos of Tungus before he changed his name to Akula..
Im gonna be posting to show you the similarities between Akula, Tariel Kapanadze, Weasley, SR193, Tiger2007 and Michel Meyer...
the connection is that all these devices utilise nuclear magnetic  resonance of ferromagnetic materials to produce excess energy...
Now from the circuit:
Lets take a look at object 1 and 3 which are diode bridges... Diode bridge 1 converts the high frequency AC current from the output back to DC into the system (loop) through inverter 2... then the inverter 2 converts the DC current back to AC but this time at 50Hz, its then connected to diode bridge 3 which converts AC back to DC to power the driver circuit 5...
if you read the above statement you can easily tell that it makes no sense, why not connect the DC from the output directly to driver circuit 5 other than converting it to AC then back to DC to power the driver..
What i found out during my research and experiment is that the inverter is not in the circuit to work only as AC to DC convertor but its there to also work as a signal generator producing a current pulse of 50Hz... So we are having two signal sources, one low frequency 50Hz produced by the inverter and then a high frequency produced by the driver all affecting the ferrite..
If you look closely in the video, you will find that the wire labled 4 in red comes directly from the inverter to the red winding on the core and that of the high frequency is clearly seen white in color covered with red tape.....
the white output winding only serves to carry the high impulse current in the yoke to the windings on the plastic tube which take out the power with out back emf....
The similarities between all the invetors mentioned above is they use 2 frequencies, one low (50Hz), the other one high (Ferromagentic material resonant frequency) to produce excess energy....
Im going to show the similarities between this circuit and tariel kapanadze shortly
The image below is from Tariel Kapanadze video 2004, if you take a good examination its the same as akula device
Lets start with wire 1, it comes from the inverter connected to a battery, so we are converting DC 12v to AC 220V 50Hz, when take another
closer examination you see that the wire goes strait to the metal can with its AC 50Hz, but it also supplies some power to the step down
transformer which then feeds the Diode bridge 4 and then powers there driver circuit 3 whose signal is taken to the metal Can 5...
It makes no sense to convert 12v Dc from a battery to 220v 50Hz (AC) then step it down to 12DC unless you need the 50Hz...
It is clearly seen here also that two frequencies are affecting something to produce excess energy...
For safety reasons i will not make a video or even reveal my true identity but i tell you that the Lithuania experiment with ferrite Yoke has all the information you need to make a successful replication... what the forgot to tell you was there is no back emf in this device and its very hard to avoid back emf unless you utilise the thane heins Bitoroid transformer...
Have a good night, its already 1 AM here
The biggest problem is that forum members what to be breast fed, they want to be given from a to z without recognizing that we also put a lot of effort to get this work out...
I've shared my work with a few who have understood and I'm going to even send my 50watt output device to a forum member for free to prove my theory works...
I haven't yet gotten a stable high power output but once I get I will make a video and post on this forum for all to see...
If possible I can instead send it to you verpies so that you do a full analysis of it, if you promise a non disclosure...
My email is kotlinnick@gmail.com...
It's the same theory as the ferrite yoke from Lithuania but different set-up, I went through Tiger's work and the Lithuania work to come to my device
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg541947/#msg541947
AlienGrey
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #21793 on: February 29, 2020, 07:57:45 PM »
Quote from: Ntambi on February 29, 2020, 06:58:49 PM
Natambi I know the one your talking about, Didn't Wesley say it only works with a Russian Barium ferrite yoke ?
Also I'm pretty sure Nelson and others said it was dangerous because it sucks in energy from anything close to it including you.
Un less you have found a way round that like the frequency, Any way it's been a while since you last pasted, look forward to
any mods you have made to it from its first showing.
Rergards AG
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg543438/#msg543438
verpies
« Reply #21795 on: March 01, 2020, 12:58:47 AM »
Quote from: Toolofcortex on January 04, 2020, 10:43:58 PM
This is just another case of XXX username comes and go and teaches /asks something then he will lose patience in about 90 minutes since I messed with him and he's sensitive.
