Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 23 Guests are viewing this topic.
verpies
Quote from: color on September 30, 2020, 01:58:02 PM
The "resonance" in his words is not resonance everyone is taught about. From my understanding it is about best sync between different proccesses on 2 systems. One giving max optimal current in ultrasonic frequencies (skin effect) and another giving max effect on disruption with max BEMF then causing max emissions (electrons/ions/etc pull from background when using skin effect?) then sync both into best output.
So do you understand the principle of operation well enough to build a working device ?
color
verpies:
Before I answer your question, I will ask you one question.
What is the capacity of the capacitor in the red circle below?
I want to know the understanding you think.
verpies
Quote from: color on October 04, 2020, 12:55:40 AM
I do not know.
NdaClouDzzz
Series and Parallel Capacitors--parallel total capacitance: "the total capacitance is more than any one of the individual capacitors' capacitances"
https://www.allaboutcircuits.com/textbook/direct-current/chpt-13/series-and-parallel-capacitors/
AlienGrey
Struth guys, you just use small value caps to alter the resonant frequency of the tuned coil.
it's like a ramp affect charging till full then when the next pulse comes along it says for get it
and dumps it's charge in that transition and wolla you trigger your circuit to do the same thing
and you have resonance.
Note also this is Amtr Radio stuffbif you have !mtr wound into 3 Turns like Ruslans pic
then thats about 300Mhz hardly in res with 1. whatever ?    :o 8) :)
