Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 28 Guests are viewing this topic.
color
As shown in the picture above, when the diode bridge used in the 12/220V inverter is directly connected to the secondary coil of the transformer, a large amount of current in the secondary coil and the newly defined reactive power are generated.
In addition, the 12/220V inverter diode bridge generates a tremendous overload on the coil induced to the transformer primary coil.
Diodes that generate overload are slightly different in the 12/220V inverter diode and the coil in which the 220/24V PSU plus (+) is guided to the transformer primary coil via the diode.
The circuit diagram posted by T-1000 is made with reference to the 12/220V inverter and diode bridge appearing in the Kapanadze generator.
The 220/24V PSU diode bridge I tested was made with reference to a Ruslan generator.
One diode was overheated, so I added two, and four more, but there was a lot of heat.
After about 5 minutes of operation, the temperature rose more than about 60 degrees Celsius.
What my daughter asked Ruslan was also about diode bridge fever and reactive power, but Ruslan didn't understand her question and she answered'I don't know'.
Indeed, Ruslan does not know of a reactive power generator system.
The Kapanadze generator 12/220V inverter diode bridge is huge.
The Ruslan generator needs a diode bridge to supply direct current to the transformer primary coil.
https://www.youtube.com/watch?v=r99g4mjEvTE
The generator demonstrated in Kapanadze's living room has a diode bridge attached to the transformer.
https://www.youtube.com/watch?v=Goq76CQapyI
The generator demonstrated in the yard has a diode bridge in a box and no exposed diode bridge.
My guess is that the diode bridge of the generator demonstrated in Kapanadze's living room is a diode that drives a 12/220V inverter.
The generator transformer in the living room is a transformer that operates by receiving alternating current from a 12/220V inverter, so a separate diode bridge is not required.
And the grenade coil is connected to the secondary coil of the transformer to generate alternating current.
And a resonant system made from a grenade coil doesn't require a large-capacity diode.
Because the resonance that drives the generator is an approach that requires a completely different idea.
The Kapanadze generator also needs one diode bridge,
In a Ruslan generator using a 24V 150W DC PSU, a diode bridge is also required.
The schematic posted by the T-1000 is a prediction of a Kapanadze generator, which is the result of the misunderstanding that a separate diode bridge is needed in addition to the transformer diode bridge to obtain the generator operating voltage.
color
Civil War ? Patriots Storm the Capitol as Woman is Shot in the Neck - Washington DC - USA
https://www.youtube.com/watch?v=5OJc2pUGOMY&feature=emb_title
During the debate in the House of Representatives of the US Capitol, disparate citizens entered the National Assembly, and Capitol Hill Petition Police aimed at the citizens and shot them.
A woman was shot and in critical condition.
An urgent citizen lifted a rifle at the level of a party rock, but did not counterattack.
It is the situation to the last.
It could be Antifa's job, or it could be a team's strategy.
color
https://www.youtube.com/watch?v=10pxq0Re7c0&t=7s&bpctr=1610064192
https://www.youtube.com/watch?v=MFzDhruvRNw
anybody know what Mike Pence got...
https://www.youtube.com/watch?v=0z8bu_yEJlI
Vice President-Pence received it without knowing what it was.
It is also in public.
What great stuff?!
Garbage rituals are held in the trash can.
Mike Pence's dream of the CCP
https://thefederalist.com/2016/07/19/5-times-mike-pence-helped-china-steal-american-jobs/
The shooting of Capitol Hill Petition killed four people, including Ashli Babbitt, who served in the U.S. Air Force for 14 years.
express our condolences to all the brave citizens who died in the fight against manipulated votes and illegality.
