Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
GeoFusion
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #21861 on: April 19, 2020, 11:10:31 PM »
Quote from: NickZ on April 18, 2020, 11:01:09 PM
   Geo. So,  can you show us wbat you can do now, with your device?
Hi Nick,
Soon, I'm making the bench setup in a much simple way now so when to add and remove is easier and
then to set it back how it was but without instability.
Take a look.
This is one of my recordings 4 years ago
https://www.youtube.com/watch?v=IdMVSiX2V7k
This clearly shows me now that I had something back then and I didn't even realize it up till now...
input is not affected when loading 300W low lumins or not loading anthing , input amps stay the same.
The Back Emf is what is filling up the cap, secret is not the diagram nor special frequencies,
I didn't even wrry on modulation...
Ofcourse for better performance you tune the telsa to the grenade but mines was not 100% tuned to it yet it gave result.
This is all about how you tune the coils and pulses of the tesla coil and when to interrupt when a field is in a certain moment.
Although 4years back it was by luck most of the time also having it right in the spot but not 100%.
***I'll make some sense in this for a moment how i view this device inner workings.
     We need to think and see we are standing near a Pool of water and you are standing at one of the sides of it.
     Now you trow a small rock in front of you in the pool which then creates ripple waves that travel..
     that will travel till the very other side of the pool
     and will reflect against the very end of the other side of the pool and come back
     and on the way the waves are growing larger when it reaches back to your side....
     That coming back ripple is the example just  B.E.M.F. ( a response ) and What if you could accelerate it?
     Imagine now in the when the ripples are coming back and your friend that is on the otherside is trowing a rock but fast
     right behind the ripples/waves and creates a nasty bigger waves that will come back, This is where you induce pulse.
     That is the work of the Tesla coil brief Pulses on the correct moment when tuned.
     So now to bring it on the device, When the Field is generated by pushpull via yoke over the 3T coil serie resonance
     when Current is Highest is where voltage is low then the pulse of Tesla Should be fired to give the amplification effect
     and having the cap at the grenade end to harvest it and in resonance at the same time. it's right when a field collapses.
This is what I see and what I have experienced and what I lacked of explanation of the guyz that have it.
Quote from: Utopia Now on April 19, 2020, 09:47:14 AM
Hi GeoFusion
Nice to hear from you   ... I am enthousiast  to learn more from you.
On what frequency does your Grenade resonate.
Are the first 2 layers wound one way and the second 4 layers the other way ?
Anyway cool video`s on your channel.
I heard you talk about the modulation coil   .. sounds like  you call that bifilar coil  or  do i misinterpret what you say i do`nt understand what you said there
Utopia Now     I am Happy :)
Hi Utopia,
No, I was not busy at all with modulation settings.. and I do not promote that.
Frequency of granade and tesla coils vary for everyone so if you use mines it wont make sense. have to use Scope.
What does make sense is to tune the system when you know you generate a field over the grenade
and when it collapses you have the HV pulse briefly at that moment to Spike up the Bemf that is coming back.
Quote from: DavidWolff on April 19, 2020, 02:56:10 PM
Well I'm not too convinced by any of it. none of it adds up to what Sergey, Enjoykin and Adrian were showing or saying
I get the idea a good part of the tread it's all about muddying the waters, even the grenade isn't wound correctly to get zero inductance.
So what's your track on the inductive winding what do you think that does ? Come on lets hear the jokes
And then there is the katcher what do you suppose is the truth about that ?
Come on lets rip this original idea of some ones fag packet apart and let see if we can get somewhere.
Thing is if you think the device works as is then there is no hope.
Dave
Hi Dave,
I know what you are saying, Some of these guys have schematics made or did also experiment on it, but maybe also
had no idea what is happening. this is why some of them only show what they think it is without good experimentation.
Some like Adrian Dniester had success with the device and figured it out. but also did not share because he is bought by
companies out there, same goes for Ruslan and others who have it or maybe had...
The kacher, the reason why it is there is to give a short pulse on the right moments of a collapsing field.
It could be any type of HV transformer at work as long as it does the very short pulses it has to do when it's time.
Hmmmmm....
It's all to know and see if it is possible but without proper test on the bench there will be no progress.
Do some Uncharted water experiments as how I did
and there we can see what is real and what not, many schematics I have
concluded as BS but not all and some of these schematics are not full given truth.
