Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
color
cheappower2012
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #17750 on: August 16, 2017, 11:46:34 AM »
Hoppy I don't think the transformer will heat up, I know that it will thru experimentation.
There is a lot of information in the 2012 device video/pictures as to how to configure the transformer also the tpu toroid is configured in a very similar way.
The buzzing in the 2004 device is coming from the inverter not the device.Its a transformer
being pushed pass its current limit.The 2004 device requires a given amount to start,its no problem
when he runs the inverter thru the battery.If he runs the ac plug with both the transformer for looping
and the inverter  connected to the battery there's no buzz
When he disconnects the battery and has the the output of the
transformer used for looping connected and plugs in the ac cord then he gets the buzzing,when
he removes the ac plug it stops because the device is powering the inverter.My opinion is
there's a small 1 to 1 low ac wattage transformer  in the inverter unfortunately it can barely start the device
this is the cause of the buzzing.Why this inverter would have this feature is strange but it may have had a function,its not an ordinary inverter.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg509588/#msg509588
And cheappower2012 pinpoints this.
This café has several members who have purchased the Kapanadze-generator. ;D ::)
color
free energy demonstration of 5 KWatts from Tariel KAPANADZE 2004.04.28
https://www.youtube.com/watch?reload=9&v=B4X5zy0piSg
The amount of current output from Kapanadze's indoor-generator inverter is 0.4A and 0.3A.
There is a reason.
Tesla does not affect the inverter output current.
Secondary amplification-transformer and Tesla are connected, and pre-over electricity is generated in the secondary amplification transformer.
The ground is also connected to the secondary amplifying transformer controller.
This is because the excess electric resonance generated by the inverter does occur only when it meets Tesla.
This means that the transformer of the inverter used by Kapanadze is not large.
The yoke-transformer my acquaintance has tested is that it is much larger than the one used by Kapanadze for resonance.
This is because the yoke-transformer has to directly handle the resonance.
This is an important word.
So 1A could be amplified to 6A.
Ruslan was also amplified to 6-7A.
This is because the principle of resonance used by my acquaintances and Ruslan is the same.
There is only the difference between whether there is a second amplification transformer or not.
Basmus also says that the resonant transformer efficiency is only 70-80%.
This means that even a resonant transformer made by Kapanadze cannot be more than this.
The perception of technology 10 years ago and 10 years later is very different.
The yoke-transformer could mean very efficient.
color
Void : [1190p]
« Reply #17836 on: August 24, 2017, 11:30:58 AM »
Saw something unusual last night, but it wasn't in a test setup on my work bench. :)
Last night there was a lightning storm, and there was a lightning strike that must have
been fairly close by as I saw the bright flash through a window, and the power switched off for
a second or two and then came back on again. They maybe have a surge protector on the power
line that caused the power to kick out for a second or two, I guess.
Anyway, later in the night I noticed that the outside light over the back door was on. I could
see it glowing brightly through the shades on a back window. I noticed the outside light was on
right away because I never turn that light on unless I go out the back door at night for some reason (rarely).
I checked the light switch and the switch was definitely fully down in the off position. I was puzzled
why the back outside light could be on when the switch was in the fully down (off) position. I switched
the switch on and then off again and the back outside light then turned off. The switch seemed to flick on
normally and flick off again normally.
I don't have any explanation for why the back outside light was on when the light switch was in the fully
off position. The back outside light does not have an automatic motion or light sensing switch on it. It is
just on a single regular mechanical flip switch. I tested the switch and it has to be a bit more than half way up
before the light turns on, and it was fully down. How the back outside light could be on when the switch was still all
the way down in the off position is beyond me. The switch does not appear to be damaged in any way. I tested
it quite a few times and it seems to be working perfectly normally. Talk about free energy... ;D
I suppose the most logical explanation would be that the switch contacts somehow got jostled and were
somehow making contact, but the switch toggle itself was in the fully down position and it is spring loaded.   :o
There was no one else in the house for the last while except me. I haven't used that switch in many months.
That light is off most of the time. Very seldom use it. Anyway, just something I thought was interesting, and
it seems kind of slow in this thread right now... :D
All the best...
P.S. Maybe the universe is trying to tell me something...
Lightning --> corona discharge --> sparkgaps --> free energy. ;D
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg509926/#msg509926
Технологии высокоразвитых цивилизаций. Лекция 4.4. Летающие на вихре
https://www.youtube.com/watch?v=CLp7RhHyH84
In my country, there is a saying that if you blow a pipe at night, a snake will come out.
Snake means 'lightning',
pipe means 'thunder'.
Soldiers playing drums on the old battlefield only play drums until the end of the war.
My youngest son's name is '천둥/Thunder(뇌 신/God of Lightning)'.
ПОЙМАЛ МОЛНИЮ Для Бесплатного освещения И отопления.
https://www.youtube.com/watch?v=VpSO7glvrMs&t=0s
It has good adhesion and is wide, so it is very good at interfering here and there.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg510278/#msg510278
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg510285/#msg510285
허송세월(A waste of time .... harsh years!)
https://www.youtube.com/watch?v=gouEQnXccG0
color
