Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Perhaps back EMF is the reason why certain members of this cafe cannot give up 'Partnered Output Coils' until the end.
Akula's circuits- is this the principle?
http://www.aboveunity.com/thread/akula-s-circuits-is-this-the-principle/
Electric OU: TK-Akula 3V LED Test 1: Running on Capacitors
https://www.youtube.com/watch?v=qbNxHAlYC9U&feature=emb_title
Объект 013б бронепоезд фейк. Fake object 013b
https://www.youtube.com/watch?v=oGgCC7HXmlU&feature=emb_title
Объект 013Б HD
https://www.youtube.com/watch?v=4MVIBlHixNc&feature=emb_title
Объект 013Б 2
https://www.youtube.com/watch?v=wS-mtNEsPo4&feature=emb_title
My dad also looked at the Akula circuit diagram for days and days to find the principle of free development.
However, it is difficult to understand the principle of free development from the circuit diagram.
By first understanding the relationship between DC and AC, we can understand the principle of the circuit diagram.
The experience of trial and error played a part.
Fleming/Lenz/Transformers are the next problem.
The rest is easy.
However, Akula's Negative Back EMF would mean something else.
color
Is there a reason Ruslan is experimenting with frequencies independently of the Yoke-transformer?
none.
This means that the Yoke-transformer and the grenade coil don't have separate frequency measurements.
It means that it doesn't make sense to test the Yoke-transformer separately with many capacitors attached.
It is correct to finish the experiment in the early stages of making the generator.
However, a weak light is seen in the lamp estimated to be 15~60W.
The Yoke-transformer alone shows that the lamp experiment was conducted, but in reality, it means that it was conducting another experiment.
Ruslan's Yoke-transformer primary coil is 10+10 turns.
The secondary coil is predicted to be 12+12 turns.
With the PSU-24V, in my dad's experience, a 500W lamp should produce 60W brightness.
Ruslan referred to Yoke-ferrite, which was not directly related to other experiments.
If it's the same experiment that my dad did in 2016, it would be.
The light is 60W.
루슬란이 Yoke-변압기만 별개로 주파수 실험할 이유가 있을까?
없다.
Yoke-변압기와 수류탄 코일이 별개로 주파수를 측정할 일은 없다는 뜻이다.
많은 캐패시터를 붙여놓고 Yoke-변압기만 별개로 실험하는 것은 의미가 없다는 뜻이다.
이미 발전기를 만드는 초기 단계에서 실험이 끝나야 옳다.
그런데 15~60W로 추정되는 전등에 약한 불빛이 보인다.
Yoke-변압기만 별개로 전등 실험을 했다는 것을 보여주지만 실상은 다른 실험을 진행하고 있었다는 뜻이다.
루슬란의 Yoke-변압기 1차 코일은 10   10바퀴다.
2차 코일은 12   12바퀴로 예측한다.
PSU-24V를 사용하면, 나의 아빠 경험상 500W 전등에 60W 밝기가 발생해야 한다.
루슬란은 다른 실험을 진행하면서 직접적으로 관련없는 Yoke-페라이트 언급한 것이다.
나의 아빠가 2016년에 진행했던 실험과 동일하다면 그 실험일 것이다.
전등은 60W다.
color
its the basis for many many OU systems.
This is a great post and few following replies by bolt, i had a similar belief myself that reactive power can do real work. This is also one good point from Thane Heins, that reactive power can do real work.
So, bolt says load is put in series with inductor and a cap and that power factor is zero and that there are standing waves. So he is talking about resonant circuit. But series resonant circuit is not power factor zero, it is like short circuit as TheCell replies...
I believe this to be valid approach, i believe bolt powered 250W bulb with 3W of active power, but what exactly did he mean.
င စ ဆ ဇ ဈ ဉ ည ဋ ဌ ဍ ဎ ဏ တ ထ ဒ ဓ န ပ ဖ ဗ ဘ မ ယ ရ လ ဝ သ ဟ ဠ အ ဢ ဣ ဤ ဥ ဦ ဧ ဨ ဩ ဪ ါ ာ ိ ီ ု ူ ေ ဲ ဳ ဴ ဵ ံ ့ း ္ ် ျ ြ ွ ှ ဿ ၀ ၁ ၂ ၃ ၄ ၅ ၆ ၇ ၈ ၉ ၊ ။ ၌ ၍ ၎ ၏ ၐ ၑ ၒ ၓ ၔ ၕ ၖ ၗ ၘ ၙ ၚ ၛ ၜ ၝ ၞ ၟ ၠ ၡ ၢ ၣ ၤ ၥ ၦ ၧ
Motivation is not a special skill.
The short circuit is technically overcome.
Why are you, with great skill, silent?
AlienGrey