This Device works, It is just that ppl don't understand it yet.
Without HV Pulse the Device is Useless. it has to be a interrupted one.
ppl are not used to work with some of these energies in this way....
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544930/#msg544930
Void
« Reply #21862 on: April 19, 2020, 11:12:33 PM »
Hi Geo. BEMF (Back EMF, AKA Counter EMF ) is not the same thing as Inductive kickback spikes.
I have explained that several times already in this thread over the years. I believe you are referring to
inductive kickback (AKA flyback spikes).
If someone really has something, they should be able to demonstrate it in an clear and reasonable manner.
All else is just talk.
All the best...
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544931/#msg544931
GeoFusion
« Reply #21863 on: April 19, 2020, 11:35:18 PM »
Quote from: Void on April 19, 2020, 11:12:33 PM
All the best...
Hi Void,
Alright, hmmmm then it must be that then.
I was not 100% sure if it was BEMF directly but the inductive kickback sounds more tobe it if so.
But the point to all of this is for all to understand what is causing this device to function.
Soon enough I'll post a demo
Cheers.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544933/#msg544933
Void
« Reply #21864 on: April 19, 2020, 11:59:37 PM »
Quote from: GeoFusion on April 19, 2020, 11:35:18 PM
Hi Void,
Cheers.
Hi Geo. No worries. It's just that it can tend to confuse matters.
When a voltage (EMF) is applied to a coil, a current starts to flow in the coil.
The coil then generates a counter EMF (back EMF) to the applied voltage on the coil which opposes the applied voltage
(it is oriented 'counter' to the applied voltage, i.e., pushing 'back' against the applied voltage).
When the applied voltage to the coil is switched off suddenly, the magnetic field around the coil collapses and creates
an 'inductive kickback' (flyback) voltage on the coil which is aiding to the originally applied voltage (the kickback voltage is oriented
in the same direction as the applied voltage was, so it 'tries' to keep the current flowing in the coil in the same direction as it was originally flowing).
So Back EMF is counter to the applied voltage on a coil and occurs only when the applied voltage is still turned on, while a kickback spike is oriented in the
same direction that the applied voltage was oriented when it was connected to the coil, and occurs when the applied voltage to the coil is switched off.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg544935/#msg544935
GeoFusion
« Reply #21944 on: May 02, 2020, 04:24:16 PM »
Hi all :)
Hope you guys are doing well.
Some new Updates on the bench after a while;
https://www.youtube.com/watch?v=vTCaF7R4Z-M
All, if you are using simple kacher, I want to state that a fast switch ( mosfet) is needed on the negative leg of kacher circuit
this allows for short burst. It is needed for what we all are aiming for.
Nick, take a look and I have enough light installed now around so to see almost everything on the bench. =)
Soliman, hmm Impressive, does gives like a clean signal then.
Conico, it looks like when you activate the switch it jumps from 8Khz to 17Khz.
that is only the kacher? hmmm should not influence like that but ok.
         Cheers~
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545334/#msg545334
color
T-1000
« Reply #21949 on: May 02, 2020, 06:32:08 PM »
Quote from: NickZ on May 02, 2020, 06:23:39 PM
   conico:   Ok, well I still don't know what you are trying to say. Just don't get fooled by brighter bulbs, without knowing the output power.
   Anyways, here is a new video by Geofusion. He posted it on the partnered coil thread, perhaps he meant to place it here.
   So, I hope that it's ok to repost it here.   https://youtu.be/vTCaF7R4Z-M
   PS. Geo, you know that if you connect that HV Kacher with that much power to the induction circuits, it will blow something up, real quick.  Remember that Ruslan said, that the Kacher does not need to be strong, it's purpose is to disrupt the flow of the induction circuit, not blow it up.
Hi Nick,
As for katcher this can be used - https://i.imgur.com/c04yYgj.png
The second important thing is power interrupter which turns katcher ON at the right moments.
This makes FM modulation for Radio Moscow.
Also depending on how far you are from Earth lay lines the voltage needed to ionise air is needed to be higher the more far you are from it.
Cheers!
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545344/#msg545344
T-1000
« Reply #21952 on: May 02, 2020, 10:00:48 PM »
Quote from: Raycathode on May 02, 2020, 09:32:29 PM
T1000 have you got a link to the rest of that circuit ?
