Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
AlienGrey
color
AlienGrey :
This is the relay Basmus used in his generator.
I took this picture from a Russian cafe,
I lost that cafe address.
It does not come out even if I search Google.
I am very sad that many of the Russian-cafes I know are closed.
Yes, I began to draw this scheme, then the controversy began, a question-answer, they began to finish drawing, redoing, erasing, painting on.
This figure is taken out of context, a semi-finished product from explanations, a "stub" of my installation.
The conversation was on a matrix in some kind of drawing room.
Basmus says again and disappears.
ha...................This is a very difficult person.....
When the industrial spy wears the armband, it gives strength to the neck. ;D
Kacher works constantly, if you slow down the frequency conversion process, the module goes into a pulsating mode-then the generation is disrupted.
Basmus said,
It's important, but I'm not sure what I mean.
Translated from Russian into English and back into Korean, I understand only roughly. ::)
Later, I will prepare a video with the setting. Now there is nothing to show, the installation has been disassembled - the pursuit of power !!! 3-4 kW
The length of the grounding, it does not matter for me. The installation was launched on the river bank, there is generally a short segment, but the resonances flew away for a long time. The video hangs out somewhere in the internet.
I have 2 pipes of 1.5 meters driven into the ground, the wire goes to the apartment, 1 kW lamps are on normally.
In nature, I had to go to the trick(хитрость), poured 3 liters of salt water into the ground, the earth turned out to be normal.
The display can be seen with claws.
Each node is configured and tested for operability separately.
-Kacher with a 12 volt battery.
-modulator and tunnel with latra 150-250 volts.
- nodes of coordination and adder, simply by instruments.
When you set everything up and put everything together, the climax comes, not a damn thing works, transistors burn out, electrolytes scatter into the trash and so on, so on.
All this comes from the location, the interaction of the fields. Therefore, the fine tuning is done very carefully. The ugly editing is the result of the installation settings. Seeming simplicity is deceiving.
P.S. The choke is wound on a plastic pipe with a 1.25mm wire. There are no copper inserts.
The resonance of the throttle can be adjusted only with a brass tube, so as not to lose the quality factor of the circuit, afterwards, be sure to remove the tube.
It has already been 5 years, but there is no 3-4kW basmus-generator so far. 8)
color
Someone from a Russian cafe member erases the tunnel-copper circuit and leaves only the capacitor, so Basmus appears and says this.
color
vasmus - СЕ генератор - часть 4
https://www.youtube.com/watch?v=XrEypabzP4E
And the following is the content that Basmus mentioned as he thought of the back electromotive force wave released in a video.
It can be seen that at the time, Basmus also did not know the exact cause of the excess electricity.
color
My acquaintance's explanation is more accurate than Basmus.
Two diodes, which all "gurus" hide with a thick layer of electrical tape
https://www.youtube.com/watch?v=vr6mQHwf_Zs&t=14s
