Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
GFusion:
БТГ 5 квт для электромобиля на IR2153 часть 22
https://www.youtube.com/watch?v=b134z-B0nl0&t=247s
Induction stove(grenade coil) and microwave transformer(Tesla coil lightning) met.
Works even without earth ground.
Imagination is the root of invention.
color
The schematic posted by the T-1000 above is how to make a reactive power transformer.
Running a generator with a reactive power transformer requires new ideas to get the return voltage that feeds the PSU.
The typical transformer used by Ruslan can get the return voltage (generator working voltage) supplied by the diode-bridge to the PSU, but
The reactive power transformer schematic posted by the T-1000 requires a slightly modified idea.
And in both ordinary and reactive power transformers, generator-resonance works.
color
Let me give you an example.
If the power supplied when the fan is operated is 200W, but the actual power consumed by the fan is 150W, then the active power is 150W and the reactive power is 50W.
Although the transformer posted by the T-1000 is far from the usual reactive power meaning.
However, the name of a transformer that does not produce power with a transformer, and that produces only a small voltage and a huge amount of current, is ambiguous.
In a broad sense, the transformer of the T-1000 is suitable for reactive power.
This is because in practice the transformer and free-generator resonance mechanisms are not related.
The way I do it, there are far more non-working areas and combination experiments than the ones that work.
In general, there are many short-circuit tests, so electrical safety breakers operate frequently.
Sometimes the electric wire is burned and eaten.
Sometimes the truth is found in a common sense that is impossible.
There is no coincidence in the experiment itself.
There are only more truths that have not yet been discovered in this universe.
color
Hello! My name is Nick and I have an MSc in Computer Science, I'm also Physics enthusiast and amateur/independent researcher. I would like to ask for your help on something. I'm currently trying to find a way to study ultrasonic waves' effects on water and I'd like to find a means of transferring a specific frequency (that would be 600 khz) to water. Unfortunately I was not able to find a cheap ultrasonic transducer working at that high frequency. The ones I found start from many hundreds of $. The wave type I'm trying to transfer is longitudinal waves (like sound waves), not transverse waves. So I was thinking of like a metallic tank, on which I would apply the transducer and that would transfer the waves to the water. Another way I thought of to produce this kind of waves at that high frequency is by making a custom siren type generator. But based on my calculations, this is also difficult because I'd need a siren with around 370 holes on every disc, spinning at 10.000rpm to produce only 60.000 and 600.000Hz would be the 10th harmonic. I was about to completely abandon the idea but I recently was told of a man who has succeeded in using a siren for the same job in the past and he was able to reach that high frequency. Unfortunately I don't have any way to contact him to ask, so I'm instead asking kindly for your help because this seems to be a dead end to me. I don't own or have access to any special kind of tools like laser cutters or anything like that but I would be able to use plexi glass for a custom made siren. Any thoughts please?
Source https://www.physicsforums.com/threads/way-of-producing-600khz-longitudinal-waves-piezo-or-siren.841200/
Just as those who emphasize American citizenship may not necessarily be American citizens,
Does this mean that it is evidence that the person who was low on being a Costa Rican citizen may not be a Costa Rican citizen?