https://www.youtube.com/watch?v=Bx51eegLTY8
color
La mesure ULTIME d'un Appareil à Energie Libre
https://www.youtube.com/watch?v=BPdR1em-_5I
Salut tout le monde bonne année bonne santé et tout ce qui va avec donc l'année 2021 commence bien parce que aujourd'hui je serai derrière reçu mes petits composants qui vont te remettre de boucler voilà donc c'est des relais trio de pension à tout 50 Ampère 15150 A je pensais pas que ça existait ça coûte à peu près 3000 € et 3000 € neuf et j'ai réussi à en avoir d'occasion donc ça c'est vraiment très très grosse commence bien l'année il manque encore des Relais 500 terre sous 900 volts pour le bouclage donc le but de cette vidéo c'est de vous montrer un peu comment j'ai fait pour mesurer l'énergie rentré et l'énergie en sortie donc énergie de sortie de voir c'est très très simple il y a pas photo vous allez voir Thierry de cours j'ai rien inventé du tout comment mesurer énergie dissipée dans un bobinage vraiment très simple vous allez le voir par contre là où j'ai remarqué que j'ai eu pas mal de critique constructive pour certaines insultant pour d'autres c'est que on m'a dit oui mais tu en as plus Yonel donc comment est-ce que tu peux être sûr que ton WhatsApp mettre il a le temps de capturer te signaux et cetera bois tout simplement que il y a des méthodes qui permettent de s'assurer que qu'est-ce que vous mesurez il faut vérifier que dans des conditions donner nos mesure ce qu'on mesure correspond bien au 4 figures qu'on a fini donc je suis conscient que en mesure en impulsionnelle où il faut vérifier effectivement que je mesure voilà que que le mettre même si vos cher même s'il est aussi performant voilà il faut qu'il soit il soit il interprète bien les résultats d'accord il y en a une qui est indubitablement la plus la meilleure pas la meilleure j'en dis pas plus et celle-ci elle ne fait appel à un wattmètre a aucun juste à même avec un multimètre ça suffit pour mesurer l'énergie consommée en entrée et la comparer avec l'énergie en sortie en sortie par contre les fondations voilà donc vous allez voir donc petit tes dernières infos avant de commencer de passer dans le dur j'ai le projet pour le Prométhée Dios le site a été a été suspendu parce qu'il est refait on a fait une vidéo on a on a validé le moi qui l'a validé mais les mesures ont été validés au niveau de l'énergie entrée sortie donc je pense qu'on mettra les résultats de toute façon un peu plus tard j'habite aussi ceux qui sont dubitatif parce que là maintenant je vais faire appel à la communauté de l'ingénieur et j'en passe et d'autres si vous êtes intrigué pour vous voulez vérifier les résultats venez il y a aucun souci je les mets mesure en entrée sortie c'est libre au niveau du rock je vous présente et c'est vraiment très très simple donc on a un rack de contrôle et un rock qui est bloqué puissance et on va voir un troisième rock qui sera le rock de bouclage pour ce dernier l'oreille de bouclage j'ai reçu aujourd'hui voilà des regarder des composants j'en ai encore qui qui devrait venir parce que pour le bouclage je vais être à plus de 10 km donc c'est voilà il faut quand même des bons composants pour exemple il y en a un qui arrive c'est 500 ampères tu 900 volts c'est pas le petit composant d'accord donc pour le bloc de contrôle c'est un mot très simple j'ai deux dans des éléments simples alimentation à découpage avec des cartes alors au niveau de d alimentation à découpage avec les cartes j'ai pas toutes les cartes qui sont terminés laissé les cartes qui seront pour le bouclage j'ai que les cartes pour la production d'énergie excédentaire j'ai j'ai pour l'instant de fiche BNC qui sont branchés pour le contrôle de la puissance ici j'ai une prise c'est là le rock de contrôle donc pour l'instant enfin pour l'instant je serai tout le temps aux alentours des 60 watts 60 volts ampères alors pourquoi ce que j' ai des ventilo dedans parce que les cartes sont refroidi j'ai j'ai aussi des alimentation à découpage qui manque aussi merdique donc en