So here it is - https://i.imgur.com/p8ffNQW.jpg
It will take time to digest methods and tricks used in schematics and I do not expect anyone building one of these any time soon.
But that it OK.
Cheers!
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545350/#msg545350
GeoFusion
« Reply #21953 on: May 02, 2020, 10:34:07 PM »
Hi Nick,
Yes, you will need to be careful while applying such high voltages to tesla coil kacher.
Am aware of the dangers for the circuits.
Yes rusland said those befor but he did not tell to get more KW out to increase voltage ;).
Take a look at the diagram T-1000 shared, it is the diagram I am working on right now.
take time to digest it and see the differences. Ground is very important and the tesla coil/ kacher.
The kacher circuit you posted is good and right now use a interupter switch at the negative rail.
in the bigger diagram it will show the difference and setup.
Yes thanks for posting my video link, although I did post it a page back last msg.
Follow the steps and this will be it to understand.
Raymondo,
This is the diagram which me and T-1000 are working on for replication.
It is finally public.
https://www.youtube.com/watch?v=vTCaF7R4Z-M&t=
G.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545351/#msg545351
GeoFusion
« Reply #21958 on: May 03, 2020, 06:09:39 AM »
Quote from: NickZ on May 03, 2020, 02:58:02 AM
  Geo:   You said, "The kacher circuit you posted is good and right now use a interupter switch at the negative rail.
in the bigger diagram it will show the difference and setup".        quote.
   What interuptor switch at the negative rail? In what "bigger diagram?
   I don't know what you are referring to.
Nick,
This link will bring you to the diagram that I am using is also the one that Arunas posted today.
You will need to zoom in alot to read and see details it is a picture of size 11Mb so very high detailed.
Look at the left design, that si the one we are building, and you will see the kacher circuit at the top side
and see the positive and negative inputs for it and you will see that negative rail is given in orange color.
that is being interrupted through a mosfet on timing. check it out.
It will be necessary also for your setup. This diagram was once found somewhere and no one know from whom it came from
and was one time on a site that existed only for a few moments and then got shut down for unknown reasons, but this was
one of the salvaged materials I got from that site since last year.
G
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545357/#msg545357
GeoFusion
« Reply #21960 on: May 03, 2020, 06:56:14 AM »
Quote from: NickZ on May 03, 2020, 06:29:02 AM
   Geo:   Ok, thanks. However, I already have a schematic and most of the components to build a controlable Kacher circuit, designed by Stalker. What I was asking about was not about the controlable circuit, but about the simple kacher circuit that I already have working. So, an interuptor circuit like the first one that Adrian once showed on the simple 5200 transistor kacher circuit, is what I'm looking for. Not the Akula nor Fet based controlable Kacher.
Nick:
You are welcome, I'm here to help.
Yes i know you are using the Stalker diagrams but
trust me to use this new diagram for the next step to make it really work.
It is the simple kacher that it is showing in the big diagram if you follow it but look what controls it is interesting and is
needed. Gonna show you a pic right here soon enough to show you what I mean ;)
Thing is the kacher can't just free oscillate, it has to be interrupted ( short pulse )
and it ain't so hard to replicate something extra to it.
It will help and you will see results.
We are beyond the point to make this thing work as how it should now and we have everything to try it out right here
right now. The bigger reason why I am showing it is because Believe in it.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545360/#msg545360
GeoFusion
« Reply #21962 on: May 03, 2020, 07:30:42 AM »
Quote from: soliman on May 03, 2020, 02:52:21 AM
hello geo,
Could you explain the use of pin 3 in this TL494 circuit?
the circuit can work with pin 3 or not.
it seems to me that it has no use (it seems to me like an antenna only)
I'm very sorry, English is not my mother's speech and I don't understand it very well. Thank you.
I only use google translation
please make me a diagram of your kacher circuit.
Hi Soliman,
it is ok, you are doing your best :) and doing good in translation.
Pin 3 I'm not even using it in my setup. But it is the PWM comparator pin or feedback.
Not sure if it is used to auto tune while load is connected...Panov was not sure for what it was, written on the pic.
I traced the wire and pin 3 and it goes to the board before the kacher circuit, to a dip switch with 2 levers.
it is then connected to the CD4017 Chip. hmm
But that leg where PIN 3 is connected which is the C1 is the "clock input" leg #14 on the CD4017 Chip.
