Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Обсуждение СЕ генератора
https://www.youtube.com/watch?v=DA3EYPmwh7I
Разбор СЕ генератора от Руслана
https://www.youtube.com/watch?v=Okci3JBIYU0
Ruslan cites the circuit diagram of the T-1000 in the two videos above.
The reason is?
It's nonsense.
Extreme High Voltage: TinselKoil X: First Light, Hash on Input
https://www.youtube.com/watch?v=WV3posVDqJs
And,
TK, who claims to be an Australian, tests this and cheers.
Many users who made Tesla coils have already known about it for a long time.
classic Tesla transformer
https://www.youtube.com/watch?v=YsGwdPqCpX0
Spigel Branimir
https://www.youtube.com/channel/UCop2ybGsiTYo1iyttgjNo8g/videos
color
https://www.youtube.com/watch?v=Okci3JBIYU0&t=426s
And Ruslan misunderstands the secret of the resonance of the Kapanadze generator.
It would be more correct to say that Ruslan made the video viewers misunderstand.
In fact, it is possible that Kapanadze adopted a method of creating resonance with transistors, as Ruslan said, but I am still skeptical.
This is because capanaze can only be known by revealing the secret of Gongjin.
Transistors taking the place of diodes are not a matter of possibility but rather an unnecessary consumption.
It is excessive consumption.
color
Стоячие волны в БТГ
https://www.youtube.com/watch?v=-4KdimZGIrI&t=57s
My dad confirmed in the video above that Roman and Ruslan use the same word.
It confirmed that the way two generators work as one generator is the secret of resonance.
However, my dad learned from experience that the essence of the Ruslan generator is not the secret of resonance, but that it is more difficult to understand and build the system the generator operates on.
The reason Ruslan praised Geo is that he is the only generator user who has experimented with 6W lamps on Earth-ground.
TK is close to showman.
color
My dad watched Ruslan's video at the time
The related contents posted in this cafe emerged like a panorama.
captainkt
Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
« Reply #17943 on: June 17, 2013, 05:49:41 PM »
@ a.king, hope somebody comes up with circuit/secret to Brazilian generator before it disappears as I tried the weekend to copy diagram on meter showing transformer rectifier and inverter with earth/batterv somewhere in center. When I tried to put connection between transformer and inverter the inverter blew up. Back to drawing board for me, so much for free energy I have spent thousands.
Keith
PS (Brazilian gen is cheap when I look at all the equipment I have lost. Including 15 induction hobs 22 inverters and over 100 microwave ovens).
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg363346/#msg363346
Zeitmaschine
« Reply #17945 on: June 17, 2013, 09:38:10 PM »
Quote from: captainkt on June 17, 2013, 05:49:41 PM
Because most likely the inverter is not an inverter. It's a converter, converting potential-free pulsed DC coming form a rectifier back to AC (by means of synchronized thyristors). The input side of the rectifier can be connected to an inverter (and car battery) like seen in 2004 and green box video, or it can be connected to an insulation transformer like in these presentations: 1, 2, 3
If the primary side of the transformer is connected in parallel to a capacitor (LC circuit) then a short impulse from a 9V battery will create also a sinusoidal wave which can be used to start the device if internally back-looped.
Now what could happen if we connect potential-free pulsed DC to ground via a large self-inductance (maybe in combination with a capacitance)? Could this large self-inductance be suitable to capture electrons from earth which then amplifies the output current?
Just speculating, don't want to blow up my equipment (yet). ;D
But at least nothing of this contradicts what can be seen in all the Kapanadze and Stepanov videos.
BTW: It's impossible to start a factory-made (off-the-shelf) inverter with a 9V battery. That means whenever TK starts his device with a 9V battery there is no inverter (don't think he soldered his own one), just a sinusoidal impulse. Furthermore that means there are three different types of TK devices: One type works with an inverter and a car battery, one with an insulation transformer from grid, and one with a LC circuit triggered by a 9V battery.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg363357/#msg363357
stivep
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #4461 on: June 24, 2014, 07:41:42 PM »
the rf band contains dual band and when rectified still gives one ac waveform. radios do this by single half wave rectifier. to keep one band with modulation audio intact and filter the rf waveform so we hear sound in a reciever of the radio.
yes the voltage must be 220/110 volt depending on the country in the output of 3rd coil.
the circuit stage is correct and is  valid. the output is ac even after full wave rectification!
this is fed to the smps ac inlet and 12 v dc  is fed to the input to replace battery for feed back.
Rectifiers Challenge
First, create an AC signal source. You can do by using a function generator with no DC bias. Or, you can take the output of an RCX pulsing a square wave, and run that through a blocking cap to remove the DC bias. View your signal to confirm that it crosses the 0V line symmetrically.
Then rectify your signal, first with a half-wave rectifier, and then with a full-wave rectifer. Use 1N914 diodes, or something similar.
View your output waves to make sure that the circuit behaves as it should. Can you see the diode drop?
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg407662/#msg407662
정류 회로, RLC 교류 회로, 공진주파수(Rectifier circuit, RLC AC circuit, resonance frequency)
https://www.youtube.com/watch?v=gQo0LXIa-R8
color
The problem raised by captainkt is that it explode when the voltage output from the yoke-transformer is connected to an inverter (220V-24/12V).
Ruslan said the polar-capacitor exploded.
Как это работает 2
https://www.youtube.com/watch?v=PHm3OLHBxX0&t=417s
Polarity-Why did the capacitor explode?
There is an article organized by my dad community member.
He is one of Korea's Ilbe members.
https://ghebook.blogspot.com/2011/06/capacitor.html
Exploding Electrolytic Capacitors - What's Inside?
https://www.youtube.com/watch?v=Uq5gLrGumR0&feature=emb_title