puissance active je suis très bas mais en puissance apparente voilà je suis quand même à 60 x 2 puissance apparente mais peu importe au niveau de nous intéresse c'est d'avoir l'énergie en entrée l'énergie en sortie donc ici il y a le câble pour la puissance en entrée donc ce câble la est branché pas être branché sur le web mettre qui lui-même sera branché sur l'alimentation de laboratoire concernant les selfies si c'est des selles c'est pour l'asservissement c'est voilà c'est pour rien j'étais l'énergie au bon moment enfin bref ça j'expliquerai plus tard au fond j'ai le condensateur qui avec le circuit résonnant donc là je vous montrerai vous allez voir au fur à mesure de la vidéo comment je vais mesurer l'énergie dissipée avec ce condensateur et avec les différents éléments donc voilà donc pour l'instant c'est pas très compliqué oui c'est entrée sortie là-bas voilà la question maintenant c'est savoir est-ce que je mesure bien l'énergie en sortie l'énergie en entrée donc voilà on se retrouve sur le PC alors si le son est beaucoup de beaucoup moins bonne qualité c'est un peu normal parce que je suis sur le micro du PC donc comment se compose alors schématiquement le prototype c'est très simple pour alimentation ici le DL380 corps donc ça c'est la prise triphasé du bâtiment on a une alimentation de laboratoire qui fournit un courant et une tension tout ça pour une puissance tout tu peux définit tous les critères on a ici un wattmètre alors le wattmètre qui est remise en question et du coup je te le montrerai pas pour une raison qui est simple c'est que plus j'essaie de justifier plus que je me suis aperçu que ça jouer contre moi et donc du coup j'ai juste montrer la méthode ultime que j'utilise pour pour faire les mesures donc mais juste pour vous comprenez on a quand même de maître est branché sur le bloc puissance ici où il y a les différents éléments qui a un qui merdeuse et secondaire la bobine de dissipation d'énergie c'est 7 bobines ici on va mesurer l'énergie dissiper dans 7 bobines on a essayé le rock supérieure de rock super ici c'est le rock des de contrôle juste avant et ici on a eu 230 V de la prise du rat le tout avec le générateur de fréquence alors voilà un peu l'éclater du prototype le rock ici avec le rock de puissance alors ça c'est un peu le projet qu'on a avec le projet 1er telios pour le bouclage et tout ce qu'il y a qui dit Sion et j'en passe je remercie au passage Sam d'avoir fait ses petits ses petits chiens un paquet mais je te montrerai pas c'est pour le projet donc donc déjà abordé condensateur avec son bobinage à côté bien le bobinage et on boit primaire primaire alors maman on doit aller voir aussi ici voilà donc bon là il y a différents éléments aux gens parler sur le rock où il y aura au-dessus du bocage donc voilà et en primaire et secondaire avec le chef de service service mais voilà donc sur quoi je m'appui pour avoir des amis sur quoi cette nuit mes travaux c'est très simple je vous montre un truc alors c'est une pépite assez de pipi sexy rapport de recherche pour les associations donc c'est un truc qui date déjà bien un bout de temps j'ai envoyé un 1969 et sa date voilà quand même de tes travaux monter diffuser voilà je cherchais le mot donc en fait on peut voir un serpent s'il y en a qu'on peut voir ici à la caractéristique alors c'est ça c'est important je sache ce signal ici ce signal là ils ont des correspondances mais pas tout à fait voilà l'excitation paramétrique au ça pour vous dire que je sais dans quel champ d'étude je me trouve pour pour savoir quelle formule appliquer effectivement va pas d'apporter le formule si on sait pas dans quel genre d'étude 11 août donc il y a aussi cette Pépita qui est basé alors je vais descendre d'abord avant de montrer c'est basé sur Mandelstam papa Lexi pareil normalement on va aller moi aussi mon papa husky voilà report sur la recherche des associations non linéaire et ici alors ils ont fait des simulations par ordinateur donc ce qu'on peut voir c'est que bon il y a