Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 37 Guests are viewing this topic.
color
Ученые физики в шоке! Насос сделан из 1 бочки и работает без электричества.
https://www.youtube.com/watch?v=VqUV_s0-VAQ&t=99s
agree with the opinion that the paradigm of hydroelectric power should be changed. 8)
color
Jeg:
Re: Color's Kapanadze forum, FE builds circuits and comments
Reply #768 on: September 23, 2020, 01:16:55 PM »
Just pause for a while and give an answer on to this. What is that? Why is there? How affects the input/output? Why we don't see it in Ruslan's published circuits?
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/msg550923/#msg550923
Jeg's question I can't answer.
I don't have an oscilloscope, so I don't understand the specific frequencies that occur in the inductor above.
Instead, I experimented with the use of an inductor coil wound around a grenade coil from different angles.
I have experimented with the above inductors to find out what they are used for.
One of them was that the inductor coil was disconnected, and the voltage/current amount generated from the main grenade coil was measured under resonance, and the result was nothing special except that a voltage difference of about 1~3V occurred.
Kapanadze 200W
https://www.youtube.com/watch?v=IAPe3DiYt2o
Kapanadze aquarium generator
https://www.youtube.com/watch?v=j-NLBSBRsBM
So, one guess is that the inductor coil is for a 200-250W generator,
The main grenade coil was assumed to be used for 1.5 to 2 kW.
Although various experiments have been conducted so far, there is little effect on the resonance output with or without an inductor coil except that a slight voltage difference occurs.
It does not affect the resonance at which the generator operates.
https://www.youtube.com/watch?v=4lObGNvR_v8
The first two out of four are voltage measurements with an inductor connected,
The second two are voltage measurements with the inductor disconnected.
Digital testers are highly affected by resonance interference with surrounding wires.
So, I use it as a reference for a digital tester.
When measured with an analog tester, the normal voltage is measured.
Akula0083-#1-Demonstration
https://www.youtube.com/watch?v=txHtgwVm2-8
Only this person knows what caused the close-to-decorative inductor coil to be wrapped around a grenade. ::) 8)
color
AlienGrey:
There was a saying yesterday that Ruslan was streaming, but,,,, there is no news. ;D 8)
color
justawatt:
Hi color you said you have cracked Ruslan
Work in 2013-15.
Can you a working video it's now 5 years you have cracked it.
I am also working on this device too.
That too I don't want see the self running device.
I want see a 1 kw device full bright light bulb.
Let the device take 1.5 kw input too but output 1 kw.
Can you show one.
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/msg554327/#msg554327
If you reveal the schematic or picture of the generator you are experimenting with, you can identify the real fake.
It is okay if you do not disclose the generator.
color
ZVS драйвер и плоские катушки.
https://www.youtube.com/watch?v=j6d23yraFng
Démo de Fabrice ANDRE Energie produite sans contact sur une plaque à induction
https://www.youtube.com/watch?v=8AcxSoxWp-k
Inductor Experiment Demo 9
Everyone is free to imagine. ;D ;D ;D
