Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
color
The basmus kacher lead in the picture above is two strands.
The Tesla secondary coil is also connected to the transistor.
The Tesla of the Basmus generator is clearly separated from the ground.
Эксперимент (Эффект качера)
Experiment (Kacher Effect)
https://www.youtube.com/watch?v=ozGwb0glcXg
Extreme High Voltage: TinselKoil X: First Light, Hash on Input
https://www.youtube.com/watch?v=WV3posVDqJs
Basmus says the Tesla pulsation is tuned to resonance.
stivep:
и этот список можно продолжать и это только тесла.
Вот это всё знать как "Отче наш" а после уже к системе переходить.
And that is the list of the most important fundamental questions.
(the guide describing fundamental ruling of to how to make Tesla coil acting as FE converting device from known and properly recognized
energy source at its natural origin)
That Tesla Coil assembly T.C* will act as your device you are looking for to get your free Energy for Free.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg550305/#msg550305
Basmus uses Tesla's secondary-coil's artificial lightning-effect (charge imbalance) indirectly.
The same goes for Akula's generator.
But,
Ruslan connects the Tesla secondary coil directly to ground.
He has shown connecting a Tesla secondary coil to ground in many videos.
There is one particular challenge here.
But for now I won't say this.
This is because it is a problem for members to solve.
Завершение демонстрации
https://www.youtube.com/watch?v=QRhtLrNFRRY&t=3s
color
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/msg549289/#msg549289
A few days ago, a member of'captainloz' told me'Rigol'.
I don't have'Rigol'.
I have never seen'Rigol' in real life.
I don't understand exactly what the members here are asking me.
Как это работает 2
https://www.youtube.com/watch?v=PHm3OLHBxX0&t=1065s
Ruslan also uses charged capacitors.
Basmus also uses a 300V charged capacitor,
My acquaintance also tests two diodes at 170~100V.
In addition to Tesla, the high voltage in the generator must have a high initial oscillation voltage.
Basmus and Ruslan used capacitors.
You can simply make an inverter device at home and use it for experimentation.
0~540V inverter.
Small E-type ferrite core experiment 8
https://www.youtube.com/watch?v=DHQakYDo8sM
Almost all experiments were conducted and finished from 2016 to early 2017.
So there is no need to purchase expensive'Rigol' separately.
There are a lot of'Strange members' trying to get the Kapanedze/Basmus/Akula/Ruslan-generator types to work on 12/24V.
There seem to be some members who don't understand what Basmus and Ruslan have said in the past that generators work at high voltages.
They are pitiful members.
color
Генератор 2 КW
https://www.youtube.com/watch?v=6jZ5How6G8Q
What do Basmus and Ruslan use relays for?
I know there are many beginners in electricity in this cafe.
I am also one of these.
And Basmus and Ruslan do not use separate transformers to obtain the initial high oscillation-voltage.
Instead, there are relays and capacitors.
This is also the reason why the generator can be operated with a 9V-battery.
However, there is no need to be sad that biography-veterans do not know biography common sense that even beginners know.
color
All of my experiments ended in 2018.
What I'm curious about is experimenting occasionally.