plusieurs quand même Institut précision et cetera si on fait des simulations explique tout simplement que avant à l'époque de papa et ce qu'il y avait pas de grands calculateur pour permettre de travailler sur les phénomènes non linéaire et du coup aujourd'hui avec les progrès scientifiques bah ils ont pu alors je te tape sur Internet et du coup il explique par exemple ils ont des clopes alors que tu es obligé de te régler la machine parce que sinon il avait mal voilà la simulation le bobinage donc obligé de se décaler de 3 % au niveau de la résonance amour voilà voilà 10 W 2 kilowatts voilà c'est quand même assez important alors encore une fois ça reste une simulation mais on peut voir ici voilà l'énergie perdue la 10 bien que l'énergie est perdu dans le circuit résonnant j'insiste dessus c'est perdu dans le circuit à résonance d'accord c'est exactement ce que là je vais vous expliquer comment je fais pour mesurer l'énergie dissipée dans mon circuit résonnant voilà comme ça je vais pas m'attarder dessus et pour expliquer que le domaine de recherche dans quel je suis voilà et très important alors on va d'abord s'intéresser à l'oscillation de sortie donc l'oscillation sortie de mon de mon prototype c'est vraiment très simple c'est simplement une onde averti d'accord merci des oscillations amorti donc on peut voir que on peut avoir des trains d'ondes amorti alors ça on s'en servait dans la radiotélégraphie d'accord c'est pas pour rien si la radio on peut voir un différents types donc en fonction de la Résistance quelque chose là c'est lié au couplage primaire secondaire là c'est le couplage la donc on peut voir le train d'avant et cetera encore une fois et encore une fois donc là on va sortir et c'est à ici à Ford au courant de l'émetteur avec la terre parce que ça a écouté c'est très très important l'argent aussi sur le fait que je n'en peux rien tout de suite ce sur quoi je Mathy la puis c'est des choses justifier et je n'ai rien inventé on peut voir ça c'est au niveau du primaire et ça c'est Londres au niveau du secondaire au qu'on peut voir ici au moment où on arrête de transmettre l'énergie au primaire qu'on arrête de mettre de l'énergie dans le primaire pas automatiquement il s'ensuit que l'énergie secondaire cherche à se dissiper dans la résistance du secondaire voilà donc là on peut voir que ici quand on commence à mettre l'énergie au niveau du primaire bah effectivement l'énergie au niveau du secondaire et à zéro espace et puis on va évoluer dans le temps et bah plus l'énergie va augmenter et puis l'énergie diminuer donc l'esprit est là c'est juste que quand on arrête d'alimenter au primaire bas automatiquement le secondaire va se retrouve en régime régime amorti libre c'est-à-dire qu'il n'est plus alimenté et l'énergie va se dissiper voilà donc c'est juju nature mort à la route et donc ce qu'on peut voir c'est effectivement ça peut être aussi quand vous prendre un condensateur vous décharger dans une salle on a l'énergie qui se dissipe dans la Résistance là que vous voyez la courbe ici c'est la courbe schématise la résistance interne dans notre secondaire alors on va prendre quelque chose qui est très important c'est ça l'énergie d'un circuit RLC donc remettre posant sur la vidéo si vous voulez le relire alors qu'est-ce que ça nous explique tout simplement que quand on a l'énergie électrique qui est en magazine et voilà qui est au maximum il va descendre et pas moi qui va descendre il va échanger d'accord avec la voix aussi magnifique que c'est l'énergie électrique en énergie électrique descend bah elle va transmettre son énergie à l'inductance et entre les deux bah on va avoir une perte d'énergie entre la là tu es là tu es là il correspond en a qui se dissipe par effet Joule dans notre bobinage d'accord alors après je vais pas rentrer dans les détails mais en fonction de la résistance de votre système l'ont d'abord tu y seras plus ou moins chaud ou court d'accord donc donc voilà donc moi dans sortie du du système j'ai une onde qui est comme