Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 80 Guests are viewing this topic.
color
Akula infinitysav coil 31 mar 2019
https://www.youtube.com/watch?v=goSCu5IvYVY
Akula misunderstands the Andrei generator released in Korea.
My research team bypassed the purchase and disassembled the Andrei generator.
It was a motor-driven generator.
The generator was not rotated by its own force, but was a generator that turned out to be a motor.
Fuel Free 1kW magnetic motor prototype
https://www.youtube.com/watch?v=cRkuFenWLgg&t=81s
The 1KW-generator shown in the video above is a self-driving generator,
(Bedini motor generator type)
(It was not invented by Andrew, but by Bedini)
The Adams Motor. The late Robert Adams, an electrical engineer of New Zealand designed and built an electric motor using permanent magnets on the rotor and pulsed electromagnets on the frame of the motor. He found that the output from his motor exceeded the input power by a large margin (800%).
http://frienergi.alternativkanalen.com/Chapt2.html
The motor is an Adams motor,
It's Bedini, which combines the generator.
Electromagnetic generator 10 kW prototype
https://www.youtube.com/watch?v=Qrw6Xj5a0nM&t=201s
10KW was a generator driven by an installed motor.
It is impossible to drive the generator itself.
Permanent Magnetic Generator 70rpm 10kw 220VAC
https://www.youtube.com/watch?v=nfj_y8eItnc
It is the same as the generator made in Korea before.
The only difference between rotating a magnet and rotating a rotor with a coil wound.
color
Motor Generator ไดนาโมรอบต่ำ 20kw&15k
https://www.youtube.com/watch?v=MkRYn_5vriM
The idea that Andrei will win the competition with such a motor is surprising.
It seems like the pride of Russians in closed countries.
Russians and Eastern Europeans do not know the world situation, but do not know too much.
The reason why Andrei came to Korea is known through the support of the Russian intelligence agency.
There may be several reasons.
color
It has two output coils that are wound in different directions every other turn. This should reduce the back EMF on the transformer with different configurations.
The reason this device is in a transformer is so that with the output circuit goes into resonance, the changing currents, means changing fluxes which should reduce the overall current draw from the input coil.
The transformer does provide better induction interaction between primary and secondary coils than separate coils.
Research testing transformer
This transformer along with the load can be configured for several tests configurations.
This reduces the number of seperate coils in a test set up.
What can be done with the coil.
1.Does one configuration function simular to a pancake coil?
2.When operating an inductive load in resonance, does the changing dirrection of current reduce the current in the drive coil?
3.What happns when the drive coil is disconnected and the right wound coil is used as the drive coil and the left coil is used as the right hand coil?
4.What happens when the right and left hand coils are tied at the top together, then at the bottom together.
5. What happens when the output coils are connected in series.
6. What happens for efficiencies with using different configurations with different load configurations.
The main purpose of this transformer is an easy to use test bed for research to reduce the drive coil power in order to get usable power in the output circuits.
https://overunity.com/18625/lunkster-transformer/msg550314/#msg550314
[Bad money drives out good]
There is an interesting word among market economy terms.
Bad money turns into good money.
Underground economy Black money drives the world's financial markets.
Bad experiments in this cafe turn into good ones.
If you turn away from the essence, there are only unnecessary problems.
If the results are not drawn and finalized, only unnecessary discussions about obtaining results will continue even after 100 years.
If someone studies only the vicious circle, it won't work forever like Gordian Knot.