Quote from: Ntambi on January 04, 2020, 10:46:21 PM
I assume we all know that the source of magnetism in a magnetic is an atom, we also know that when an atom placed in a magnetic field it tends to orient along or against this magnetic field... That means when I place a ferrite yoke in a magnetic field I'm able to arrange all it's atoms(small magnets) in a given direction causing a net resultant field.. the next process is where resonance kicks in, because with resonance I'm able to apply a very small force for a big response, I then apply the ferromagnetic resonance frequency (NMR frequency) to those atoms there by turning them 180 degrees with less energy... These processes have created a super magnet with the ability to move it's poles just like magnetic spinning in a generator... If you can recall Weasley in the deflection yoke of Lithuania said they felt a huge magnetic field present, that's what caused it,
Guys,
Just because Ntambi is new here, does not mean that he is one of those fly-by-nights.
What he wrote above is anchored in well-known science.  The internal hyperfine magnetic fields of iron are extremely strong.  How strong might even surprise you.
According to the attached PDF document, these internal fields reach 33 Tesla in pure iron.  In a ferrite they will be different, of course, but the principle is the same.
Also, if nuclear magnetic resonance is possible in iron at approximately 45.5MHz then it should be also possible in the ferrite, even if at a different frequency.
Notice, that in iron the Larmor frequency is unaffected up to 0.6 Tesla of externally applied field.  Ferrite would have a different threshold but the principle remains the same.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg543444/#msg543444
verpies
« Reply #21799 on: March 01, 2020, 11:13:34 AM »
Quote from: AlienGrey on March 01, 2020, 05:16:59 AM
Re the Ferrite NMR I found this it might be of help or not to others in experimentation
https://www.researchgate.net/figure/NMR-spectra-of-nanocrystalline-zinc-ferrite-obtained-at_fig3_258004401
This data shows the same trend:  Decreasing the frequency as the externally applied magnetic flux density increases.  This is the opposite behavior relative to most other materials.
Ntambi also mentioned the word nano pulse; point being Ruslan, Akula device used a Tesla coil
If Dally used nano pulses in his device then ... that's my point. and Ntambi confirms it.
There are three types of stimulating signals that cause spin axis precession:
1) CW
2) Sweeped FM
3) Dirac pulse (low repetition frequency nanopulse, picopulse, etc...)
The nanopulse is only one of them.
As usual the problem with NMR is getting the phase of the individual precessions synchronized.  That is generally difficult because the precessional frequencies depend on the magnetic flux density of the field that the precessing atoms are subjected to, so if the field is not uniform, then these precessions get out of sync (in other words - randomized) and the net signal becomes zero.  That is the scourge of NMR !
The nature of ferromagnetic materials makes it easier to maintain field uniformity because the internal hyperfine field is so huge (33T for iron) that any externally applied field constitutes only a small fraction of the total field felt by the atoms, thus the Larmor frequency of a ferromagnetic is relatively insensitive to the externally applied field (up to 0.6T for iron).
Also, pure metals are very conductive and that makes it hard for high frequency magnetic fields to penetrate them, due to eddy currents and skin effect.  The solution to this is heating up the metal so high that its resistivity increases or using non-conductive ferromagnetic or antiferromagnetic materials (e.g. ferrites) ...or other ways to stimulate the precession of the atomic spin axes, e.g.: acoustic stimulation.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg543448/#msg543448
color
Void
« Reply #21806 on: March 01, 2020, 10:11:02 PM »
Quote from: Ntambi on January 14, 2020, 10:42:58 PM
Hello Ntambi. Welcome to the forum.
I would agree that the principle behind Daly, Akula, and Ruslan devices all appears to be the same principle,
as the setups are all very similar, and Ruslan of course copied Akula closely, assuming any or all of those circuits
were/are legit.