celle-ci comme celle-ci et du coup bah on peut mesurer l'énergie dissiper dans notre circuit secondaire d'accord alors comment je fais pour avoir l'énergie dissipée par une onde amorti et ben c'est très simple il suffit de connaître sa tension maximum de mon condensateur parce que le condensateur il faut bien le charger jusqu'au là on est d'accord et une fois qu'on a stoppé notre système Bah le condensateur doit bien se décharger en totalité dans notre circuit dans d'autres résistance d'accord donc là on va aller sur sur sur normalement et metteur en scène voilà je n'ai rien et là qu'est-ce que vous allez voir alors ça je reprends exactement ce que j'avais petit au niveau la vidéo sur la bobine qu'est-ce qu'on voit la puissance mise en jeu dans le circuit CP il y a pas de me CV au carré x le nombre de cycle par seconde donc en fait c'est ce qu'on peut voir la prendre quand même ici qui est beaucoup mieux qu'on peut savoir c'est que ici on sait qu'on énergie stocker l'énergie stockée si correspond l'énergie que l'autre condensateur dans le circuit résonance ok est-ce qui se passe c'est que bah pour mettre NRJ dance condensateur mais je crois bien plus ça lui fournir l'énergie au condensateur est-ce qui se passe qu'est-ce qui se passe c'est que effectivement si on reprend à étincelle c'est bien ce qu'ils disent ils disent que notre conversation ici et bah quand on le décharge dans le circuit résonnant ici et bah on comment on peut connaître l'énergie transmis ici bah simplement simplement en connaissant la tension appliquer le condensateur qui se décharge notre circuit à résonance donc automatiquement Bah qu'est-ce qui va se passer et ben on peut connaître l'énergie sur une seconde dépenser par notre condensateur d'accord donc ni plus ni moins où est-ce que j'ai c'est simplement des comme ça mais répéter plusieurs fois par seconde et chaque ont amorti dissipe d'accord une quantité d'énergie et c'est quantité d'énergie correspond à chaque fois à une charge d'un condensateur qui se décharge ensuite dans la Résistance voilà donc ça pour mesurer l'énergie en sortie il y a rien de plus simple il y a rien j'ai rien avant tu es tout et là on peut le voir tout simplement alors je tiens à préciser encore une fois c'est que je ne veux je veux pas rentrer de mesure je ne t'ai rien montré je pense que j'ai suffisamment jusque-là essayer de faire mes preuves et quoi qu'on en dise en tout cas certaines personnes viennent vérifier et et constate comme moi un excellent d'énergie que là il y a pas de il y a pas de souci je vous invite aussi vous voulez venir il y a aucun souci maintenant comment on va faire pour mesurer l'énergie pendant près bah en fait c'est vraiment très simple tout simplement qu'est-ce qui se passe on a ici l'alimentation de laboratoire qui va chercher mon rat qui s'y met dans ce rock avec le bloc puissance qu'est-ce que j'ai bah j'ai des condensateur ce que je fais c'est que je charge condensateur et une fois que j'ai chargé ses condensateurs Bah qu'est-ce que je fais pas tout simplement que je déconnecte l'alimentation de laboratoire d'accord donc je déconnecte les tables d'accord bien la les déconnecte et je déconnecte le mettre et voilà parce que du coup on fait comment ils sont chargés ils ont une quantité d'énergie accumuler d'accord là il y a aucun souci donc un lézard on peut pas dire oui mais il y a des instructions peut-être qui calcule mal et c'est très simple c'est que j'allume le système et bah pendant 2 secondes et je vois pendant une seconde d'accord combien mon condensateur a perdu en énergie donc comment je fais pas c'est très simple il suffit de mesurer par la Formule 1 2016 écart et l'énergie de base de départ de l'autre commence à 7h et après quand j'ai éteint le système une seconde après moi je regarde combien il me reste d'énergie et après la différence d'énergie qui n'est plus là bah ça sera l'énergie dépensée en entrée voilà donc là l'entrée encore une fois comme ça on ne peut pas remettre ça en question je veux dire