Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
아쿠라0083
https://www.youtube.com/watch?v=fp3sed_eli0
d3x0r :
Re: Akula 1 KWatt Free Energy Generator
« Reply #17 on: June 30, 2014, 08:50:41 PM »
https://overunity.com/14734/akula-1-kwatt-free-energy-generator/msg408288/#msg408288
Roman Karnaukhov interrogatively approaches the schematic.
This is because if you look at the schematic itself, it is understood as bifilar-resonance.
But neither does Roman say it is a bifilar-resonant.
The beginning of all misunderstandings is due to the schematic above.
In the Yoke-transformer primary coil, it makes no sense for a half-cycle-half-wave-resonance operated by two diodes to resonate the bifilar-coil and resonate the grenade secondary coil again.
What you need to do if you resonate directly is like going a long way.
It means that it is not convincing in itself to leave a good resonator Yoke-transformer and induce a bifilar-resonance between the coils, which greatly reduces the efficiency.
Let's remember what the Shark said about the theoretical moments of this device ;-)
it uses 2 generators 1 at a frequency of 100 with what is a kilohertz, the second for tens of hertz.
Coils with 2 generators are wound back.
the beginning and end of the pulses from the two generators coincide, which leads to mutual extinction of the field.
Mutual quenching of the field translates the transverse wave into a longitudinal wave (that is, the field of opposing coils does not disappear without a trace)
Such a change in the field occurs due to the impulse pumping of ferrite domains by a voltage without current; In resonance, the ferrite domains are temporarily rotated, returning to their place already carrying the current component
the total signal of all waves is removed on a removable coil and it is larger than at the input ...
Even though it is clearly mentioned that it resonates with a ferrite-transformer, the intruders distort it as they insist on [make your generator].
It is impossible to [make your generator] other than the Kapanadze/ruslan generator resonance method.
This is because the method of resonating is the same.
That's why I'm arguing that a free-generator is impossible if I don't make the Kapanadze/Ruslan generator way.
It is possible if someone accidentally discovers a new resonance method.
But,
Extremely difficult.
AlienGrey
color
Anyone who insists on'make your own generator' is very likely a patent stealer.
Not your own generator,
To make a Kapanadze/Ruslan type generator,
In a short time,
To help yourself.
color
AlienGrey :
Notice the windings it's not the same as other devices and you know nothing of cable lengths of frequency or tuning
The shape or frequency of the coil is not important,
It is important to note that because of the above schematic, the method of resonance has started to be distorted.
As for the way of thinking, Asians and Westerners think differently.
In Buddhism, this is called 'patītyasamutpāda'.
In all phenomena, countless causes (hetu) and conditions (pratyaya) are mutually established, so there is no one independent or self-reliant, and without all conditions and causes, there is no phala.
When translated into English, it is translated into words like this.
'dependent arising'
'conditioned genesis'
'dependent co-arising'
'interdependent arising'
If you dig into a substance, you may find very small particles, but it is difficult to find out what caused the substance to be formed.
The cause of the material is revealed only when the surrounding situation is first identified.
Who made the above schematic and distributed it?
Basmus?
My prediction is that Roman-Karnahof made it.
This is because few people predict positively and accurately like 'Roman'.
color
https://overunity.com/18210/radiant-power-from-solid-state-tesla-hairpin-circuit/msg549797/#msg549797
If the above Tesla Resonator for 100 years has not been able to create a free-generator capable of driving the own vehicle as well as excess electricity, this is not a Kapanase/Ruslan-generator-resonance method.
And nowhere is there any evidence that Tesla made a free-generator.