However, I am not convinced that what was shown in the 'Lithuania experiment' was the same,
but, yes, the underlying principle may possibly be the same in that setup as well.
Kapanadze remains a mystery so far, as he has kept some key details about his circuits hidden.
It is possible that what Kapanadze is doing is using the same principle as well, however.
I think you may be mistaken about the 'inverter' in Akula's early 'self-runner' circuit setups.
I believe that is an AC to DC power supply, not an inverter. Akula was converting
the high voltage AC output from his output coil to a lower DC voltage such as 12V or 24V,
and using that lower DC voltage to feedback back to the input and power his PWM driver. Yes, he may have a
fullwave bridge rectifier before the power supply, but the step down AC to DC power supply apparently still works
even when fed with say around 220V DC (or pulsating DC) rather than 220V AC.
Hello to everyone else as well!
All the best...
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg543462/#msg543462
Void
« Reply #21807 on: March 01, 2020, 10:23:40 PM »
Quote from: NickZ on March 01, 2020, 02:26:32 PM
   Well guys, most of the real builders have left this thread, or are waiting for something that really WORKS.
   What is this board coming to then?  NMR...  Here we go again... burning shit up, instead of finding the REAL solution, tapping ambient energy. Not harmful, non polluting, etz...
   Can we get back to that, instead?   If Verpies does not want to test his device, maybe itsu can do it?  Or, someone that can take input to output measurements.
   But, what is the point of bringing up a test of a device on this open source thread, that won't be disclosed? That does not sound right to me.
Hi Nick. I might be willing to run such a device through testing on my bench and
post all the test results here or on Youtube, depending on the conditions of the arrangement made, but it
looks like Ntambi wants to keep it private.
Ntambi:
In such a case, Ntambi,  maybe you can post up a private video of your test setup with any measurements
you are making, on Youtube or on your Google drive or similar, and PM or email me the link, and I could give an analysis
of what I see in the video. That way you don't have to send out your device to anyone. BTW, I am not at all convinced that
the Thane Heins style transformer arrangement is doing anything unusual at all, and from what I have seen,
Thane Heins seems to have come to the same realization at some point a number of years ago. I believe what Thane may have
been seeing with his transformer was actually just a leakage inductance effect.
Ntambi, if your test setup relies on the Thane Heins transformer, then I have doubts about your test setup.
Have you managed to get your test setup self sustaining (self-looped), or are you doing measurements
to conclude a COP >1 in your test setup?
All the best...
void
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg543463/#msg543463
Void
« Reply #21816 on: March 02, 2020, 06:08:26 PM »
Quote from: DavidWolff on March 02, 2020, 09:41:09 AM
And I have an OFF TOPIC question for Void JB had a circuit with a two capacitor parallel charge and a series discharge into a lead acid battery.
Witch JB seriously promoted Question did you prove that circuit?
I cannot post the schematic as it is copy write.
Dave
Hi Dave. I have tested several different variations of such Bedini arrangements, but the problem
right from the start with such circuit arrangements is they of course return less energy back to the battery
than is being expended from the battery to run the circuitry. Thomas Bearden proposed that pulsing the battery is what
is drawing in extra energy into the system inside the battery via 'asymmetric regauging', I think is the term Bearden used.
However, I have as yet not been able to see indications that such 'asymmetric regauging' is occurring in a pulsed lead acid battery
in my own experiments. That's why I have been focusing on the battery 'back popping' approach in the last while.
All the best...
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg543488/#msg543488
GeoFusion
« Reply #21846 on: April 18, 2020, 04:22:02 AM »
                        AG
                  "so what's the missing link we are ignoring ?"
  What many didn't mention much,   B.E.M.F. energy
                Is the missing link. ;)
Do not focus on the conventional ways of getting energy out....