vous avez une batterie une des condensateur ce qui stocker l'énergie si vous apercevez qui vous avez moins consommer en entrée qu'est-ce que vous a qu'est-ce que vous avez dépensé dans ce bobinage de dissipation la résistance interne ici des mots qui nage sur une seconde je tiens à préciser c'est qu'effectivement il y a un lien d'énergie d'accord tableau petite vidéo sur ce tableau mais je vais vous le montrer donc pour vous compreniez alors ça c'est des mesures que j'ai fait manuellement mais vraiment manuellement pour être sûr d'avoir le coffre vraiment total total total de pas la peine de prendre en compte donc ici on a pas de me lasser 05 les farad CC et 6 cv ok d'accord si on se garer on voit que mon condensateur d'accord qui était chargé à 60,87 volts tout ça j'ai utilisé un bon et bien voilà et du coup j'ai 26, 121 jours et quelques de stocker dans mon corps à 7h de 14100 microfarad donc je vais descendre alors j'ai fait à peu près 150 ans j'ai fait 150 à pulsion d'accord et je m'aperçois que au bout de 150 impulsions sur une seconde bah j'ai perdu d'accord alors j'étais à 26 joules et je suis tombée à 18 jours du coup j'ai perdu une quantité d'énergie et moi ce qui m'a fallu ce qui ce que j'ai fait c'est que après et ben tout simplement que j'ai regardé mon condensateur d'accord il a correspond à 16,32 microfarad d'accord ici c'est 680 microfarad ce que j'avais testé sur un autre bobinage exetera c'est sur un autre bobinage mais j'avais donc sur plein plein plein de prototype donc ici, 32 microfarad assez chargé de 0,554 jours et à restituer dans notre résidence 0,154 jours aussi s'est passé cet après j'ai répété 550 fois donc on peut voir que on est à 137 ans 34130 734 alors là j'ai vraiment pris chacun pulsion ça m'a pris une semaine pour prendre le tableau est quand même balaise est ce qui s'est passé c'est que j'ai vraiment tout fait amorti et ça c'est un boulot fastidieux d'accord est-ce qui s'est passé c'est qu'on voit bien qui effectivement d'accord le petit de 10 minutes 10 minutes 10 minutes 10 minutes d'accord et on voit qu'à la fin à la 150e impulsion on est à 0,0, d'accord et on peut voir que du coup le total des joules cumulé dissipé par les ondes amorti dans la Résistance roller on voit quand total de J je suis à 18,86 jours de dissiper dans la résistance de mon système d'accord alors je vais dire voilà et ce qu'on peut voir c'est que on peut voir que j'ai je suis passée de 26,12 joules sur une seconde à 150 impulsion donc on peut voir que j'ai pris dans des condensateurs en entrée celui qui est dedans d'accord on peut voir que j'ai pris 7,32 jours d'accord est-ce qu'on peut voir c'est que en ayant pris un bon comment ça tu es énergies dans l' entrée de mon condensateur te voir je suis à 18,86 joules de dissiper dans le bobinage secondaire ici d'accord donc là ce qu'il se passe quelque chose et puis effectivement il y a bien une dissipation d'énergie dans la Résistance dans notre secondaire là j'en ai absolument rien voilà c'est un peu les mesures c'est comme ça que je l'ai fait je n'ai rien à te voilà donc en entrée je laisse le condensateur se décharge et pendant une seconde je connais énergie dissipée pendant une seconde l'énergie s'envoler du condensateur au niveau de l'entrée et après les énergie dissipée les parties de chaque impulsion et je les cumule la journée 150 bah il suffit dès que tu mulet et je le total des joules voilà donc c'est aussi alors s'il a 0,154 + 0,147 + 0,54 + 0,147 et cetera et cetera et cetera et cetera jouer cumul Basque ce qu'on peut voir et ben tout simplement où est-ce que tu es et bah ce qu'on peut voir c'est que effectivement sur chaque Houda Marti ben j'ai une énergie qui se dissipe oklar microjoule il faut bien imaginer ici d'accord je suis à 154000 et J donc en fait j'ai mon d'amorti qui s'est chargé ici à 154 min J et après tu es dispo dans la Résistance d'accord alors comme ça c'est que je suis simplement ils ont à l'oscilloscope avant qu'on peut couper comme ça on peut faire voilà