Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 25 Guests are viewing this topic.
color
AlienGrey:
I don't understand AG's question.
All I understand English is that of Google Translate.
Like someone who speaks English professionally, I don't understand if I ask questions
Ask questions one by one simply and clearly.
And exclude the oscilloscope question.
AlienGrey
Color
Here is a component diagram can you explain its function, all it's function
so the novice can understand and how he can correctly replicate it.
My opinion is if he knew it's basic design characteristics and function
he would not be able to make it neverlone make it function
with out expert advice knowledge or a scope or faction generator.
color
The photo below is a grenade-coil about 38m (42-43V)/42m (44-45V) long.
https://www.youtube.com/watch?v=0CK1O_m-DNU
The coil was wound as described by Ruslan.
There are no coils other than this.
As I said before, I use the same capacitor.
The voltage difference between the two grenade-coils is about 2V.
Whoever asks me for an oscilloscope/wavelength/frequency, asks the blind for directions.
Trial and error is the mother of success.
color
I've also been trying to figure out the Basmus-Generator principle for a long time.
Whether or not the two diode method was used.
It is also possible that a thyristor was used.
Where did you hide the diode or thyristor?
It is impossible to create resonance with a transistor.
color
vasmus-СЕ генератор-часть 15-тунельный резонатор
https://www.youtube.com/watch?v=_bHd726we10
I initially reasoned assuming that this would have used a diode or a thyristor,
But,
What Basmus explains is a completely different resonance method.
When the DC voltage passes through the two capacitors, the voltage is amplified by the back EMF.
The key to the resonance is that the two capacitors generate back EMF at the same time.
Basmus also stated that it is a DC voltage.
AC voltage makes it difficult to cast the amount of current at ground.
In a closed-coil, the general back EMF increases only the voltage, but does not amplify the amount of current.
Radio wave sound between capacitor charging and discharging.
https://www.youtube.com/watch?v=7RzLx4XGZPc
This activates the ground with the Tesla-coil.
The method of activating grounding with a Tesla-coil is the same as the Kapanadze or Ruslan-generator principle.
The unique half-wavelength of DC produced by diodes, Basmus is the difference that creates resonance using a capacitor.
Wolne elektrony w powietrzu-free electrons in the air
https://www.youtube.com/watch?v=sV1Gn6ojSfg
I get a lot of help from this member.
We don't know each other, but he's a very smart guy.