So to say CD407 is receiving Pulse signals from the TL494's pin3 white wire.
Hmmm Funny .. Might seem it works with the relay on the board maybe.
But to be sure it has to do with the start and stop of the system buttons.
In picture below you will see the pic of that circuit where the white wire is connected to the dip switch blue.
I have drawn arrows in red to show you what to see.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545362/#msg545362
GeoFusion
« Reply #21963 on: May 03, 2020, 07:36:56 AM »
Quote from: NickZ on May 03, 2020, 07:19:26 AM
  Geo:  Ok, I've seen the simple Kacher circuit that you are refering to now.Yes it is similar to my own version, but where is the interuptor circuit part (not shown). As that is what I am asking about.
Alright :) good.
yes it is a simple one.
Now do you see where on the minus leg of the Kacher is?
It is given a Orange color, orange wire which then goes to one side of a Mosfet if you follow the wire.
It connects to a IRFP3205.
The link to the diagram
I will do my best to show you on a modified pic if you have problems finding it. it is right there.
G
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545363/#msg545363
GeoFusion
« Reply #21982 on: May 04, 2020, 09:23:56 AM »
Quote from: Raycathode on May 04, 2020, 08:01:27 AM
A, '150 volts' I don't think that's quite it some how,
Any way the way I'm getting it from a few is the Katcher is used
like a funnel effect like the sap up a tree or a kid being sucked behind a bus on his bike,
remember those days?
No offence but Geo is using an accelerating motor to get his effect as far as I can tell,
I bet T1000 knows more than he is letting on.
Maybe it's time just to move on with all the dead ends.
Raymondo
Raymondo.......
I think you have absolutely no idea what you are talking about hahaha what a wierd talker.
you must be one of those trolls  ;)
          "Maybe it's time just to move on with all the dead ends." ??
give some recordings on your experiments to show why someone needs to move on... some useful insight and help
otherwise your just one of those trolls again.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545408/#msg545408
NickZ
« Reply #21990 on: May 08, 2020, 05:24:32 PM »
  Yea, you're trying to get somewhere, alright. There's plenty of room at the asylum.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545472/#msg545472
GeoFusion
« Reply #22015 on: May 13, 2020, 12:02:49 AM »
Quote from: NickZ on May 08, 2020, 01:04:02 AM
   Hey Geo:   How that "accelerating motor" going? Just kidding...
   Anyways, I was wondering if you've got your set up running yet.
   NickZ
Hi Nick,
Yes, I am about to do a good recording this week so to show the 3T series resonance area.
Something I have to show and for others to see. after that will connect everything and some more stuff that
I have stumbled across for the findings and the last pieces of puzzles.
Stay tuned
G
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg545553/#msg545553
NickZ
« Reply #22270 on: June 25, 2020, 05:45:58 PM »
   So, here we are. It looks the 2020 is the year of Free Energy Death. Why??? Well because, we are getting no where like this.There are no new self running device videos now. Nothing really new and exciting to talk about in the forums, no OU devices, no nothing. So, people here and elsewhere start fighting between themselves.   So, Everything is now going right on schedule... As planned.
Have you noticed...  Why is that?  I wonder.   AND, most of all, what the hell are we going to do about it???
Sit on your hands, keep fighting, and spinning our wheels.
   Looks like it.
   At least some of us are TRYING to build something, while all this is going on. But, wanting and trying, are not enough. We really need to get it together here. Or else... when the shit really really hits the fan. Well, you know what I'm saying. We and everyone else is going to be shit out of luck.
   Do we really need thousands of satelites, spying on us, tracking us, watching us, and doing what they want with us? As is happening now. Do we surrender to being chipped, and having to do things that we don't want to do, like having to get vaccinated, or your kids can't go to school, you can't get a job, can't even fly away on a plane, either. Like Cuba, like Venezuela, like...   Where am I going with this?     Just another bad hair day, for me today. Sorry.
    I'll get back in line.
         I don't know about you, but, I'm going fishing... After I eat another Snickers Bar.
     Chou.
   NickZ
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg547274/#msg547274
GeoFusion
« Reply #22346 on: July 05, 2020, 08:46:38 PM »
The greater ground the better connection and attraction for good output.
The less ground in my experience is less power out.
In comparison with the signals sharing from the TL494 in shown diagram,
where on my setup it is shared after the amplifier which is the 1R2110 to the kacher circuit.