d'accord là si je fous ici ici je sais pas comment je vais pouvoir le faire je sais pas si je vais pouvoir le faire et vous imaginez que voilà le cache c'est parti ici et ben ça me donne juste le nom d'un merci ici d'accord donc voilà voilà alors alors pourquoi ce tableau j'avais fait l'envoyer s'il y a quand même il y a quand même beaucoup beaucoup de mesures vous allez voir décédé grave c'est pas mal de choses là on peut voir quand d'entrée j'étais là 60,87 de départ et le postulat là ça a rien à voir au niveau des mesures mais c'est que j'avais de base c'est selon les travaux dedans c'est d'autres chercheurs plus on augmenter la tension en entrée plus on allait avoir des électros traction donc plus on est allé à avoir de de clopes et on allait pouvoir augmenter 7 7 c'était se paramétrique qui permet d'avoir un excellent d'énergie donc le postulat de base c'était quoi c'était de vérifier ça donc ce que j'ai fait c'est par la suite bah je suis passé à 203 V en entier au niveau du condensateur du coup en une seconde 150 impulsion je suis tombé à 185 joules d'accord donc 185 jours de départ et 203 ça nous fait un départ en entrée de 50,67 jours consommé dans mon beau comment ça tu heures de 14100 microfarad d'accord et après ben j'ai fait des relevés étapes d'accord et en fait en cumulant l'énergie dissipé par choc au d'amorti et là ça me donne 193, 83 joules d'accord donc on peut voir c'est que ça nous donner un code de 3,82 alors que précédemment on avait un code de 2,57 ans après cette deuxième deuxième tension je me suis dit je vais augmenter un peu plus et on verra si toi aussi bah là ça veut dire le tableau Benjamin col de 4,25 à 342,7 volts j'ai perdu dans un condensateur de 14100 microfarad 137,29 J et après pareil en mesurant chaque impulsion ballastée 4,43 et au fur à mesure sa chute Bah normal que la tension qu'est-ce qui se passe c'est que je ne retrouvais à 584 joules en entrée enfin si on voit qu'on était un code de 4,25 pour 342 V de départ 3,82 de 4 pour 203 le départ est de 57 pour 60,87 de départ d'accord et effectivement je rentre vraiment dans ce que c'est voilà voilà donc ben écoutez je sais pas quoi dire d'autre à part que l'énergie voilà je mesure l'énergie en entrée et dissiper voilà comment ils seront là donc une énergie de départ dans mon condensateur qui est débranché désolidariser d'accord de toute alimentation de tu vas te mettre comme ça ça enlève le problème qu'on peut me dire oui mais tu as des impulsions tu es ce site et sol exetera le plus important si de dissiper l'énergie de dissipera que ce soit les impulsions de microseconde ce que vous voulez il me fera donc là ce qu'on voit c'est que la désolidariser d'un condensateur de départ et là je revois section de secondes dans la résistance interne de mon bobinage une quantité d'énergie supérieur à ce que j'ai dissiper dans le condensateur voilà donc écouté c'est voilà donc encore une fois je la formule aussi que vous voyez ici bah c'est simplement la formule qui est ici d'accord voilà c'est l'énergie pendant 7h x 6 cv carré d'accord ça nous donne les J et x le nombre d'impulsion par seconde tout simplement voilà donc c'est quand même voilà c'est quand même c'est quand même fou j'ai quand même j'ai quoi aussi pourquoi pourquoi j'ai pas peur de vous montrer tout ça pour l'instant c'est simplement que ce n'est pas parce que vous voyez des Andes amorti que vous avez trouvé un accident dans les orties parce que si ça avait été aussi simple je veux dire depuis la création des émetteurs à étincelle qui a les excédent d'énergie dans les électeurs à et encore une fois une particularité à avoir mais vraiment je pense vous expliquer ce que ce cas là d'accord ou juste un truc c'est que il y a il y a beaucoup de synchronisation à voir il y a des services man c'est pas une électronique très très simple il y a quand même beaucoup beaucoup de réglage à faire il y a des fenêtres qui sont vraiment très très très très très rapide à voir donc ça sera la dernière et je vous dis à plus Ciao