** edited post
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544868/#msg544868
GeoFusion
« Reply #21855 on: April 18, 2020, 07:01:37 PM »
Quote from: NickZ on April 18, 2020, 04:40:05 AM
  Hi Geo:  Welcome back. How goes it? Long time  no hear...  NickZ
Hi Nick,
Yes, busy as always with many things that are important.
I'm just here to give hints that will help.
To understand the system is to focus on the Collapsing field part and using a HV swing right when that happens.
this is what gives it the multiplication method. resonances are used to keep in tune for the system to work and the amount that
you want to receive corresponding to the LC configs. Sync is needed as well otherwise it wont work.
then you have to see when kacher needs to be fired on the correct moment when Mosfet of pushpull is off.
The simple kacher has to be turned off completely by a switch, ( MOSFET) for a brief pulse when the collapse of field is
happening on the grenade. You can add an extra FET that will control the simple kacher negative terminal on or off in fast.
tricky part is that, to sync that specific part.
As what Ruslan said long back or Akula, the Tesla coil/ Kacher is what is doing all the massive output work after.
Make sure you only tap from out put after diode bridge. not befor! otherwise resonance is broken.
Bemf is what this output is, I have seen to much but had to say it.
Important EDITED **
** Nick, I reflected on my old videos where in 2016 was a year I almost had it but it was unstable
Yet it performed as Ruslan did but was limited power yet it did not effect the input at all when changing output
load. In those days I had no idea precisely what was going on but was doing my best to understand, but now I do.
The BEMF was present that day at the output , this is why it did not effect the input.
If there were another tesla coil circuit that could handle higher voltages input such as 60VDC would have made this output greater that day without increasing the input.
this is the video from 2016
The output is not affected by touching the antenna that also shows that the operation is different as I am stating.
https://www.youtube.com/watch?v=1weV296sjHU&t=
Now I know what to do ;), It has taken me 4 years to figure it out since that day.
Quote from: Raycathode on April 18, 2020, 09:50:48 AM
No look again at Nelsons circuit he kindly published he is using that !
Want to try again ?
It does not matter of his circuit now, yet he had some success but we are working on the Akula/Ruslan/Dniester Device here.
Focus on that.
I'm simply helping giving hints and my findings over the period of times.
Cheers
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544887/#msg544887
GeoFusion
« Reply #21857 on: April 18, 2020, 09:24:43 PM »
Quote from: DavidWolff on April 18, 2020, 09:05:48 PM
Geo! i'm not disputing you have something working BUT!
this was Wesleys Lithuwanian experiment I don't have one or Ruslans device
but this device worked.
Even Delomorto talkes about it on his wersleys thread
It makes sence Ruslans does not!
Hi Dave,
Yes I am aware of this device and have spoken to T-1000 about it many times.
The way this is making energy is completely different from the Akula/Ruslan Devices.
STAAR Yoke device is doing Ferrite Transmutation energy output. this leads to nasty Radiation from the extra material
they had inside the composite of the Ferrite material. those two frequencies Exited it and release it and within certain
resonance. Not sure if it was mixed of Barium inside the Ferrite.
**On thing Ruslan did not talk about nor Akula is how this energy comes about to existance.
that is where they are bastards for a long time... my time invested to see and experiment what it is all about
came to an realisation.
By my findings it is Bemf harvesting and havign resonance all over to keep the balance.
The collapsing field energy and having a brief HV HF pulse right after is what accelerated the output.
This is the type of output when loading it, will not have effect on input. Simple as that.
Ruslan's lastest videos back then for sure did show he using other ways how to
but it is the same outcome and method he is using but difference devices to get it.
Again, STAAR device is comepletely different, Unless you are trying to to nuclear resonance on copper
which is not the thing here right now.
Ruslan did not infact never say what is happening at output but at the video I just posted of my experiment in 2016
RUSLAN did msg me and told me I am close to figuring things out but I had still no clue back then.
Right now, I have.
Right now, I have.
Right now, I have.
Right now, I have.
Right now, I have.
Right now, I have.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544890/#msg544890
