low weight and high power density energy conversion system parts
Started by lancaIV, March 22, 2019, 08:57:05 AM
                   Old and new re-/ invention or improvement :
          the search for the best technical advantage/disadvantage ratio and lowest production cost
                     rotative electric drive ( motor or generator, AC alternator)
https://www.nextbigfuture.com/2015/04/siemens-and-emrax-claim-best-power-to.html
                  2500 RPM range : 5 - 10 KW per Kg passive/active material weight
same article forecast : superconducting engine and motor 40-80 KW/ Kg power-to-weight ratio ( RPM ?)
                          but we are in 2019 :
so we have to search and find the disadvantages and the solutions :
rotative mechanical friction and wear ( system function lifetime shortening )
Ultrasonic surface treatment ( NUFM) and surface coating ( GEO, GEO+)  https://web.archive.org/web/20050305185038/http://bufo.ru/
Motor/ transformer space/ weight saving method :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#
Magnetic material saving or magnetic force improving array :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130314&CC=US&NR=2013062983A1&KC=A1#
Iron core or later air core :
https://www.lunduniversity.lu.se/lup/publication/ac5293fd-65b6-4ca1-be28-dc9dd1677f25
No magnetic material in the construction except in the magnets
https://patents.google.com/patent/US4318019A/en
NASA labs R&D plastic bonded magnets and
https://m.phys.org/news/2010-03-iron-nitrogen-compound-strongest-magnet.html
EE-parts 3d-print hard-/ software
https://www.sciencenewsforstudents.org/article/3-d-printers-offer-better-way-make-some-magnets
3d motor or generator parts printing : https://www.google.com/search?q=3d+electric+motor+print&ie=utf-8&oe=utf-8&client=firefox-b
wiring in future : coils or foils or sputted layer from copper to copper/ alu to alu to carbon( CNT) graphit/ graphene coils/ foils/layer
https://www.researchgate.net/publication/282022870_AT_THE_CUSP_OF_THE_NEXT_ELECTRIC_MOTOR_REVOLUTION_REPLACING_COPPER_WITH_CARBON_NANOMATERIALS
anorganic to organic materials
www.schillergy.com
From their PDF :
Motorcycle ( 16 KW) and Automobile ( 65 KW)  e-drive
               3000 RPM 120 V and 400 V
                       active material
Permanent magnets     0,1 Kg .       /KW
Copper                             0,1 Kg.        /KW
Iron                                0,1-  0,25 Kg/ KW
Permanent magnets : magnet array, magnet array x Iron-Nitrite/Nitrogen PM
Copper : aluminium ( later carbon)coil and cooling technique Ed Sines
        Comercial   DC motor, 3000 RPM 12V and more , Kg material/KW -motor price calculation
https://m.alibaba.com/showroom/dc-motor-3000rpm.html
https://m.alibaba.com/product/60740222994/2018-New-Design-6000W-Electric-Car.html?spm=a2706.7835515.0.0.3688470bagBk2W
                                                         180-195 US$/ 23 Kg ~
                                             < 10 US$/Kg. selling price.       passive/ active material e-drive
                                                  ? US$/Kg  production price ?
                                         How many hours function warranty. ?( theory/ practizise)
High power/ weight ratio drives without permanent magnets :
http://www.arestov.de/index.php/en/electric-bike
It would be wonderful to have ready to use devices  !  8)
Approved and tested ! ::)
And relatively cost attractive  ! :)
Probably one ( unexspected) source :  ;)
https://www.google.com/search?q=akio+hara+winpro&ie=utf-8&oe=utf-8&client=firefox-b
Nice generator, with very efficient conversion technique !
https://patents.google.com/patent/US20130038069A1/de
        https://patents.google.com/patent/US4464095A/en as " rotative cw/ccw magnetic principle"
                      and speed-/power-amplifier effect
A relatively low cost energy generator project :
Target : max.  500 Euros/KW unit  1 Euro-cent/KWh   tax Quote : 5% p. a.   amortization : 10 years
E. U.  In-situ private household energy generation ,renewable,low-/no CO2- and other GHG emission
1. dis-/advantage comparison :
A.Fanerator compressed air motor-generator chamber
B.Marzahn /Baquero Menendez solar cell chamber
C.Fritzsche multi generator-1 motor couple
D. Thorpe - Li Yng wind chamber with motor assistant for no/low wind
E.Mukherjee generator-rotative controle unit couple
Calculation and avaliation ( industrial prices) result : cheapest concept "E. Mukherjee", second. Fritzsche
Mukherjee prototyping :
instead hand curbe for system starting using a low cost electric drill ( accu or net sourced)
Bearing : ultra low friction treatment bufo.ru ,surface finishing and coating
generator/motor : Helmut Schiller high power density machine
  3000 or 6000 or 12000 RPM work velocity ( higher RPM = less material and costs )
Bearing ( untreated)  lifetime : 3000 RPM ca. 20000 hours full-load
                                                      6000 RPM.      10000 hours
                                                    12000 RPM.        5000 hours
             bufo.ru GEO treated.     3000 RPM ca. 80000 hours full- load
                                                       6000 RPM.       40000 hours
                                                      12000 RPM.      20000 hours
Helmut Schiller 3000 RPM 1 KW motor weight : 1 Kg
                             6000.                                            : up to 1/2 Kg
                           12000.                                            : up to 1/4 Kg
Mukherjee power unit cycle : 2 KW generator - 0,5 KW controls unit - rectification losts(+ res.) : net 1 KW output
https://patentauction.com/patent.php?nb=13385
Kg production costs if 10-20 Wh/Kg and given KWh storage a 125 US$ as price estimation ?
1000 Wh / 10 Wh per Kg             +- 100 Kg
1000 Wh / 20 Wh per Kg             +-   50 Kg
For comparison :
Alkaline Mignon- 1,2-1,5 V - /AA-batterie,+- 23 Gr. weight,, in 100 pieces package available for ≤ 10 Euros :
0,1 Euros per pill ,   4 Euros/Kg pill
this estimated Kg-endconsumer market  price as target for :
hydro-carbon electric cell from 1927 :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19280203&CC=FR&NR=633752A&KC=A
15 Kg for 550 piles , with 1,2 Volt and 1,5 A output  per cell
2020 production costs ?
( mysteric that 1927     660 Volt a 1,5 Ampere pils/piles-array      could drive a :  10 HP 1500 RPM electric motor )
                                  +- 1000 VA        +- 7457 Watt  nominal      ( electric engine start inrush behaviour ?)
Nicola Teslas Pierce Arrows wonder performance part/trick ?
I think this represents a cheap electricity source for bivalent energy generation and storage :
Conventional and artificial Wind + solar energy converter use and for no/low seasons rechargeable hydro-carbon cells  !
550 pils output x 30 hours  37,5 days      Mr. Chalko/mtbest.net  daily 800 Wh consume
                                                 10    days       oeko-energie.de intelligent household electricity consume a 3 KWh
Enough time to wait ( conventional wind/solar  converter use ) for the next wind breeze or sunshine/sunny days per charge  !
Important for the KWh- hydro-carbon cell energy price : how many water recharge cycles  ?
             550 pils a 1,2 V a 1,5 Ampere : 15 Kg x 4 Euros/Kg :
60 Euros/  1 charge = 30 hours =       30 KWh delivered                 =   2,0      Euros/KWh
                  10 recharge cycles     =    300 KWh delivered                 =   0,2      Euro/  KWh
                100 recharge cycles     =  3000 KWh delivered                =   0,02    Euro / KWh
Zinc without acid = up to 50 times less reduction/consume ( coating ?) ~ 50 recharge cycles ?
