IEC Earth Engine First Magnet motor installed in Las Vegas
Started by ramset, March 14, 2019, 11:35:40 AM
hartiberlin
Well, it is really disapointing...I just analyzed the source code of the webpage...
It is no real Live Stream, just a 11 second loop, it is just a recorded MP4 Video file:here it is stored..
http://earthenginelive.com/live/rtsp-stream.mp4
So also no real load to see, just idling away....probably all powered by the big yellow battery...seen in the former video...So we are still waiting to see, if they will show a real KWatts load on any of their motors...
So still waiting for member Chet to get a few good engineers to them who have the right knowledge to measure it correctly...
Regards, Stefan.
conradelektro
Why this typical scam like behaviour?
I would accept an engine that can turn by itself for some time. It would be interesting without the double talk. Why not state the situation clearly?
No sane person will believe talk about 25 KW ( https://ie.energy/ , 25 KW, 24 Hours a Day, 7 Days a Week, 365 Days a Year) without real proof.
Is it an attempt to lure investors? If this is the case, it is very badly done. How naive can a investor be?
Greetings, Conrad
Quote from: hartiberlin on May 16, 2019, 06:45:33 AM
Regards, Stefan.
I'm not defending them nor am I interested in what they are doing but just wanted to inform you that because it's a mp4 file it does not mean it's not a live stream. This is commonly done on the web so that clients do not directly connect to the live stream source (the camera) and hog up all the connections to it over RTSP. And also so the stream can be embededed in a html5 video tag so that clients don't need any special plugins to view it. Here are code libraries that do just that:
https://github.com/horgh/videostreamer
https://github.com/Streamedian/html5_rtsp_player/wiki/HTML5-RTSP-Player
Just to be on the fair side.
tinu
Imho it's possible to extract energy from permanent magnets only if a proper setup is built as to intentionally deplete them eventually. Not worth the effort, though.
Also, imho it is possible to extract very small amounts of energy from the magnetic field of Earth. Suffice, in principle, to build a fixed large coil that rotates with Earth (1/24h) and captures flux variations due to Earth-Sun asymmetric magnetic field. I pondered for years if it'd be possible to increase such a minute power level by using a setup made of air-core coil(s) that run at a sufficiently high frequency to increase power output but also at a low enough frequency as to take advantage of magnetic reconnection in a relatively large space surrounding the coil(s). Maybe this could be the theoretical basis for some interesting devices scrutinized here in the last years? Anyway, I'm far from cracking any of them...
On the same line, I think it would be morally wrong to perfect such a device because it will obviously draw its energy from Earth's magnetic field, which I consider to be a non-regenerable asset. Imagine what would be the consequences of billions and billions of such devices running restlessly for years at high power levels ... This is a real dilemma I have for not pursuing this idea at full capacity! Same applies with extracting energy from Earth's electric field...
Strictly on-topic, I am suspiciously watching it, waiting for some substance info to be released. So far all I can see is smoke.
Best regards!
hartiberlin
 Karl Walsh The 11 second loop is a software glitch that's being fixed. When you want to fool people you do it with a 30 minute loop—not 11 seconds where the image obviously stops and reloads. I've seen this happen often with ATP pro tennis livestream. When the tennis live feed has a glitch it defaults to a 1 min 58 sec loop. Very peculiar. Anyway, the motor is pulling a small load— all the cameras— and that will be explained when the new page layout is finished. There will also be either a video timestamp or a physical clock atop Crystal. My vote is for the clock as that would be more difficult to fake. New software has been installed and you should see the improvements today. It's been quite the learning curve for a team without much experience in livestreaming.
Stefan Hartmann to  Karl Walsh7 minutes ago Thanks for the info. Cool would be, if they could at least show a 10 Watts LED light running all day long
from the generator output, also if it is not the promised 500 Watts load...If it could at least trickle charge its own battery and still be able to run a 10 Watts LED light , that would already show some additional output...and be more output than it uses itsself....
Stefan Hartmann   • a few seconds from now Also with a big sized Joule Thief circuit you can easily lightup a 10 Watts LED with just 1 to 3 Watts fully and additionally keep up the big yellow battery charged.... so such a setup would use less than 5 Watts, if you do it right and your magnet deflection arm is not drawing too much power and maybe could be redesigned to just use a relay mechanism instead of a motor, that only uses just one short current pulse....