Busy replacing small caps on the Pushpull driver, TL494 was limited till 27Khz.
Now will be able to have the range of till 50Khz which is necessary, maybe this was limiting me
Since very beginning.
Cheers
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg547693/#msg547693
color
Ntambi and GeoFusion's experiments have been drifting for several months.
How long do we have to wait? ::)
color
https://www.youtube.com/watch?v=srI7STFU5Mk&t=205s
https://www.youtube.com/watch?v=lcKsIpdsWUA
If you sell a Bedini generator for more than $10,000, which can be made for just $500, it is natural for investors to get angry later when they learn the facts.
There seems to be someone at this cafe who knows who the last unsuspecting investor is.
This is the case when you started knowing that it was impossible to recover your investment from the beginning.
Bedini generators are well known around the world.
Andrei must have known this cafe well.
The rumors are fast.
Does this look like Wesley?
I am a person who desperately wants members to experiment freely and sell generators.
Honesty is greater than commercial morality.
color
틀딱들은 온라인상에서 닥치고 있었으면 좋겠다구 개희야? ::) 8)
니미뽕~ ::)
박원숭이 추락사했다구 소문이 자자하더라 개희야.. ::)
신정환 가세연 나오면 볼만할게다 개희야 ;D
그 마을에는
착한 사람도 있었고 소악마가 있었는데,
그 마을의 지배자는 소악마였다.
소악마는 마을을 괴롭히면서 주먹질하고 욕하고 주름잡으면서 활개치고 떵떵거리며 살았다.
각종 흉악 범죄들도 저질렀다.
마을 사람들은 괴로워했지만 별 수단이 없었다.
하지만 마을은 대체로 행복했고 그들의 눈에 띄지만 않으면 뭘 하든 상관 없었다.
그러다 다른 마을에서 넘어온 중악마가 들어왔다.
소악마는 뭘 잘 모르고 경계했지만 몇 번 붙어보니 깨갱거리고 조용히
다른 마을 사람들처럼 행동했다.
기존 마을 사람들은 환호했다. 드디어 소악마를 무찔러줄 새로운 무언가 온 것이다.
중악마는 소악마가 하는 나쁜 짓들을 하지 않았다.
그래서 마을 사람들은 중악마를 믿고 따랐으나,
중악마는 소악마처럼 작은 나쁜 짓을 하는 게 아니라 더 큰 나쁜 짓을 하는 것이기 때문에 잘 보이지 않았다.
중악마는 자기 이득과 나쁜 판단에 따라 마을은 점차 망가뜨렸지만 마을 사람들은 잘 몰랐다.
나쁜 사업으로 마을을 망가뜨리고 팔아넘겼다.
그러다 다른 곳에더 대악마가 들어왔다.
사람들은 별로 불편이 없다고 생각했기 때문에 멀찍이서 뉴스로만 알 수 있을 뿐이었다.
중악마는 매우 곤란해지고 두려워졌다. 모든 것을 대악마에게 넘겼다.
대악마는 마을 전체를 악마화 시켜서 체질개선하고 마을을 불행의 도가니로 만들었다.
마을은 외부적으로는 그럴듯해보였으나 속으로는 완전히 썪었다.
악이 정의가 되었고, 악만 승리를 하게 되었다.
악마들과 악마들의 법이 활개쳤다.
하지만 마을 사람들은 멍청했고 너무 먼 이야기 였기 때문에 원인을 알지도 못하고 그저 불행에 대한
원인을 다양한 방법으로 추측만 하며 살 수 밖에 없었다.
마을 사람들은 아무것도 몰랐다. 모든 것이 완전히 망했다는 걸.
그러다 악마의 왕이 나타났다.
대악마는 순종하며 악마의 왕과 상생하였다.
마을은 과거의 모습은 온데간데 없이 사라지고 디스토피아 세계가 되었다.
사람은 사라지고 악마만이 남았고,
진실은 사라지고 거짓 뿐이고 바른 것은 아무것도 남지 않게 되었다.
착한 사람은 멸종했고 기괴한 세계가 되었다.
상상 속 어느 작은 마을의 이야기.
The clichéd electricity business is filled with recluse-electric masters and magical effects work.
A member of the free-generator part of'Ilbe', a mega site in Korea who is interested in this cafe, answered a question.
Nothing special. ::)
